MODBUS protocol Library
Dear all, I am looking For good MOdbus Library . I have Downloaded From 2-3 Website But They are not working fine. Can someone here suggest me best link to download
So provide links to the libraries you downloaded and provide information about what you don't like for each library or why you think that they don't work.
https://code.google.com/p/simple-modbus/ https://code.google.com/p/arduino-modbus-slave/ http://playground.arduino.cc/Code/ModbusMaster#.UzuM56LsG4E Here are library i downloaded
I wanted to impliment like this:
http://replicantfx.com/wp-content/uploads/2012/11/ModBusSlave_Ref.pdf
I have tried all above sites. Can some tell me or share me library and associated Example For mod bus protocol. That cab execute on Arduino UNO REV3;
I am using arduino v1.0.1
and also having MPIDE 023 windows 20140316 Version of IDE.
Let me know suitable library. If any one tried with library already share there the library in rar file
If you want to implement a ModBus slave, using a ModBus master software is probably not a good idea.
Get a more recent version, 1.0.5 is current.
You still didn't tell us what didn't fulfill your requirements in these two implementations. You also didn't specify what these requirements are.
AMPS-N: I wanted to impliment like this:
This project already includes software for the Arduino, although it's for a pre-1 version of the IDE, but the required changes are simple and small (described in the playground). This project uses Mach 3 on the PC. Do you own that software? If not, what other software do you plan to use on the PC?
@ pylon
I have an SCADA system . That support MODBUS protocol. It like centralized system where we can connect no of devices. Now i have 2 arduino Which acts as slave.I want to communicate between two over mod bus protocol.
  1. I want to circuit connection for Modbus prtocol for arduino.currently i am having This set up
    http://electronics.stackexchange.com/questions/49097/arduino-as-modbus-master-with-max485-doesnt-get-any-response
  2. I need simple example with library explaining modbus slave. Where i can assign slave id , slave address, function code etc, From Software i can read data. For testing i am using below software. I have already tested software with other modbus device . Since it mine first time to design Modbus slave I dont knoe how to do it in arduino.
You still didn’t tell us why the two mentioned implementations don’t work for you as you wrote earlier.
On the page you linked (http://replicantfx.com/wp-content/uploads/2012/11/ModBusSlave_Ref.pdf), there is another implementation of a ModBus slave. You also didn’t tell us why that didn’t work for you.
In that software mentioned above you can set the slave address and the available registers. You’ll have to define what a slave ID is as the ModBus I know doesn’t define such a term. is it the same as the address? If yes, why should you assign it twice? In most cases only the most primitive function codes are implemented in the existing Arduino code but you’re free to extend that functionality if you need more features.
Are you looking for Modbus over Serial or over Ethernet, I didn’t see this mentioned anywhere. If you want a Modbus/TCP slave then I have included the Mudbus library. I have an Arduino Mega 2560 with all of it’s pins mapped out with the exception of those required by the Ethernet shield. I have this sketch working with an industrial HMI for a home automation type system, it works quite well. Some of the pins have thermistors connected, I multiply by 10 so I can divide by 10 on the master and carry a decimal place. For diagnostics I made a holding register for the Slave’s free ram as well as two holding registers that hold the 32bit millis() value split into two 16 bit words. All of the other holding registers are just raw ADC values from analogRead(). If you’re using an UNO or any other Arduino with less pins then just remove the lines that map to pins you don’t have.
Hope this helps.
#include <SPI.h>
#include <Ethernet.h>
#include "Mudbus.h"
Mudbus Mb;
  //Setup networking
    uint8_t mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x51, 0x06 };
    IPAddress ip(10, 0, 0, 11);
    IPAddress gateway = ( 10, 0, 0, 53 );
    IPAddress subnet  = ( 255, 255, 255, 0 );
    Ethernet.begin(mac, ip, gateway, subnet);
    Mb.ConnectionTimeout = 100;
    pinMode(2, OUTPUT);
    pinMode(3, OUTPUT);
    pinMode(5, OUTPUT);
    pinMode(6, OUTPUT);
    // Read the current state of the pins before calling Run()
    // This allows you to read forced pin state changes
    // Any writes after connecting to the master are written after
    Mb.C[0] = digitalRead(0);
    Mb.C[1] = digitalRead(1);
    //Mb.C[2] = digitalRead(2);
    //Mb.C[3] = digitalRead(3);
    Mb.C[4] = false;
    //Mb.C[5] = digitalRead(5);
    //Mb.C[6] = digitalRead(6);
    Mb.C[7] = digitalRead(7);
    Mb.C[8] = digitalRead(8);
    Mb.C[9] = digitalRead(9);
    Mb.C[10] = false;
    Mb.C[11] = digitalRead(11);
    Mb.C[12] = digitalRead(12);
    Mb.C[13] = digitalRead(13);
    Mb.C[14] = digitalRead(14);
    Mb.C[15] = digitalRead(15);
    Mb.C[16] = digitalRead(16);
    Mb.C[17] = digitalRead(17);
    Mb.C[18] = digitalRead(18);
    Mb.C[19] = digitalRead(19);
    Mb.C[20] = digitalRead(20);
    Mb.C[21] = digitalRead(21);
    Mb.C[22] = digitalRead(22);
    Mb.C[23] = digitalRead(23);
    Mb.C[24] = digitalRead(24);
    Mb.C[25] = digitalRead(25);
    Mb.C[26] = digitalRead(26);
    Mb.C[27] = digitalRead(27);
    Mb.C[28] = digitalRead(28);
    Mb.C[29] = digitalRead(29);
    Mb.C[30] = digitalRead(30);
    Mb.C[31] = digitalRead(31);
    Mb.C[32] = digitalRead(32);
    Mb.C[33] = digitalRead(33);
    Mb.C[34] = digitalRead(34);
    Mb.C[35] = digitalRead(35);
    Mb.C[36] = digitalRead(36);
    Mb.C[37] = digitalRead(37);
    Mb.C[38] = digitalRead(38);
    Mb.C[39] = digitalRead(39);
    Mb.C[40] = digitalRead(40);
    Mb.C[41] = digitalRead(41);
    Mb.C[42] = digitalRead(42);
    Mb.C[43] = digitalRead(43);
    Mb.C[44] = digitalRead(44);
    Mb.C[45] = digitalRead(45);
    Mb.C[46] = digitalRead(46);
    Mb.C[47] = digitalRead(47);
    Mb.C[48] = digitalRead(48);
    Mb.C[49] = digitalRead(49);
    Mb.C[50] = false;
    Mb.C[51] = false;
    Mb.C[52] = false;
    Mb.C[53] = false;
    //Analog inputs 0-1023
    // Temperature readings using a 3k NTC thermistor
    Mb.R[0] = int(tempFromADC(analogRead(1)) * 10); //pin A0 to Mb.R[0]
    Mb.R[1] = int(tempFromADC(analogRead(2)) * 10);
    Mb.R[2] = int(tempFromADC(analogRead(2)) * 10);
    Mb.R[3] = analogRead(A3);
    Mb.R[4] = analogRead(A4);
    // Basic light measurement using a photoresistor
    Mb.R[5] = lightScale();
    Mb.R[6] = analogRead(A6);
    Mb.R[7] = analogRead(A7);
    Mb.R[8] = analogRead(A8);
    Mb.R[9] = analogRead(A9);
    Mb.R[10] = analogRead(A10);
    Mb.R[11] = analogRead(A11);
    Mb.R[12] = analogRead(A12);
    Mb.R[13] = analogRead(A13);
    Mb.R[14] = analogRead(A14);
    Mb.R[15] = analogRead(A15);
    // Slave Memory
    Mb.R[16] = freeRam();
    // Slave uptime, 32 bits carried by two (2) 16 bit registers
    long uptime = millis();
    // High word
    Mb.R[17] = uptime >> 16 & 0xFFFF;
    // Low word
    Mb.R[18] = uptime & 0xFFFF;
    // Listen for the master
    Mb.Run();
    // This delay improves stability by orders of magnitude
    delay(10);
    // Set digital outs
    digitalWrite(2, Mb.C[2]);
    digitalWrite(3, Mb.C[3]);
    digitalWrite(5, Mb.C[5]);
    digitalWrite(6, Mb.C[6]);
double tempFromADC(int adcVal)
    double temp;
    // See http://en.wikipedia.org/wiki/Thermistor for explanation of formula
    temp = log(((10240000/adcVal) - 10000));
    temp = 1 / (0.001129148 + (0.000234125 * temp) + (0.0000000876741 * temp * temp * temp));
    temp = temp - 273.15;          // Convert Kelvin to Celcius
    temp = (temp * 1.8) + 32.0; // Comment this line for C instead of F
    return temp;
int lightScale()
    double val = analogRead(5) / 1023.0;
    int returnVal = int(val * 1000);
    return returnVal;
int freeRam()
    extern int __heap_start, *__brkval;
    int v;
    return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
Mudbus.zip (16.2 KB)
I am looking for Modbus slave over Serial.I have already mentioned I am using Arduino UNO board.If you have any working code with uno for trail purpose will be appreciable
Are you looking for Modbus over Serial or over Ethernet, I didn't see this mentioned anywhere. If you want a Modbus/TCP slave then I have included the Mudbus library. I have an Arduino Mega 2560 with all of it's pins mapped out with the exception of those required by the Ethernet shield. I have this sketch working with an industrial HMI for a home automation type system, it works quite well. Some of the pins have thermistors connected, I multiply by 10 so I can divide by 10 on the master and carry a decimal place
Hi AMPS-N,
Do you still require assistance? I have developed SimpleModbusMaster and SimpleModbusSlave. You have already mentioned them. They will communicate with each other as long as you adhere to the schematic on the same site. I have tested them extensively with various industrial and marine equipment and so have other users with great success. Give it try and let us know if you come right.
Y ai already solved the problem , Thanks for support
Hi There,
I am pretty new here , Kind of been popping in and out. been hunting around for answers around this
topic. Id taken youd code and thrown it on my Arduino Mega with the Ethernet R3 Shield.
The code runs and i can pick up the Modbus slave from TCP/IP. However there is some stuff I
dont understand in your code and how best to adapt it to what id like to do. In addition to this
i think i require some more assistance either in knowing how Mudbus library works in relation
to the digital input registers you have there. since i am not sure where or what my registers should
be on my Master side. Could anyone also recommend to me a good Master simulator .
What i intend to do is for the time being Run 2 DHT22 sensors with another 2 Analogue temperature
probes. I would also like to write values back to the Arduino for example PWM signal for control on
the other side . Its my first time run with some home automation and I would really like to experiment
with this. I would like to stick to Modbus as i want to use NodeRed for interaction and control with
all the sensory and ouputs .
madpenguin8:
Hope this helps.
#include <SPI.h>
#include “Mudbus.h”
Mudbus Mb;
 //Setup networking
   uint8_t mac = { 0x90, 0xA2, 0xDA, 0x00, 0x51, 0x06 };
   pinMode(2, OUTPUT);
   pinMode(3, OUTPUT);
   pinMode(5, OUTPUT);
   pinMode(6, OUTPUT);
   Mb.C[4] = false;
   Mb.C[10] = false;
   Mb.C[50] = false;
   Mb.C[51] = false;
   Mb.C[52] = false;
   Mb.C[53] = false;
   // Slave Memory
   // High word
   // Low word
   Mb.Run();
   delay(10);
   // Set digital outs
   double temp;
   return temp;
int lightScale()
   return returnVal;
int freeRam()
   int v;
See this link example code modbus TCP/RTU:
https://www.amazon.com/dp/1096415186
