Millis over run, how to stop Millis after successful run
Hi Folks
getting there but now i have run into a timer loop.
first run works fine and code compiles ok.
but last three segments call a IF function that already true due to the prior run.
would like to know where to look or how to reset or stop at end of successful run
Thanks in anticipation
Gate 1.2
   Made to run on Arduino uno clone
   this code is to run linear actuators with out position sensors
   but have inbuild stop switches in actuators
   to be used as auto gate openers
   useing 2 H bridge units to drive
   delay time is to allow sufficent run time to open or close gates
   overrun is not a concern as actuators stop at limits
unsigned long Traffic;    // traffic timer
unsigned long CloseGate;  //Start time of timer
unsigned long StartHold;  //Start time of timer
unsigned long Current_Time; // as states
const unsigned long GateRun = 10000; //reStart gates
const unsigned long GateHold = 20000; //Pause timer for traffic
const unsigned long RunTime = 20000; //run timer for gate motion
int pedestrian = 3;   //open small gate only
int OpenGates = 4;    // open both gates
int stopfeedA = 5;    // sensor eye A to digital pin 5
int stopfeedB = 6;    // sensor eye B to digital pin 6
int OpenGate2 = 7;    // open gate to motor2 digital pin 7
int OpenGate1 = 8;    // open gate to motor1 on digital pin 8
int CloseGate1 = 9;   // close gate to motor1 on digital pin 9
int CloseGate2 = 10;  // close gate to motor2 on digital pin 10
int end = 0;
  pinMode(OpenGate2, OUTPUT);        // open gate 2
  pinMode(OpenGate1, OUTPUT);        // open gate 1
  pinMode(CloseGate1, OUTPUT);       // Close Gate 1
  pinMode(CloseGate2, OUTPUT);       // Close Gate 2
  pinMode(stopfeedB, INPUT_PULLUP);    // EMERGENCY STOP GATES
  pinMode(stopfeedA, INPUT_PULLUP);    // EMERGENCY STOP GATES
  pinMode(OpenGates, INPUT_PULLUP);    // OPEN GATES
  Current_Time = millis();  //get the current "time"
  //   ////////////////THIS SECTION TO RUN MAIN GATES//////////////////////
  if (digitalRead(OpenGates) == LOW)
    // Open Gates
    digitalWrite(OpenGate1, HIGH);
    digitalWrite(OpenGate2, HIGH);
    // Gate close timer
    StartHold = millis();
    Serial.println("GateRun started and gates opening");
  // test whether the period has elapsed
  if (Current_Time - StartHold >= GateRun)
    Serial.println("timer already finished gate run stop");
    // shutdown gates
    digitalWrite(OpenGate1, LOW);
    digitalWrite(OpenGate2, LOW);
    // Gate traffic timer
    Traffic = millis();
  // /////// This section is to reclose Gates after being opened //////
  if (Current_Time - Traffic >= GateHold)
    Serial.println("Traffic Delay already finished.Gates Closing now");
    // close gates
    digitalWrite(CloseGate1, HIGH);
    digitalWrite(CloseGate2, HIGH);
    // Gate hold timer = millis();
    CloseGate = millis();
  if (Current_Time - CloseGate >= GateRun)
    Serial.println("Gates Shut down ready for re run");
    // shut down gates
    digitalWrite(CloseGate1, LOW);
    digitalWrite(CloseGate2, LOW);
  // /////////  THIS SECTION IS EMERGENCY STOP ///////////////
  if (digitalRead(stopfeedB) == LOW)
    Serial.println("Emergency stop B pressed stops gates");
  if (digitalRead(stopfeedA) == LOW)
    Serial.println("Emergency stop A pressed stops gates");
  Serial.println("end script and rerun");
Use a boolean variable and test it before taking action. If it is false then don't take the actions. Set it to true when you want the actions to occur.
74younus:
Hi I have successfully controlled the Millis() function now. Someone here had posted a code for LEDs and servo for run under millis and I made major alterations to that code and that worked for me. I want to thank him. :slight_smile:
Do you think that person will randomly encounter this message, which resurrects a year old thread that has very little to do with your post? Please just PM them, and start your own thread topics. The first one belongs in the "Project Guidance" forum, not here.
