Ok here is my project. I want to use Two Seeduino Xaio SAMD21 boards to use the onboard USBC ports to send and recieve MIDI commands while using Serial1 to transfer the codes to one another.
This is for a Mutli FX pedal board to control an amp sim plug in that uses USBMIDI for desktop editors. This MUST be as small as possible and the reason for the Xaio boards.
How it should work:
So there will be (Board A) and (Board B) (MFX unit on A and Plug-in unit on B for example)
So an example is I have the board in a preset selection mode to select the next preset up or down. It should send a MIDI command. Board A sees MIDI input and all it has to do is send the data to Board B via Serial1 via the Tx pin.
Board B sees this data via Serial1 and then converts it to what ever MIDI data I assign and then sends out its USBC port to the linked device. It may use a different code for its preset selection mode or I may want it to something different. This will need work both ways as I may need to send inputs from the Plug In back to the FX pedal.
Now the test set up. So have the two boards communicating via Serial1. I can turn the onboard LED on and off on Board B and it sends a return message. I can see this in the serial monitor with the IDE connected to Board A.
Now what I need is to read MIDI from the onboard USBC port from board B and send what ever is recieved over Serial1. It does not need to be complicated this can be a single number not a sting as Ill have to remap the MIDI command back out anyways.
if MIDI data = X
Serial1.print (21)
Is there a way to send the MIDI data to a variable? Then say Ok if this variable equals this: Serial1 print this?
Here is the code set for now there is a master and slave. Board A is the master.
Master
// Initialize the second serial port on pins 5 and 4
Serial1.begin(115200);
String readString;
String Q;
//-------------------------------Check Serial Port---------------------------------------
while (Serial1.available()){
delay(1);
if(Serial1.available()>0){
char c = Serial1.read();
Serial.print(c);
if (isControl(c)){
while (Serial.available()) {
delay(1);
if (Serial.available() >0) {
char c = Serial.read(); //gets one byte from serial buffer
if (isControl(c)) {
//'Serial.println("it's a control character");
readString += c; //makes the string readString
Q = readString;
//--------Checking Serial Read----------
if(Q=="on"){
Serial1.print("1");
Serial.println("Sent:On");
if(Q=="off"){
Serial1.print("2");
Serial.println("Sent:Off");
Slave
//#include "usbmidi.h"
#include "MIDIUSB_Defs.h"
#include "MIDIUSB.h"
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
pinMode(13,OUTPUT);
// First parameter is the event type (0x0B = control change).
// Second parameter is the event type, combined with the channel.
// Third parameter is the control number number (0-119).
// Fourth parameter is the control value (0-127).
void controlChange(byte channel, byte control, byte value) {
midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
MidiUSB.sendMIDI(event);
String readString;
String Q;
while (Serial1.available()) {
delay(1);
if (Serial1.available() >0) {
char c = Serial1.read(); //gets one byte from serial buffer
if (isControl(c)) {
Q = readString;
if(Q=="1"){
digitalWrite(13,LOW);
Serial1.println("I see You!!");
if(Q=="2"){
digitalWrite(13,HIGH);
midiEventPacket_t rx;
do {
rx = MidiUSB.read();
if (rx.header != 0) {
Serial1.print("Received: ");
Serial1.print(rx.header, HEX);
Serial1.print("-");
Serial1.print(rx.byte1, HEX);
Serial1.print("-");
Serial1.print(rx.byte2, HEX);
Serial1.print("-");
Serial1.println(rx.byte3, HEX);
} while (rx.header != 0);
