MKR IoT Carrier - Not Working
Hello, I bought a MKR IoT Carrier last December 2022, and a month later it arrived.
We uploaded a sketch for humidity, temperature, light, and weather station. The web editor successfully verified and uploaded the code on the MKR WIFI 1010. The problem is the IoT Carrier doesn't respond, the LCD doesn't light up and the sensors doesn't send readings.
Here is the code:
// BSEC Software Library - Version: 1.6.1480
#include <bsec.h>
  Sketch generated by the Arduino IoT Cloud Thing "Untitled"
  https://create.arduino.cc/cloud/things/3cd71424-ed50-407c-affe-783e581eee97
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  String weather_report;
  float humidity;
  float temperature;
  int light;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
int modeSelect = 0;
int previousMode = 0;
int refreshCount = 0;
  // Initialize serial and wait for port to open:
  //while (!Serial);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  //Get Cloud Info/errors , 0 (only errors) up to 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  //Wait to get cloud connection to init the carrier
  while (ArduinoCloud.connected() != 1) {
    ArduinoCloud.update();
  CARRIER_CASE = false;
  carrier.begin();
  carrier.display.setRotation(0);
  carrier.display.fillScreen(ST77XX_BLACK);
  carrier.display.setTextColor(ST77XX_WHITE);
  carrier.display.setTextSize(3);
  carrier.display.setCursor(60, 80);
  carrier.display.print("Aether");
  //carrier.display.setCursor(60, 120);
  //carrier.display.print("Station");
  delay(2000);
  carrier.display.setTextSize(2);
  carrier.display.setCursor(70, 80);
  carrier.display.print("Connected");
  carrier.display.setCursor(50, 110);
  carrier.display.print("To IoT Cloud");
  delay(2000);
  carrier.Buttons.update();
  while (!carrier.Light.colorAvailable()) {
    delay(5);
  int none;
  carrier.Light.readColor(none, none, none, light);
  temperature = carrier.Env.readTemperature();
  humidity = carrier.Env.readHumidity();
  if (carrier.Button0.onTouchDown()) {
    modeSelect = 0;
  } else if (carrier.Button1.onTouchDown()) {
    modeSelect = 1;
  } else if (carrier.Button2.onTouchDown()) {
    modeSelect = 2;
  } else if (carrier.Button3.onTouchDown()) {
    modeSelect = 3;
  if (modeSelect != previousMode) {
    updateDisplay();
    previousMode = modeSelect;
    refreshCount = 0;
  } else if (refreshCount >= 50) {
    updateDisplay();
    refreshCount = 0;
  if (humidity >= 60 && temperature >= 15) {
    weather_report = "It is very humid outside";
  } else if (temperature >= 25 && light >= 700) {
    weather_report = "Hot and sunny outside";
  } else if (light <= 100) {
    weather_report = "It is dark outside";
  } else if (temperature >= 15 && light >= 700) {
    weather_report = "Warm and sunny outside";
  } else if (temperature <= 16 && light >= 700) {
    weather_report = "A little cold, but sunny outside";
  } else if (humidity >= 90 && temperature <= 15) {
    weather_report = "It is wet and rainy outside";
  refreshCount++;
void updateDisplay() {
  if (modeSelect == 0) {
    carrier.display.fillScreen(ST77XX_RED);
    carrier.display.setTextSize(4);
    carrier.display.setCursor(70, 50);
    carrier.display.print("Temp:");
    carrier.display.setCursor(40, 110);
    carrier.display.print(temperature);
    carrier.display.print(" C");
  } else if (modeSelect == 1) {
    carrier.display.fillScreen(ST77XX_BLUE);
    carrier.display.print("Humi:");
    carrier.display.print(humidity);
    carrier.display.print(" %");
  } else if (modeSelect == 2) {
    carrier.display.fillScreen(ST77XX_GREEN);
    carrier.display.setTextColor(ST77XX_BLACK);
    carrier.display.setCursor(60, 60);
    carrier.display.print("Light:");
    carrier.display.setCursor(80, 120);
    carrier.display.print(light);
  else {
Is it a hardware or software anomaly? Thank you for the feedback. I need to submit this project by next week.
Hi @dophinder. Did you forget to add the code? I will be happy to take a look and try it out on my MKR IoT Carrier if you will provide the code.
Alternatively, if you downloaded it from somewhere or followed a tutorial, you can provide the link to where you obtained it from.
#include <bsec.h>
  float humidity;
  float temperature;
  int light;
int modeSelect = 0;
  //while (!Serial);
  initProperties();
  carrier.begin();
  delay(2000);
  delay(2000);
    delay(5);
  int none;
    modeSelect = 0;
    modeSelect = 1;
    modeSelect = 2;
    modeSelect = 3;
    updateDisplay();
    refreshCount = 0;
    updateDisplay();
    refreshCount = 0;
  refreshCount++;
  else {
Thank you, it will mean so much to me if you can help me. I'm a college student working on my design study.
I tried it out and it worked perfectly for me. So your code is fine.
Try this:
  1. Connect the MKR IoT Carrier to your computer with the USB cable.
  2. Open your Thing in Arduino IoT Cloud.
  3. Select the "Sketch" tab.
  4. Just to be sure you have the correct sketch on the Device, click the rightward pointing arrow button ("Verify and Upload") on the Sketch toolbar.
  5. Wait for the upload to finish successfully.
  6. Click the magnifying glass icon ("Open Serial Monitor") on the Sketch toolbar.
    A separate window will now open.
  7. Press the button marked "RST" on the MKR WiFi 1010 board that is plugged into the bottom of the MKR IoT Carrier.
    ⓘ This reset is done so you can see all the serial output from the very beginning of the sketch starting to run.
Now watch the Serial Monitor window. You should see some information about the board initializing, connecting to your WiFi router and to Arduino Cloud.
The successful output looks something like this:
***** Arduino IoT Cloud - configuration info *****
Device ID: 9ab0c2b0-374e-425f-bb68-30a96014ecfb
MQTT Broker: mqtts-sa.iot.arduino.cc:8883
WiFi.status(): 0
Current WiFi Firmware: 1.5.0
Connected to "my_ssid"
Sd card not detected
Connected to Arduino IoT Cloud
Thing ID: b56bfc49-3ca2-4f32-9548-8586be95a253
Some of the first lines might be missing because there is a bug in the Arduino Cloud Serial Monitor that makes it too slow to initialize, so even when you reset the board some of the first serial output is missing. You can fix that by adding a delay to the setup function of your Thing sketch:
  delay(2000);  // Give Arduino Cloud Serial Monitor time to initialize
Then upload the Thing sketch to your board again and check Serial Monitor to see all the output.
Hopefully the output shown in Serial Monitor will give you some information about the problem.
Thank you, the serial monitor shows the sensor data but it doesn't show on the IoT Cloud dashboard
Are there any cases that the MKR WIFI 1010 might be the one faulty?
This is very unexpected. There is nothing in the sketch you shared that would print sensor data to Serial Monitor. Are you certain you uploaded this sketch to your board?:
We actually just tried a simple code, if it shows on the dashboard of the IoT Cloud, yet still doesn't show on the dashboard. But the serial monitors shows the data
  https://create.arduino.cc/cloud/things/6f159185-14f8-4a43-8c8a-922dfc437057
  float humidity;
  float temperature;
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  initProperties();
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  carrier.withCase();
  carrier.begin();
  // Your code here
  Serial.print("Temp: ");
  Serial.println(temperature);
  Serial.print("Humid: ");
  Serial.println(humidity);
Did the LCD on the IoT Carrier worked on yours? Have you had any issues with the sensitivity of the buttons?
Can I connect with you simultaneously maybe on Discord or other media? It would be much appreciated
How about if you open your Thing on Arduino IoT and then select the "Setup" tab; do you see the expected values for the variables there?:
Yes. It works perfectly when I run the first sketch you shared. Of course there will not be any activity in the LCD when running the simple sketch you just shared because that sketch does not have any code to output on the LCD.
The truth is that, although I own the MKR IoT Carrier, I haven't had the opportunity to work with it very often. So I can't speak authoritatively on the reliability of the button. But I can say that after quite a bit of use of the first sketch you shared over the last few days, I have not experienced any problems at all with the buttons.
Arduino has other people assigned to providing support on Discord so it would not be appropriate for me to connect with you on the platform that is outside the scope of my work, but they should definitely be able to help you out over there:
