Hi -
I've been working on this for a few hours and can't seem to resolve it.
I can make the IDE start with a tiny splash screen and somewhat usable interface except for some of the dialog boxes that show information (ex: get board info will pop up, but can't read the font)
or
I can make a normal size splash screen by using DPI settings in Windows Preferences (Win 10) - but the UI is GIANT and unusable.
Researching shows that this should be adjustable by setting Editor font size and Interface scale.. but they do not seem to work.
I've also removed and reinstalled Java with no difference.
Can anyone suggest anything? I've seen this before with Java apps - but it usually all worked or nothing worked... This IDE is stuck in-between - some stuff is the right size or the other stuff is.. not all of it at the same time.
Thanks
Is the only thing that doesn't scale the Board Info dialog? Or does the same problem occur with other dialogs (e.g. File > Open, File > Preferences, Edit > Find, Sketch > Include Library > Manage Libraries, and Tools > Board > Boards Manager)?
bperkins011:
I think the IDE is using its own version maybe..?
That's correct. They decided to start doing that because it was too difficult trying to support all the various versions people might have installed on their computers.
Thanks for the reply - I just tried all of the other dialogs you listed and they are readable.
For now - it looks like it is the 'get board info' dialog that is messed up in terms of readability.
The startup splash screen is also teeny (if that helps locate the code in question) but obviously doesn't matter.
I went through all of the permutations of setting DPI compatibility mode in windows (arduino.exe -> properties -> change high DPI settings) but they don't help really. I can make the user interface GIANT if I let the system handle scaling.
One last symptom - the 'interface scale' preference inside the IDE seems to have zero effect on the scale of the interface.
I'm betting if that setting worked - I could use it in conjunction with the windows setting and get everything to balance out.
My laptop has the high res screen where I'm having the issues.
My desktop is 1920x1080 and everything works great on that.
Hopefully this is useful for the IDE developers.
Thanks!
