I want to establish Modbus RTU RS485 communication between PLC Schneider Electric TM241 (Master) and Arduino UNO (Slave). I used a MAX485 interface to make the connection. To get started I used the code I found at RS485 MODBUS Serial Communication using Arduino UNO as Slave
Since I don't use the LCD screen, I deleted this part of the code. I imported the libraries from Modbus-Master-Slave-for-Arduino/ModbusRtu.h at master · smarmengol/Modbus-Master-Slave-for-Arduino · GitHub. I created my own library named “My_Slave, renamed the .h and .cpp files the same. I also deleted some comments in the code, leaving everything else unchanged.
//RS-485 Modbus Slave (Arduino UNO)
//Circuit Digest
#include <My_Slave.h> //Library for using Modbus and Arduino
#include <Servo.h> //Library for using Servo Motor
#define led1 2 //Define as 2 led1
#define led2 5 //Define as 5 led2
Servo servo; //Initilize servo object for class Servo
Modbus bus; //Define Object bus for class modbus
uint16_t modbus_array[] = {0,0,0}; //Array initilized with three 0 values
delay(5000);
pinMode(led1,OUTPUT); //Led1 set as OUTPUT
pinMode(led2,OUTPUT); //Led2 set as OUTPUT
servo.attach(6); //Servo PWM pin 6
bus = Modbus(1,1,4); //Modbus slave ID as 1 and 1 connected via RS-485 and 4 connected to DE & RE pin of RS-485 Module
bus.begin(9600); //Modbus slave baudrate at 9600
bus.poll(modbus_array,sizeof(modbus_array)/sizeof(modbus_array[0])); //Used to receive or write value from Master
if (modbus_array[0] == 0) //Depends upon value in modubus_array[0] written by Master Modbus
digitalWrite(led1,LOW); //LED OFF if 0
digitalWrite(led1,HIGH); //LED ON if value other than 0
if (modbus_array[1] == 0) //Depends upon value in modbus_array[1] written by Master Modbus
digitalWrite(led2,LOW); //LED OFF if 0
digitalWrite(led2,HIGH); //LED ON if value other than 0
int pwm = modbus_array[2]; //Depends upon value in modbus_array[1] written by Master Modbus
servo.write(pwm); //Write Received value (0 to 180) from Modbus Master
delay(200);
The code is for writing data to the Arduino Uno, Function Code 16 "Write Multiple Registers". Everything works fine.
I myself would like to read data from the Arduino Uno (Slave), namely Function Code 03 (Read Holding Registers) and write individual pins, Function Code 05 (Write Single Coil). I can't find where in the program I should change the code to manage Function Code 03 and 05.
It would be most helpful if someone could just point me to the fix I need to put in the existing code, maybe in the .h and .cpp libraries as well, to handle the following
- Function code 03, Register 3059 or 0x0BF3, Length 2
- Function code 05, Register 10 or 0x0010, Length 3
Then I myself will further study what I have to change in the existing code for Functional Code changes.
Best regards
