I need some advice on using the mills function with while loops. I would like to execute some code section for a specified amount of time, eventually serving as time wasting instead of the delay() function.
I noticed that the timer gets stuck in the while loop, and stops counting. The timer value stays zero in the while loop, and therefor the while loop never meets the exit criteria.
the typical loop you are looking for is BlinkWithoutDelay.
there is a system time millis() that counts in microseconds.
you can note that time
then = millis() ;
duration = millis() - then ;
but, that would just refresh each loop. and you want to create a delay anyway.
lets use a value.
int period = 1000 ; put before setup.
int then, duration ;
in loop() put this
if (duration >= period )
// do that thing you want to do ;
then = millis(); // starts the timer all over again
just change the period to whatever you need.
as a note, this is only for very short timing periods.
for longer periods, you would want to use unsigned long and not int
blink without delay has many-many variations. this is just a simple one.
if (duration >= period ) {
count++ ; // increments a counter each period
if (count >= 60) {
// read temperature
count = 0 ;
this sequence does a thing each second ( whatever your period is)
then increments count
and after 60 seconds, it would read the temperature.
same stuff to increment count.... and add count_HR before setup
And note - you do not use "while" loops in any program that requires multi-tasking - doing more than one thing at a time. And "delay()" is itself, a while loop, so you cannot use that.
All this said, the problem with your program is simply that it is disorganised and you have not thought it out properly.
Paul__B:
That's not really true, although I understand Paul__B's reason for recommending that as a rule for beginners. You can use while loops, as long as you know they will execute quickly and not hog the CPU. For example, scanning an array for a particular value, or repeating a calculation for a small but unknown number of repetitions. But a while loop with a delay inside is a no-no, as are while loops which repeat until millis() reaches a value that is more than a handful of milliseconds later than it started.
