I connected my MKR1000'S power using a USB cable only. After a while, the charge light started blinking, any issues with this type of setup? It has been working for two days already but previously, I have the same setup, it failed a month later.
Hello killzone_kid,
Thank you for your reply. I am sorry. This is not what I am asking - I just want to connect its power through the USB port ONLY. I don't mind it is blinking but I do mind that it stops working when it sends my data to the ThingSpeak server.
Sorry, I should give more detailed info. My first MKR1000 - run from 8/13/2022 to 9/16/2022. I know it failed because it stop sending data (temp/humidity) to the Thingspeak server. This device was connected using USB power. Since this device is still under warranty, I received a new replacement. With this new replacement, I updated its firmware from v19.4.4 to v19.6.1 yesterday (9/22/2022). Here is the link - https://thingspeak.com/channels/1832269. It is working well so far. I just want to make sure it will continue to work going forward; that is why I want to know whether this type of power connection will cause any issues in the future.
Additional information on the fields in my Thingspeak server.
Field 4 Chart - counter. Its initial value is -525960 (a negative number here) which is the number of minutes in a year. Since I update my data every minute, I use the above number to count backward (counter = -525960; ++counter); by end of one year, the value should 0L. If my MKR 1000 device stops its updates, this counter will stop as well; this is a quick way to check whether my device is working or NOT :).
I hope this helps.
I have been experiencing a similarly maddening problem with a MKR WiFi 1010. This is an autonomous project, solar powered. The board wakes up once every half hour (via external timer) and connects to WiFi for a minute every day to send out telemetry. It has been randomly failing about once a month. When I open it up the board is frozen and the yellow CHRG LED is slowly blinking. There is no LiPo battery connected to the board, the system runs off a big 9V battery pack and the Arduino board is powered from a dedicated 5V regulator feeding the Vin pin. It is crazy because 999 times out of 1000 everything works OK, but it's the 1 in 1000 power-up cycles that fails.
