Hello, my code is for an MLX90614 sensor. I'm measuring the temperature and changing the emissivity setting for different surfaces. But sometimes, about 1 in 10 times, when I click to set the emissivity, the temperature read by the sensor is absurd—either in the hundreds or even negative. I'm having difficulty finding the problem because it happens randomly.
This is my code:
#include <Wire.h>
#include <Adafruit_MLX90614.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
#define i2c_Address 0x3c
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
const long interval = 1000;
const long interval_SET_E = 1000;
unsigned long lastDebounceTime = 0;
unsigned long dernierTemps = 0;
unsigned long dernierTemps_SET_E = 0;
const int delaiDebounce = 50;
int lastButtonState_CF = HIGH;
int compteur_temp = 0;
float object_temp_C;
float object_temp_c;
float object_temp_f;
int ambient_temp_c;
int ambient_temp_f;
const int BD_LASER = 2;
const int B_CF = 3;
const int B_E = 4;
const int DIODE_LASER = 12;
float pin_pot = A3;
int BD_State = 0;
float Valeur_E = 1;
double emissivity = 1;
double new_emissivity = 1;
double new_emissivity_2;
bool lastButtonState_BE = LOW;
bool etatMODE_BE = LOW;
enum Etat {
INITIALISATION,
ATTENTE,
AQUISITION,
SETE
Etat etatActuel = AQUISITION;
bool etatMODE_CF = LOW;
Wire.begin();
mlx.begin();
delay(250);
display.begin(i2c_Address, true);
mlx.writeEmissivity(1.0);
pinMode(DIODE_LASER, OUTPUT);
pinMode(BD_LASER, INPUT_PULLUP);
pinMode(B_CF, INPUT_PULLUP);
pinMode(B_E, INPUT_PULLUP);
display.clearDisplay();
display.setTextColor(SH110X_WHITE);
display.setTextSize(1);
display.setCursor(0, 20);
display.print("Thermometre 2.3");
display.display();
delay(2000);
void mesureIR() {
object_temp_c = mlx.readObjectTempC();
object_temp_f = mlx.readObjectTempF();
void affichage_c() {
display.setTextSize(2);
display.setCursor(28, 20);
display.print(object_temp_c);
display.print((char)247);
display.print("C");
display.setCursor(8, 55);
display.print("Temp Ambiante: ");
display.print(ambient_temp_c);
display.print("C");
display.setCursor(8, 0);
display.print("E:");
display.print(new_emissivity);
display.display();
// Serial.println(object_temp_c);
void affichage_f() {
display.print(object_temp_f);
display.print("F");
display.print(ambient_temp_f);
display.print("F");
display.display();
// Serial.println(object_temp_f);
void affichage_k() {
float object_temp_k = (object_temp_c + 273);
int ambient_temp_k = (ambient_temp_c + 273);
display.print(object_temp_k);
display.print("K");
display.print(ambient_temp_k);
display.print("K");
display.display();
// Serial.println(object_temp_k);
void affichage_set_e() {
display.print("C");
display.display();
void diode() {
digitalWrite(DIODE_LASER, true);
ambient_temp_c = mlx.readAmbientTempC();
ambient_temp_f = mlx.readAmbientTempF();
BD_State = digitalRead(BD_LASER);
bool BE_State = digitalRead(B_E);
bool B_CF_State = digitalRead(B_CF);
unsigned long tempsActuel = millis();
//------------------------------------------------------- etat bouton d'affichage CFK
if (B_CF_State == LOW && lastButtonState_CF == HIGH && (tempsActuel - dernierTemps > delaiDebounce)) {
compteur_temp++;
dernierTemps = tempsActuel;
lastButtonState_CF = B_CF_State;
// -------------------------------------------------------- etat bouton de mesure avec emissivité
if ((millis() - lastDebounceTime) > delaiDebounce) {
if (BE_State == LOW && lastButtonState_BE == HIGH) {
etatMODE_BE = !etatMODE_BE;
lastDebounceTime = millis();
lastButtonState_BE = BE_State;
switch (compteur_temp) {
case 0:
affichage_k();
if (etatMODE_BE == true) {
compteur_temp = 4;
case 1:
affichage_c();
compteur_temp = 4;
case 2:
affichage_f();
compteur_temp = 4;
case 3:
affichage_k();
compteur_temp = 0;
case 4:
affichage_set_e();
if (etatMODE_BE == false) {
compteur_temp = 1;
switch (etatActuel) {
case INITIALISATION:
digitalWrite(DIODE_LASER, false);
etatActuel = ATTENTE;
Serial.println("INTITIALISATION");
case ATTENTE:
if (BD_State == true) {
etatActuel = SETE;
case AQUISITION:
if (BD_State == false) {
mesureIR();
if (compteur_temp == 1) {
affichage_c();
} else if (compteur_temp == 2) {
affichage_f();
} else if (compteur_temp == 3) {
affichage_k();
diode();
case SETE:
int valeur_pot = analogRead(pin_pot);
new_emissivity = 0.09 + (float(valeur_pot) / 1023) * 0.9;
Serial.println(new_emissivity);
affichage_set_e();
if (etatMODE_BE == 0) {
mlx.writeEmissivity(new_emissivity);
Serial.print("Emissivité appliquée: ");
