Hello,
I work with MKR board and would like to bring them in deep sleep until an external interrupted triggered. If multiple interrupts came within 2 seconds I would like ignore them.
The following code only works without deepSleep.
Is there anything I have to handle additional?
#include <ArduinoLowPower.h>
#define PIN_SENSOR_IN 0
volatile boolean trigger = false;
pinMode(PIN_SENSOR_IN, INPUT_PULLUP);
LowPower.attachInterruptWakeup(PIN_SENSOR_IN, pulseSensorTriggered, FALLING);
if(trigger){
//do something
trigger = false;
LowPower.deepSleep(); //without is works
void pulseSensorTriggered(){
static unsigned long last_interrupt_time = 0; // put this already as global because of longer time
unsigned long interrupt_time = millis();
if ( interrupt_time - last_interrupt_time > 2000 ) { //should trigger not within 2 seconds
trigger = true;
last_interrupt_time = interrupt_time;
hope you understand my problem and have some inputs for me
