Has anyone tried to communicate android and the MKR1000 with bluetooth? I've been trying with HC-05 and the same program for Arduino UNO, and I can´t. I´m using Tx and Rx ports (pins 13 and 14 of MKR1000) and no serial library.
I can´t find any information about it on Internet.
This thread is a year old, so you will probably never know, the argument about the library was probably as irrelevant as it was incoherent, and the absence of comment about code or procedure was unhelpful..
For starters the MKR1000 is a 3.3V device. I understand the HC-05, as typically used, can be unreliable running on 3.3v. Are you able to power it properly? How are you doing that?
You might find the following background notes useful.
