I recently hacked a mindflex headset, following a tutorial online. I turned it into a cheap EEG headset. I used the brain for the Arduino. Then i used Processing to read m my brain waves. Everything went well at first. The serial monitor showed the codes, I had "0," in front of the numbers and it also showed my brain waves in Processing's braingrapher.
I tried to use my hacked Mindflex headset to play the mindflex game, it didn't want to connect.
And now when I run the code on Arduino the Serial Monitor doesn't show anything it's just blank.
please help if you know how to fix this problem
