Please update to the newest version. There are new features and bug fixes in every newer version.
When using the ESP32, there is I2C_BUFFER_LENGTH in Wire.h
When using a basic Arduino board with ATmega microcontroller from the AVR family, there is BUFFER_LENGTH in Wire.h
The Sparkfun library is probably not compatible with every board. Can you fix that yourself ?
Perhaps you can put this in your sketch: #define I2C_BUFFER_LENGTH BUFFER_LENGTH before including the *.h files.
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
//I2C_BUFFER_LENGTH is defined in Wire.H
If none of the specified platform matches, the value is set to 32. So an undefined value shouldn't happen except you installed things not correctly. Did you install the *.h and *.cpp file correctly to the library folder?
Hello Koepel you make my day, that was it! Thank you
