Mini Pro + RFM12 + JeeLabs -> How to configure SPI/JeeLibs.org
I am no sure about how to configure the JeeLab to work with the Arduino Mini Pro and, I have no communication with the default sonfiguration. I have the following building parts
  • 2 pieces of Arduino Mini Pro (3.3V)
  • 2 pieces og HopeRF RFM12b (v1.0) 433 MHz
  • JeeLabs liberary (Example RF12stream uploaded to both Arduino's)
The two RFM12b is connected to the two Arduino Mini Pro as follows:
Arduino Mini Pro PIN <------> RFM12b PIN
GND <------> GND
VCC <------> VDD
13 <------> SCK
12 <------> SDO
11 <------> SDI
10 <------> nSEL
I have connected a 175 mm Antenna to the ANT on both RFM12b's and the distance between them i roughly 20 cm. The RF12stream program example is installed on both Ardurino Mini Pro's and, I have connected a oscilloscope the the GND and the SCK PIN's on the RFM12b, but I don't ses any SCK signals when running the program. I see some signals on the other PINs, but expected to see the SCK ! Because of this, I guess, that I need to configure the JeeLabs.org lib. ?
Could someone pleas advise me what to do ?
Never used JeeLab so not sure if you need to configure to suit a pro mini but this schematic shows the SCK, MISO & MOSI to be on different pins to the connections you show.
Thanks for your input but, compared to the diagram you linked to, my Arduino Mini Pro has an other PIN numbering but, I have connected it the same way.
Remark: I have executed other programs without any problem.
Do you have other suggestion instead of using JeeLibs.org ?
IMPORTANT: When running the program RF12Demo from JeeLibs, I can communicate with the RFM12b and store the node ID and communicate with the RFM12b. I see that the SCK is only turned on, when the Mini Pro and RFM12b communicates and, then the SCK is turned off again.
Now I just want to find out, if it is possible to measure the RF signal on the RFM12b antenna ? Just to verify that a signal is transmitted. My scope is going down to 5 ns/40MHz/2mV.
Other suggesions to a simple test of the communication between the two RFM12b's :slight_smile:
japping:
Can you supply more details/links to the Arduino mini pro your using. Maybe the mini pro and the pro mini are different things.
I haven't been precisely enougt when posting this - sory. I am using two Mini Arduino Pro from www.sparkfun.com. I hope this is information enough ?
japping:
Do you mean this?
Yes
Did you also connect arduino D2 to the IRQ pin on the RFM12 as shown here
No, I have not connected the RFM12b PIN IRQ to the Mini Arduino Pro. But I will look into it and try to find out what the function of this PIN is.
Thanks a lot for this input
japping:
I think the pin is used by the RFM12B to tell the Arduino that RX data has arrived and needs dealing with.
Status:
I think that the two Mini Arduino Pro with RFM12b is running now, but I am not sure how to test it. I have a PC with serial interface connected to one of the Arduinos and the other Arduino+RFM12b is running om battery. I have uploaded the JeeLabs example RF12Demo. When I send the serial message "4,10 a" I get this back:
----------START -------
10a
-> 1 b
? 27 143 188 239 239 10 71 10 82 210 76 177 61 142 40 62 255 55 143 255 76
? 159 154 27 190 55 134 246 27 255 111 239 154 45 160 60 237 75 201 71 144 63
? 142 202 173 197 247 69 102 194 168 173 30 237 226 219 44 204 132 195 254 19 199
? 155 136 240 63 13 2 23 236 86 10 110 150 57 90 19 246 159 19 213 167 223
? 146 127 252 180 108 9 174 236 87 139 194 200 244 189 56 250 231 230 16 243 204
? 44 64 0 0 0 0 0 0 0 0 127 198 180 251 213 24 0 0 1 252 252
? 19 123 188 64 6 210 127 138 191 92 192 66 132 157 207 95 226 51 223 60 196
? 33 7 113 224 255 45 93 241 172 109 177 68 215 173 206 121 87 252 220 79 251
? 44 157 111 247 87 87 5 237 251 2 27 82 45 124 208 2 232 250 54 93 164
? 190 69 214 116 118 7 189 62 186 191 223 13 251 181 192 11 45 93 222 134 220
? 13 8 66 219 241 242 183 150 65 221 57 117 172 61 139 124 201
? 190 29 47 2 173 223 125 215 192 94 125 129 254 33 23 197 222 80 209 26 252
? 49 72 5 192 31 95 200 208 154 58 175 11 79 215 139 83 162 26 113 171 137
----------END ----------
and it continues sending these lines of numbers.
Anyone who know what this means ?
Any suggestions to a program that can verify my setup with only one serial connection to one of the arduino's. It could be a program that continously send RFM12b RF messages to the other RFM12b.
All suggestions is welcome - thanks in advance.
I found the following detailed guide for RF12Demo and it is very usefull: jeelib/examples/RF12/RF12demo at master · jeelabs/jeelib · GitHub
Unfortunately I don't get the "OK" described at point no. 9 :frowning:
I will look further on my electrical connections.
I just found out, that the question mark followed by numbers send to the serial port on the PC is a crc error message.
I don't know why, but I will try to find out ! suggestions are welcome.
I never got the jeelib library and examples to work properly. You might take a look at the low power labs RFM12 stuff.
http://lowpowerlab.com/
Thanks for the suggestion, if I don't get the JeeLabs up running within the next few days, then I will try the GitHub/LowPowerLab.
"Next few days" -DUH. Once I gave up on jeelib and found out about lowpower labs, it took about 5 minutes to get the basic Send and Receive examples to work. Just try it and see.
Hi oric_dan and Riva !
First of all I am glad to tell you, that the RFM12b communication between the two Mini Arduino Pro's are working now :slight_smile:
What I found out this morning was, that the battery on the standalone Arduino just delivered 2.85V and not 3.3V. I then connected a 4.5V powersupply and the RF12Demo command "0a" gave me the answer "OK 194" :slight_smile:
Discussion summery:
Riva corrected the missing IRQ wire between the Arduino and the RFM12b and, oric_dan pointed out that there is an alternative to JeelLabs called GitHub/LowPowerLab.
Thanks a lot for all you help, now it is possible for me to work further on with my weather station.
Glad you got it working in the end.
