Mobile Phone number from SD Card
Hi all, I'm trying to read a mobile phone number from as SD Card, then use that phone number as a variable but I'm really struggling to get it into a variable.
The number is stored in a file called phone.txt which I can read and that's all working.
I've been using this:
while(myFile.available())
Serial.write(myFile.read());
myFile.close();
and then something like phonenumber = myFile.read();
but it's not working!!
I've been searching for a couple of days and my searches are telling me that I need to read each number of the phone number into an array and then use that.
Please help me as it's driving me up the wall :slight_smile:
Many thanks in advance.
Cowpi3:
I bet if used "Serial.print(phonenumber)" After reading the phone number, you would have quickly debugged you program.
Paul
There was an almost identical problem recently in this Thread in which I suggested a solution.
...R
Robin2:
...R
Hi Robin,
Your example in that thread is exactly what I was looking for, however your example is the easiest that someone has put it - so thank you very much. I'll give it a trial asap and let you know how I get on.
Apologies for posting another thread, I didn't see yours!
