I have some problems to read out the EEPROM of my MLX90614 DCI infrared sensor, which is connected via I2C to my Arduino Uno. So the problem is less the sensor, than my limited programing skills..
To set a new emissivity I need to change the values in two EEPROM cells of the MLX, 0x04 and 0x0F. However, I'm not familiar with the wire library and only wanted to read out the current values by using to following code:
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_MLX90614.h>
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
#define MLX90614_I2CADRESS 0x5A
//float emissivity = 0.95; //0xF332 in hex, which is the new value, but not used here
Wire.begin();
mlx.begin();
Wire.beginTransmission(MLX90614_I2CADRESS);
Wire.requestFrom(0x04, 2); //cell with the emissivity, factory default 1 (0xFFFF), 16bit long
while(Wire.available()) {
char c = Wire.read();
Serial.print(c);
Wire.endTransmission();
But it is not working. There is no error occuring when I upload the code on the Arduino, but there is nothing shown in the serial monitor.
I found something similar in the forum: Problem with Reading/Writing to the EEPROM of a MLX90614 - Sensors - Arduino Forum
Unfortunately, I cannot find the used i2cmaster library which is used there and more over I don't really know what the code is all about. I only want to read the content of the cells and write some new values to them. This shouldn't be that much code or am I wrong?
read16() and write16 should work for my purpose. uint8_t is the adress, as it is 8bit long and uint16_t for my desired value, right?
But I was irritated by the following: The Melexis datasheet says that 0x04 is the adress for the emissivity. In the Adafruit library it is: #define MLX90614_EMISS 0x24
So which one is it?
The correction can be applied after you make the measurement -- there is no need to update the sensor. For the record, you need to acquire both the ambient (chip) temperature Ta, and the object temperature Tom in Kelvin. The corrected object temperature Toc is given by the following expression in C, where eps is the actual surface emissivity:
It was not passible to test the adress, because the functions in the mlx90614 library I mentioned are private.. So there will be no way to use them right?
However, with your calculation I got very similar results (+- 0.1°C) to my previous, where I simply multiplied the measured value of the object temperature with the emissivity.
Thank you.
quite expensive formula, can be done substantial faster
Tom4 = Tom * Tom;
Tom4 = Tom4Tom4;
Ta4 = Ta * Ta;
ta4 = Ta4Ta4;
Toc = pow(((Tom4 -Ta4)/eps) + Ta4), 0.25);
the latter line can be optimized to Toc = sqrt(sqrt((((Tom4 - Ta4) / eps) + Ta4)));
optimization is good, but I don't understand why TomTom = Tom4 and Tom4Tom4 = Tom4 also? And the same with Ta.
What does the 4 mean? To the power of 4?
banff:
Thanks again
indeed, the 4 indicates to the power of 4.
More descriptive names are better however you got the idea. Maybe introduce Tom2 for tom squared but that would introduce an extra variable (probably the compiler would optimize it away). Would be easier to understand.
Apparently you now have to register with Melexis to read it.
However, I can't read it, but I'm registered. Whenever I copy your link, I'm forwarded to the page which asks for registration.
But if it is the PDF which explaines the change of emissivity from Melexis, I already got it.
The formula of emissivity: E=(TOnew^4-TAnew^4)/(TOreal^4-TAreal^4). Do you solve for TOnew or TOreal?
So which one is it?
Thanks and regards,
banff
Though the datasheet says that the address of emissivity value is 0x04, the command opcode for EEPROM starts with 001XXXXX. Hence the address which needs to be sent is 0x24 and not 0x04.
banff:
So which one is it?
Hello, I'll drop this here for anyone who has came to this post and have the same concern:
The EEPROM address, for emissivity in this case, is 0x04. But the SMBus command to write that EEPROM address is 0x04 (0x20 command for writting in EEPROM + 0x04 address for emissivity)
