Hi there,
I am using an Arduino to display some parameters from a solar inverter via modbus. I do not have the solar system set up to practise that so I am trying to sort out the rest of my Arduino interface things before hand. I am fairly new to Arduino coding but not struggling too much, I have this code that I procured and have edited to fit what I need:
#include <TimerOne.h>
//the pins of 4-digit 7-segment display attach to pin2-13 respectively
int a = 2;
int b = 3;
int c = 4;
int d = 5;
int e = 6;
int f = 7;
int g = 8;
int p = 9;
int d4 = 10;
int d3 = 11;
int d2 = 12;
int d1 = 13;
long n = 50;// n represents the value displayed on the LED display. For example, when n=0, 0000 is displayed. The maximum value is 9999.
int x = 100;
int del = 5;//Set del as 5; the value is the degree of fine tuning for the clock
int count = 0;//Set count=0. Here count is a count value that increases by 1 every 0.1 second, which means 1 second is counted when the value is 10
const int buttonPin = 32;
int buttonState = 0;
//set all the pins of the LED display as output
pinMode(d1, OUTPUT);
pinMode(d2, OUTPUT);
pinMode(d3, OUTPUT);
pinMode(d4, OUTPUT);
pinMode(a, OUTPUT);
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
pinMode(p, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
Timer1.initialize(100000); // set a timer of length 100000 microseconds (or 0.1 sec - or 10Hz => the led will blink 5 times, 5 cycles of on-and-off, per second)
//Timer1.attachInterrupt( add ); // attach the service routine here
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
Serial.println(88);
else{
SOC();
void SOC()
for(int l = 0; l<100;++l){
clearLEDs();//clear the 7-segment display screen
pickDigit(0);//Light up 7-segment display d1
S();// State
delay(del);//delay 5ms
pickDigit(1);//Light up 7-segment display d2
O();// of
pickDigit(2);//Light up 7-segment display d3
C();//Charge
clearLEDs();
for (int l = 0; l<500;++l){
// clearLEDs();//clear the 7-segment display screen
// pickDigit(0);//Light up 7-segment display d1
// pickNumber((n/1000));// get the value of thousand
// delay(del);//delay 5ms
// pickDigit(1);//Light up 7-segment display d2
// pickNumber((n%1000)/100);// get the value of hundred
pickDigit(0);//Light up 7-segment display d3
pickNumber(n%100/10);//get the value of ten
pickDigit(1);//Light up 7-segment display d4
pickNumber(n%10);//Get the value of single digit
// pickDigit(3);//Light up 7-segment display d3
// P();//Charge
clearLEDs();
delay(250);
void pickDigit(int x) //light up a 7-segment display
//The 7-segment LED display is a common-cathode one. So also use digitalWrite to set d1 as high and the LED will go out
digitalWrite(d1, HIGH);
digitalWrite(d2, HIGH);
digitalWrite(d3, HIGH);
digitalWrite(d4, HIGH);
switch(x)
case 0:
digitalWrite(d1, LOW);//Light d1 up
case 1:
digitalWrite(d2, LOW); //Light d2 up
case 2:
digitalWrite(d3, LOW); //Light d3 up
default:
digitalWrite(d4, LOW); //Light d4 up
//The function is to control the 7-segment LED display to display numbers. Here x is the number to be displayed. It is an integer from 0 to 9
void pickNumber(int x)
switch(x)
default:
zero();
case 1:
one();
case 2:
two();
case 3:
three();
case 4:
four();
case 5:
five();
case 6:
six();
case 7:
seven();
case 8:
eight();
case 9:
nine();
void clearLEDs() //clear the 7-segment display screen
digitalWrite(a, LOW);
digitalWrite(b, LOW);
digitalWrite(c, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
digitalWrite(g, LOW);
digitalWrite(p, LOW);
void zero() //the 7-segment led display 0
digitalWrite(a, HIGH);
digitalWrite(b, HIGH);
digitalWrite(c, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
void one() //the 7-segment led display 1
void two() //the 7-segment led display 2
digitalWrite(g, HIGH);
void three() //the 7-segment led display 3
void four() //the 7-segment led display 4
void five() //the 7-segment led display 5
void six() //the 7-segment led display 6
void seven() //the 7-segment led display 7
void eight() //the 7-segment led display 8
void nine() //the 7-segment led display 9
void L(){
void S(){
void O(){
void C(){
void P(){
// void add()
// // Toggle LED
// count ++;
// if(count == 10)
// count = 0;
// n++;
// if(n == 10000)
// n = 0;
So I know why my button isn't doing what I need, because there is a call to a looping function inside the main loop and whilst it is doing that it isn't checking my button state, I verified the button is working and it enters that routine when I hold it down, I just want to know what changes I need to make to be able to constantly check the button state or when it is pressed in to save that information and to run the routine the next time it returns to the main loop, ideally staying in that state until the button is pressed again but first I just want it to change when I press.
It's just a basic tactile switch (unsure part number) I am using a Mega 2560 Board and I have a 5641 as 4 digit display.
