Minima "Error : status 74" Ubuntu 22.04 LTS
Hi, my name luigi from italy my problem upload sketch from ubuntu 22.04 LTS 64bit PRO
Error message:
Lo sketch usa 53600 byte (20%) dello spazio disponibile per i programmi. Il massimo è 262144 byte.
Le variabili globali usano 4552 byte (13%) di memoria dinamica, lasciando altri 28216 byte liberi per le variabili locali. Il massimo è 32768 byte.
dfu-util 0.11-arduino4
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Opening DFU capable USB device...
Device ID 2341:0069
Run-Time device DFU version 0101
Claiming USB DFU (Run-Time) Interface...
Setting Alternate Interface zero...
Determining device status...
DFU state(0) = appIDLE, status(0) = No error condition is present
Device really in Run-Time Mode, send DFU detach request...
Device will detach and reattach...
dfu-util: Lost device after RESET?
Caricamento non riuscito: errore durante il caricamento: exit status 74
My install fixed: https://github.com/arduino/ArduinoCore-mbed/blob/main/post_install.sh
Not working.
In short, it takes one out of 3 and the r4 card does not remain selected.
Ubuntu 22.04.3 LTS 64 bit. Version Pro License.
Install correctly the latest IDE 2 following Download and install Arduino IDE, add the boards Package Core and then double tap the reset button fast and check the status of the onboard "L" LED. If the onboard LED fade in and out slowly (pulsating), upload an example sketch ( like Blink LED) from the IDE to the board.
You might take a look at:
Fix udev rules on Linux – Arduino Help Center
It mentions this error code and shows you way to fix the udev rules.
ok, my reinstalled ubuntu from all applications . using arduino-ide.appimage
using udev:
installed .. working ok.
thanks.
