Let me say a Monitor has to be an extra Window, cause it is a Monitor
The best will be when you program an extra window looking like a monitor for:
(see Picture from an Arduino Project as monitor example:
Serail monitor with its known settings and eg. a send button instead of a [command +Enter] here both Button for Mouse and Screen Users
and [command +Enter] for the programmers.
2.
Serial Plotter with its known functions.
The old one was nearly perfect. Only missing zoom in and out eg. with a
magnifying glass.
Will be fine when you can support this well-known and proven technology again or even better!
THX!
Hi @michaeljohannes . Thanks for taking the time to try the beta phase Arduino IDE 2.x and providing your valuable feedback!
This is being tracked by the IDE developers here:
opened 07:48PM - 29 Mar 21 UTC
type: enhancement
topic: code
topic: serial monitor
### Describe the request
Allow **Serial Monitor** to be placed in a dedicated… window separate from the primary Arduino IDE window.
🙂 It will be possible for the user to control the display location of the Serial Monitor separately from the primary Arduino IDE window according to their needs and preferences.
🙂 This will provide feature parity with the Arduino IDE 1.x Serial Monitor.
### Describe the current behavior
Serial Monitor is a view in the bottom panel of the primary Arduino IDE window.
🙁 It is not possible to move Serial Monitor to a separate screen in order to dedicate all space on the primary screen to the Arduino IDE editor.
### Arduino IDE version
#### Original report
2.0.0-beta.4
#### Last verified with
2.0.1-snapshot-32d904c
### Operating system
All
### Operating system version
Any
### Additional context
The requested "tear off" capability would probably make sense for other windows ("**Output**" view) too.
<a name="workaround"></a>
#### Workaround
1. Select **File > New Sketch** from the Arduino IDE menus.
A new Arduino IDE window will open.
1. Select **Tools > Serial Monitor** from the Arduino IDE menus.
The "**Serial Monitor**" view will open in the bottom panel of the Arduino IDE window.
1. Hover the mouse pointer over the top border of the bottom panel.
The mouse pointer will change into a resize icon.
1. Click and drag the border up until it reaches its maximum height.
You can now use that Arduino IDE window solely for Serial Monitor, switching back to the other Arduino IDE window to do sketch editing, compile, upload, etc. operations just as you would do with the Arduino IDE 1.x Serial Monitor.
#### Additional requests
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-810073157
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-813597014
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-850550857
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-983961342
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1006024396
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1034829176
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1068087883
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1195300991
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1247730828
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1247930105
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1257039691
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1382677544
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1399304977
- https://github.com/arduino/arduino-ide/issues/289#issuecomment-1399421191
- https://github.com/arduino/arduino-ide/issues/1799
- https://github.com/arduino/arduino-ide/issues/1268
- https://github.com/arduino/arduino-ide/issues/755
- https://github.com/arduino/arduino-ide/issues/2131
- https://forum.arduino.cc/t/making-the-serial-console-a-dockable-screen-again/1079586
- https://forum.arduino.cc/t/ide-2-0-3-undocking-serial-monitor/1063170
- https://forum.arduino.cc/t/arduino-ide-usb-serial-terminal-issues/1049458/13
- https://forum.arduino.cc/t/how-to-get-all-my-1-18-19-libraries-installed-in-2-0-1/1050248/3
- https://forum.arduino.cc/t/serialmonitor-74880-baud-rate-in-ide-2-0-1/1046886
- https://forum.arduino.cc/t/windows-the-serial-monitor-window-needs-to-pop-out-please/1036538
- https://forum.arduino.cc/t/using-v-2-0-serial-monitor-print/1034093
- https://forum.arduino.cc/t/arduino-2-0-0-macos-unexpected-differences/1033549
- https://forum.arduino.cc/t/2-0-keyboard-shortcuts-dont-work/1033105/11
- https://forum.arduino.cc/t/arduino-ide-2-0-0-available-for-download/1031651/17
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/1
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/3
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/4
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/15
- https://forum.arduino.cc/t/changing-ide-fonts/1028827
- https://forum.arduino.cc/t/serial-monitor-issues-hopefully-fixed-before-release/1026548
- https://forum.arduino.cc/t/serial-monitor-in-seperate-window/1022661/1
- https://forum.arduino.cc/t/serial-monitor-in-seperate-window/1022661/2
- https://forum.arduino.cc/t/serial-monitor-in-seperate-window/1022661/5
- https://forum.arduino.cc/t/automatic-build-external-screen-for-serial/1013958
- https://forum.arduino.cc/t/serial-monitor-with-new-ide/1010684/10
- https://forum.arduino.cc/t/ide-2-0-rc5-serial-monitor-problems/978293
- https://forum.arduino.cc/t/serial-monitor-characteristics-fail/943590
- https://forum.arduino.cc/t/how-to-dock-serial-monitor/942477
- https://forum.arduino.cc/t/how-to-dock-serial-monitor/942477/12
- https://forum.arduino.cc/t/no-support-for-esp32-boards-manager-2-01/940115/5
- https://forum.arduino.cc/t/first-impressions-and-comments/930873
- https://forum.arduino.cc/t/missing-serial-monitor-and-serial-plotter/924262
- https://forum.arduino.cc/t/arduino-2-0-has-too-many-problems/1100602
- https://forum.arduino.cc/t/arduino-2-0-has-too-many-problems/1100602/13
- https://forum.arduino.cc/t/missing-baud-rate-dropdown-v2-0-4-ide/1105972
- https://forum.arduino.cc/t/arduino-2-04-stuck-in-splash-screen/1107587/11
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/16
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/17
- https://forum.arduino.cc/t/serial-monitor-double-window-problem/1112463
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/18
- https://forum.arduino.cc/t/ide-2-1-i-am-not-happy/1142471
- https://forum.arduino.cc/t/ide-2-serial-monitor/1146303
- https://forum.arduino.cc/t/serial-monitor-in-a-separate-window/1031455/26
- https://forum.arduino.cc/t/i-miss-my-separate-serial-monitor-window/1163606
- https://forum.arduino.cc/t/cannot-upload-to-ftdi-megas-only/1170683
- https://forum.arduino.cc/t/your-reason-for-not-switching-to-the-2-x-ide/1176322
- https://forum.arduino.cc/t/your-reason-for-not-switching-to-the-2-x-ide/1176322/23
- https://www.facebook.com/official.arduino/posts/pfbid02x5KM54Gf7L56Tea79pLYVafrciYAGZrioedDVD6YFKEnJdsiNT3w6S2WinZtrAc9l?comment_id=1395510504579311
- https://www.facebook.com/official.arduino/posts/pfbid02qWaAtdLM6Hz43h7BRiYLg3yAoDz4HXRw28tLpgc4d1rszqG5gjbbumA21cLcS2Vcl?comment_id=996845494967736
- https://twitter.com/DevReliefFred/status/1696610597171773571
- https://twitter.com/PaulStoffregen/status/1658089036685410305
### Issue checklist
- [X] I searched for previous requests in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the feature was still missing when using the latest [nightly build](https://github.com/arduino/arduino-ide#nightly-builds)
- [X] My request contains all necessary details
This deficiency is being tracked by the Arduino IDE developers here:
opened 04:36PM - 01 May 21 UTC
topic: code
type: imperfection
### Describe the problem
There is no send button in the Serial Monitor.
##… # Describe the problem
1. Open the "**Serial Monitor**" view.
🐛 There is no "**Send**" button associated with the message field.
### Expected behavior
A "**Send**" button that can be clicked to send the message to the board:
nightly 20210501
4deaf4f
All
Any
#### Additional reports
- https://github.com/arduino/arduino-ide/issues/810#issuecomment-1030367754
- https://forum.arduino.cc/t/would-like-the-send-button-for-serial-monitor-on-the-new-ide/873159
- https://forum.arduino.cc/t/rc9-2-serial-monitor-send-button/1024938
- https://forum.arduino.cc/t/serial-monitor/698844/4
- https://forum.arduino.cc/t/arduino-ide-2-0-0-rc9-input-in-serial-monitor-is-not-working/1015720/4
- https://forum.arduino.cc/t/arduino-error-message-jan21/1080560/33
#### Workaround
Press the <kbd>**Enter**</kbd> key to send the message.
### Issue checklist
- [X] I searched for previous reports in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the problem still occurs when using the latest [nightly build](https://www.arduino.cc/en/software#nightly-builds)
- [X] My report contains all necessary details
Work is in progress on the Serial Plotter now:
arduino:main
← arduino:serial-plotter
opened 09:12AM - 05 Nov 21 UTC
Refactor the serial connection management and implement the Serial Plotter.
The latest test builds are available here if you would like to give it a try:
https://github.com/arduino/arduino-ide/actions/runs/1450699701#artifacts
or you can wait for the next Arduino IDE 2.x release, which will have the plotter.
Thanks for your feedback!
I see you are working on this thats fine!
system
Closed
May 11, 2022, 9:19am
4
