Hi, totally beginner with Arduino here! Trying to write a sketch to create a simple MIDI touch piano with Arduino 1 using the Adafruit touch board MPR121. I would like to connect two MPR121 boards for a total of 24 touch keys. I saw several discussions on this topic and try several sketchs but due to the fact I don't know how to exactly code the Arduino's I didn't succeed. The only result I obtained is the following one I found on the forum where just one MPR121 is working with the Arduino but in a very limited way: it sends the same MIDI note for every touch pin of the MPR121. I suppose I should modify the code to define all the 24 midi values I want to use (and to add the second MPR121) but I really don't know how I can modify this code.
This is a library for the MPR121 12-channel Capacitive touch sensor
Designed specifically to work with the MPR121 Breakout in the Adafruit shop
----> https://www.adafruit.com/products/ 1
These sensors use I2C communicate, at least 2 pins are required
to interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <Adafruit_MPR121.h>
#include <Control_Surface.h> // Include the Control Surface library
// Instantiate a MIDI over USB interface
USBMIDI_Interface midi;
//*const uint8_t C4 = 60; // Note number 60 is defined as middle C in the MIDI specification
using namespace MIDI_Notes;
// MIDI address of the note to send
const MIDIAddress noteAddress = {note(C, 1), CHANNEL_1};
const uint8_t velocity = 0x7F;
//*0b1111111; // Maximum velocity (0b1111111 = 0x7F = 127)
#ifndef _BV
#define _BV(bit) (1 << (bit))
#endif
// You can have up to 4 on one i2c bus but one is enough for testing!
Adafruit_MPR121 cap = Adafruit_MPR121();
// Keeps track of the last pins touched
// so we know when buttons are ‘released’
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
midi.begin();
//Control_Surface.begin(); // Initialize Control Surface
Serial.println("Adafruit MPR121 Capacitive Touch sensor test");
// Default address is 0x5A, if tied to 3.3V its 0x5B
// If tied to SDA its 0x5C and if SCL then 0x5D
if (!cap.begin(0x5A)) {
Serial.println("MPR121 not found, check wiring?");
while (1);
Serial.println("MPR121 found!");
midi.update();
// Get the currently touched pads
currtouched = cap.touched();
for (uint8_t i=0; i<12; i++) {
// it if is touched and wasnt touched before, alert!
if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
Serial.print(i); Serial.println(" touched");
midi.sendNoteOn(noteAddress, velocity);
// if it was touched and now isnt, alert!
if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
Serial.print(i); Serial.println(" released");
midi.sendNoteOff(noteAddress, velocity);
// reset our state
lasttouched = currtouched;
