hello everyone'
i am using mlx 90614 along with 2 resistors on a breadboard.the connections are correct. i am running this code but it shows no reading on display monitor.
#include <Wire.h> // I2C library, required for MLX90614
#include <SparkFunMLX90614.h> // SparkFunMLX90614 Arduino library
IRTherm therm; // Create an IRTherm object to interact with throughout
const byte LED_PIN = 8; // Optional LED attached to pin 8 (active low)
Serial.begin(9600); // Initialize Serial to log output
therm.begin(); // Initialize thermal IR sensor
therm.setUnit(TEMP_F); // Set the library's units to Farenheit
// Alternatively, TEMP_F can be replaced with TEMP_C for Celsius or
// TEMP_K for Kelvin.
pinMode(LED_PIN, OUTPUT); // LED pin as output
setLED(LOW); // LED OFF
setLED(HIGH); //LED on
// Call therm.read() to read object and ambient temperatures from the sensor.
if (therm.read()) // On success, read() will return 1, on fail 0.
// Use the object() and ambient() functions to grab the object and ambient
// temperatures.
// They'll be floats, calculated out to the unit you set with setUnit().
Serial.print("Object: " + String(therm.object(), 2));
Serial.write('°'); // Degree Symbol
Serial.println("F");
Serial.print("Ambient: " + String(therm.ambient(), 2));
setLED(LOW);
void setLED(bool on)
if (on)
digitalWrite(LED_PIN, LOW);
digitalWrite(LED_PIN, HIGH);
