Hello all,
I am trying to use the ir thermometer sensor “MLX90614”.
I Connected the sensor to the arduino and I am runnig this code;
#include <i2cmaster.h>
void setup(){
Serial.println("Setup...");
i2c_init(); //Initialise the i2c bus
PORTC = (1 << PORTC4) | (1 << PORTC5);//enable pullups
void loop(){
int dev = 0x5A<<1;
int data_low = 0;
int data_high = 0;
int pec = 0;
i2c_start_wait(dev+I2C_WRITE);
i2c_write(0x07);
// read
i2c_rep_start(dev+I2C_READ);
data_low = i2c_readAck(); //Read 1 byte and then send ack
data_high = i2c_readAck(); //Read 1 byte and then send ack
pec = i2c_readNak();
i2c_stop();
//This converts high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
double tempFactor = 0.02; // 0.02 degrees per LSB (measurement resolution of the MLX90614)
double tempData = 0x0000; // zero out the data
int frac; // data past the decimal point
// This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
tempData = (double)(((data_high & 0x007F) << 8) + data_low);
tempData = (tempData * tempFactor)-0.01;
float celcius = tempData - 273.15;
float fahrenheit = (celcius*1.8) + 32;
Serial.print("Celcius: ");
Serial.println(celcius);
Serial.print("Fahrenheit: ");
Serial.println(fahrenheit);
delay(1000); // wait a second before printing again
The code himself is running good, my problem is the measurements.
When I am putting my hand 5cm infront of the sensor I am geting result of 22±, but when I am taking my hand away(15-20cm) the result are changing,.
There is no distance limit. The sensor reports the average temperature of everything in its field of view, which is a cone of roughly 90 degrees. As almost always, if you have questions for how a device works, the data sheet is a fantastic resource!
Practically speaking, it averages its field of view.
Take your hot soldering iron and slowly move it into the field of view of the device-
and then get closer to it. It's averaging that hot iron and everything it sees as
the background, and outputting that as one number.
There are several different fields of view available- they seem to do it with lensing.
Ok guys, thank you for the information!
I found several exmaples for multiple sensros(codes), but I didnt found any circulate(the datasheet doesnt spesificate capasitor and resistors values. And he is workign in 3.3v). Does any one have an example ?
BTW, when I attach 2 sensors to the same pins( analog 4 and 5), the I2C scaner cant find anything.
Thank you
Of course two sensors will interfere with each other, until you have changed the device address of one.
Get one working first. http://bildr.org/2011/02/mlx90614-arduino/
And I did change the address. Now I have 0x5A and 0x57. But when I try to scan them all in the same time , the scan returns me black. When I scan them individualy they are working perfect.
