Misleading port offered
Misleading port sometimes being offered when uploading. I'm using IDE 2.3.8.
It was on COM6 when programming with another Uno earlier. No other ports are connected. For uploads I instinctively first used the option for the current cable connection.
When you see what you describe in the IDE what does the OS show as available COM ports ?
I'll have to check the next time it happens.
Right now, restarting IDE 2.3.8 and repeating the exercise, Tools > Port is correctly showing only COM3 (and COM1). Device Mgr is showing:
Communications Port (COM1)
USB-SERIAL CH340 (COM3)
I had similar problems yesterday, but more serious, in that 'COM6 persisted after restarting IDE and PC, and other 'impossible' states.
