Mini Motor Driver with nrf24l01 socket.
I made a little motor driver /servo controller with a nrf24l01 socket for small dc motors.
Can handle a 1.5 - 2 amps.
It about the size of an arduino pro mini and meant for little coreless motors for boats cars mini helicopters and indoor planes or whatever you want.
If you have a nrf24l01 it is a complete rc unit.
Otherwise the socket is used to burn the bootloader and then can be used for other things.
I made mine with an atmega8 but any 88/168/328 will work. (I don't recommend using the atmega8 as it does not have hardware pwm on the pins connected to the driver).
Note: the Atmega is running at 8Mhz as the voltage regulator is a 3.3 volt. This is so the nrf24 module can be powered from the same source.
If you don't use a Nrf24 radio then you can use a 5 volt regulator and run at 16mhz. You can also use the internal oscilator and put a pin header in where the xtal would be.
(thats why its a big through hole part)
Will work between 3.5 and 9 volts depending on parts and setup. The servo is powered right from the raw input voltage so should not exceed 6 volts if you want to power the servo through the board.
I will post the gerber files here in case anyone wants to give it a go, I make up stuff like this to fill up board space when I order pcbs and have room left over.
Here's the drawbacks...
This is a circuit designed to be as small as possible.. there is no reverse circuit protection. I use polarized rc plugs on all my things.. There is also nothing to stop you from turning on both sides
of the bridge in your sketch and blowing the bridge I haven't done it yet but you must keep this in mind.
My schematics are terrible. I use diptrace and it makes ugly schematics and mine are the worst. If anyone wants to make a more legible schematic that would be awesome!
I'll put up the diptrace schematic too.
So if there is interest I will keep posting what i can.
I didn't know where to post it, Its not good enough to be a finished project but it works well for small motors, haven't tested it to breaking point yet.
I am having fun with it so i figured I would share.
Here are a couple videos of it in action.
It can be made for about $2 with ebay bits! Canadian!
Parts List
Atmega8 /88/168/328
sot-223 voltage regualtor LDO
2 each AO3402/3401 mosfets and 2 MMBT2222A transistors
bunch of small 805 resistors ( see picture.. you don't have to be exact).
2 10 uf caps
1 0.1 uf caps
smd 0805 LED
1 220 uf cap.
I'll put up my simple sketch that I use to control it when I get it cleaned up. Otherwise just remember DO NOT TURN PINS 5 and 6 HIGH AT THE SAME TIME.
I'll try and keep this updated.. any suggestions and improvements are greatly appreciated.
Cheers
Alka
schematicDiptrace.zip (17 KB)
sot23allinone.zip (9.2 KB)
Nice videos
Can you make a pdf-file from your schematic? Now the diptrace is needed and I don't want install it now. I have another.
What libraries you use with the NRF24L? I would like use that chip but there are too many libraries.
I am using TMrh20 library for the nrf24l01.
I am not at home now but I will try make a pdf later , the problem is my schematic is hard to read. Opening it with diptrace ( its free for under 300 pins) allows you to follow the connections a little more easily. Also I am terrible at laying out schematics that look nice.
I did a second version of this board that is for controlling 4 motors (single direction), with the nrf24l01 socket and a socket for a 6050 gyro/accelerometer. its a little smaller than this one and can be used in theory for a small quad ( although I never wrote code for this). I'll try and get that up here too ( I would love to see someone smarter than I use it for a little quadcopter).
