Basicaly I have a code that reads a temperature sensor and gives the temperature when you press the button (on tft) "refresh". The problem is that sometimes it refresh without touching the button and I have a python code that read the serial and print the temperature in a table, but it has a line limit so it desapears with every reading. The point is, I want to refresh only when the button is pressed. I also havea version of this code that only uses a simple delay of 1s.
#include <MCUFRIEND_kbv.h>
#include <TouchScreen.h>
#include <Adafruit_GFX.h>
#include "Nanoshield_Termopar.h"
#include <SPI.h>
#include "Nanoshield_LCD.h"
Nanoshield_Termopar termopar(43, TC_TYPE_K, TC_AVG_OFF);
Nanoshield_Termopar termopar2(44, TC_TYPE_K, TC_AVG_OFF);
Nanoshield_LCD lcd;
#define XM A2
#define YP A3
#define YM 9
#define XP 8
#define TS_MINX 90
#define TS_MINY 92
#define TS_MAXX 906
#define TS_MAXY 951
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_RESET A4
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
MCUFRIEND_kbv tft;
#define MINPRESSURE 10
#define MAXPRESSURE 1000
#define PRETO 0x0000
#define BRANCO 0xFFFF
#define AMARELO 0xFFE0
bool error = false;
bool valor_botao1 = false;
bool valor_botao2 = false;
int px = 150;
int py = 128;
int largura = 150;
int altura = 205;
int tolerancia = 0;
unsigned long tempoAnterior = 0;
const long intervalo = 1000;
void telaInicial();
void telaBoasVindas();
termopar.begin();
termopar2.begin();
uint16_t ID = tft.readID();
tft.begin(ID);
tft.setRotation(1);
telaBoasVindas();
telaInicial();
unsigned long tempoAtual = millis();
TSPoint p = ts.getPoint();
pinMode(XM, OUTPUT);
digitalWrite(XM, LOW);
pinMode(YP, OUTPUT);
digitalWrite(YP, HIGH);
pinMode(YM, OUTPUT);
digitalWrite(YM, LOW);
pinMode(XP, OUTPUT);
digitalWrite(XP, HIGH);
if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
p.x = tft.width() - (map(p.x, TS_MINX, TS_MAXX, tft.width(), 0));
p.y = tft.height() - (map(p.y, TS_MINY, TS_MAXY, tft.height(), 0));
if (p.x > px - tolerancia && p.x < px + largura + tolerancia &&
p.y > py - tolerancia && p.y < py + altura + tolerancia) {
if (tempoAtual - tempoAnterior >= intervalo) {
tempoAnterior = tempoAtual;
tft.fillRect(186, 30, 85, 30, PRETO);
tft.fillRect(186, 170, 85, 30, PRETO);
termopar.read();
termopar2.read();
tft.setTextColor(BRANCO);
tft.setCursor(200, 179);
tft.print(termopar.getExternal() - 1.25);
tft.setCursor(200, 40);
tft.print(termopar2.getExternal());
void telaBoasVindas() {
tft.setRotation(3);
tft.fillScreen(BRANCO);
tft.setTextColor(PRETO);
tft.setTextSize(3);
tft.setCursor(85, 100);
tft.print("TFJ V3.0");
delay(5000);
tft.fillScreen(PRETO);
if (termopar.hasError()) {
tft.setTextColor(AMARELO);
tft.setTextSize(1);
tft.setCursor(85, 80);
tft.print("Termopar 1 com erro");
void telaInicial() {
tft.setRotation(3);
criarBotao(186, 145 , 90, 85, "", PRETO);
criarBotao(186, 10, 90, 85, "", PRETO);
criarBotao(20, 100, 120, 50, "", PRETO);
escreveEstado(92, 42, "Temp_1", AMARELO);
escreveEstado(92, 176, "Temp_2", AMARELO);
escreveEstado(42, 115, "REFRESH", AMARELO);
void escreveEstado(int posx, int posy, String texto, int cor) {
tft.setCursor(posx, posy);
tft.setTextColor(cor);
tft.setTextSize(2);
tft.print(texto);
void criarBotao(int posx, int posy, int largura, int altura, String texto, int cor) {
tft.fillRect(posx, posy, largura, altura, cor);
tft.drawRect(posx, posy, largura, altura, PRETO);
tft.setCursor(posx + 12, posy + 1000);
tft.setTextSize(3);
tft.print(texto);
