Ja genau. Nutze aktuell folgenden Sketch zum testen:
// Growatt Solar Inverter to MQTT
// Repo: https://github.com/nygma2004/growatt2mqtt
// author: Csongor Varga, csongor.varga@gmail.com
// 1 Phase, 2 string inverter version such as MIN 3000 TL-XE, MIC 1500 TL-X
// Libraries:
// - FastLED by Daniel Garcia
// - ModbusMaster by Doc Walker
// - ArduinoOTA
// - SoftwareSerial
// Hardware:
// - Wemos D1 mini
// - RS485 to TTL converter: https://www.aliexpress.com/item/1005001621798947.html
// - To power from mains: Hi-Link 5V power supply (https://www.aliexpress.com/item/1005001484531375.html), fuseholder and 1A fuse, and varistor
#include <SoftwareSerial.h> // Leave the main serial line (USB) for debugging and flashing
#include <ModbusMaster.h> // Modbus master library for ESP8266
#include <ESP8266WiFi.h> // Wifi connection
#include <ESP8266WebServer.h> // Web server for general HTTP response
#include <PubSubClient.h> // MQTT support
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include "globals.h"
#include "settings.h"
os_timer_t myTimer;
ESP8266WebServer server(80);
WiFiClient espClient;
PubSubClient mqtt(mqtt_server, 1883, 0, espClient);
// SoftwareSerial modbus(MAX485_RX, MAX485_TX, false, 256); //RX, TX
SoftwareSerial modbus(MAX485_RX, MAX485_TX, false); //RX, TX
ModbusMaster growatt;
void preTransmission() {
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 1);
void postTransmission() {
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 0);
void sendModbusError(uint8_t result) {
String message = "";
if (result==growatt.ku8MBIllegalFunction) {
message = "Illegal function";
if (result==growatt.ku8MBIllegalDataAddress) {
message = "Illegal data address";
if (result==growatt.ku8MBIllegalDataValue) {
message = "Illegal data value";
if (result==growatt.ku8MBSlaveDeviceFailure) {
message = "Slave device failure";
if (result==growatt.ku8MBInvalidSlaveID) {
message = "Invalid slave ID";
if (result==growatt.ku8MBInvalidFunction) {
message = "Invalid function";
if (result==growatt.ku8MBResponseTimedOut) {
message = "Response timed out";
if (result==growatt.ku8MBInvalidCRC) {
message = "Invalid CRC";
if (message=="") {
message = result;
Serial.println(message);
char topic[80];
char value[30];
sprintf(topic,"%s/error",topicRoot);
mqtt.publish(topic, message.c_str());
delay(5);
void ReadInputRegisters() {
char json[1024];
char topic[80];
char value[10];
uint8_t result;
digitalWrite(STATUS_LED, 0);
ESP.wdtDisable();
result = growatt.readInputRegisters(setcounter*64,64);
ESP.wdtEnable(1);
if (result == growatt.ku8MBSuccess) {
#ifdef DEBUG_SERIAL
Serial.print("InputReg page");
Serial.print(setcounter);
Serial.print(": ");
#endif
sprintf(json,"{");
for(int i=0;i<64;i++) {
#ifdef DEBUG_SERIAL
sprintf(value,"%d|",growatt.getResponseBuffer(i));
Serial.print(value);
#endif
#ifdef DEBUG_MQTT
sprintf(json,"%s \"r%d\":%d,",json,i,growatt.getResponseBuffer(i));
#endif
sprintf(json,"%s \"end\":1 }",json);
#ifdef DEBUG_SERIAL
#endif
#ifdef DEBUG_MQTT
sprintf(topic,"%s/raw",topicRoot);
mqtt.publish(topic, json);
#endif
if (setcounter==0) {
// Status and PV data
modbusdata.status = growatt.getResponseBuffer(0);
modbusdata.solarpower = ((growatt.getResponseBuffer(1) << 16) | growatt.getResponseBuffer(2))*0.1;
modbusdata.pv1voltage = growatt.getResponseBuffer(3)*0.1;
modbusdata.pv1current = growatt.getResponseBuffer(4)*0.1;
modbusdata.pv1power = ((growatt.getResponseBuffer(5) << 16) | growatt.getResponseBuffer(6))*0.1;
modbusdata.pv2voltage = growatt.getResponseBuffer(7)*0.1;
modbusdata.pv2current = growatt.getResponseBuffer(8)*0.1;
modbusdata.pv2power = ((growatt.getResponseBuffer(9) << 16) | growatt.getResponseBuffer(10))*0.1;
// Output
modbusdata.outputpower = ((growatt.getResponseBuffer(35) << 16) | growatt.getResponseBuffer(36))*0.1;
modbusdata.SOC = growatt.getResponseBuffer(1014-64 );
modbusdata.gridvoltage = growatt.getResponseBuffer(38)*0.1;
// Energy
modbusdata.energytoday = ((growatt.getResponseBuffer(53) << 16) | growatt.getResponseBuffer(54))*0.1;
modbusdata.energytotal = ((growatt.getResponseBuffer(55) << 16) | growatt.getResponseBuffer(56))*0.1;
modbusdata.totalworktime = ((growatt.getResponseBuffer(57) << 16) | growatt.getResponseBuffer(58))*0.5;
modbusdata.pv1energytoday = ((growatt.getResponseBuffer(59) << 16) | growatt.getResponseBuffer(60))*0.1;
modbusdata.pv1energytotal = ((growatt.getResponseBuffer(61) << 16) | growatt.getResponseBuffer(62))*0.1;
overflow = growatt.getResponseBuffer(63);
if (setcounter==1) {
modbusdata.pv2energytoday = ((overflow << 16) | growatt.getResponseBuffer(64-64))*0.1;
modbusdata.pv2energytotal = ((growatt.getResponseBuffer(65-64) << 16) | growatt.getResponseBuffer(66-64))*0.1;
// Temperatures
modbusdata.tempinverter = growatt.getResponseBuffer(93-64)*0.1;
modbusdata.tempipm = growatt.getResponseBuffer(94-64)*0.1;
modbusdata.tempboost = growatt.getResponseBuffer(95-64)*0.1;
// Diag data
modbusdata.ipf = growatt.getResponseBuffer(100-64);
modbusdata.realoppercent = growatt.getResponseBuffer(101-64);
modbusdata.opfullpower = ((growatt.getResponseBuffer(102-64) << 16) | growatt.getResponseBuffer(103-64))*0.1;
modbusdata.deratingmode = growatt.getResponseBuffer(103-64);
// 0:no derate;
// 1:PV;
// 2:*;
// 3:Vac;
// 4:Fac;
// 5:Tboost;
// 6:Tinv;
// 7:Control;
// 8:*;
// 9:*OverBack
// ByTime;
modbusdata.faultcode = growatt.getResponseBuffer(105-64);
// 1~23 " Error: 99+x
// 24 "Auto Test
// 25 "No AC
// 26 "PV Isolation Low",
// 27 " Residual I
// 28 " Output High
// 29 " PV Voltage
// 30 " AC V Outrange
// 31 " AC F Outrange
// 32 " Module Hot
modbusdata.faultbitcode = ((growatt.getResponseBuffer(105-64) << 16) | growatt.getResponseBuffer(106-64));
// 0x00000001 \
// 0x00000002 Communication error
// 0x00000004 \
// 0x00000008 StrReverse or StrShort fault
// 0x00000010 Model Init fault
// 0x00000020 Grid Volt Sample diffirent
// 0x00000040 ISO Sample diffirent
// 0x00000080 GFCI Sample diffirent
// 0x00000100 \
// 0x00000200 \
// 0x00000400 \
// 0x00000800 \
// 0x00001000 AFCI Fault
// 0x00002000 \
// 0x00004000 AFCI Module fault
// 0x00008000 \
// 0x00010000 \
// 0x00020000 Relay check fault
// 0x00040000 \
// 0x00080000 \
// 0x00100000 \
// 0x00200000 Communication error
// 0x00400000 Bus Voltage error
// 0x00800000 AutoTest fail
// 0x01000000 No Utility
// 0x02000000 PV Isolation Low
// 0x04000000 Residual I High
// 0x08000000 Output High DCI
// 0x10000000 PV Voltage high
// 0x20000000 AC V Outrange
// 0x40000000 AC F Outrange
// 0x80000000 TempratureHigh
modbusdata.warningbitcode = ((growatt.getResponseBuffer(110-64) << 16) | growatt.getResponseBuffer(111-64));
// 0x0001 Fan warning
// 0x0002 String communication abnormal
// 0x0004 StrPIDconfig Warning
// 0x0008 \
// 0x0010 DSP and COM firmware unmatch
// 0x0020 \
// 0x0040 SPD abnormal
// 0x0080 GND and N connect abnormal
// 0x0100 PV1 or PV2 circuit short
// 0x0200 PV1 or PV2 boost driver broken
// 0x0400 \
// 0x0800 \
// 0x1000 \
// 0x2000 \
// 0x4000 \
// 0x8000 \
setcounter++;
if (setcounter==2) {
setcounter = 0;
// Generate the modbus MQTT message
sprintf(json,"{",json);
sprintf(json,"%s \"status\":%d,",json,modbusdata.status);
sprintf(json,"%s \"solarpower\":%.1f,",json,modbusdata.solarpower);
sprintf(json,"%s \"pv1voltage\":%.1f,",json,modbusdata.pv1voltage);
sprintf(json,"%s \"pv1current\":%.1f,",json,modbusdata.pv1current);
sprintf(json,"%s \"pv1power\":%.1f,",json,modbusdata.pv1power);
sprintf(json,"%s \"pv2voltage\":%.1f,",json,modbusdata.pv2voltage);
sprintf(json,"%s \"pv2current\":%.1f,",json,modbusdata.pv2current);
sprintf(json,"%s \"pv2power\":%.1f,",json,modbusdata.pv2power);
sprintf(json,"%s \"outputpower\":%.1f,",json,modbusdata.outputpower);
sprintf(json,"%s \"SOC\":%.2f,",json,modbusdata.SOC);
sprintf(json,"%s \"gridvoltage\":%.1f,",json,modbusdata.gridvoltage);
sprintf(json,"%s \"energytoday\":%.1f,",json,modbusdata.energytoday);
sprintf(json,"%s \"energytotal\":%.1f,",json,modbusdata.energytotal);
sprintf(json,"%s \"totalworktime\":%.1f,",json,modbusdata.totalworktime);
sprintf(json,"%s \"pv1energytoday\":%.1f,",json,modbusdata.pv1energytoday);
sprintf(json,"%s \"pv1energytotal\":%.1f,",json,modbusdata.pv1energytotal);
sprintf(json,"%s \"pv2energytoday\":%.1f,",json,modbusdata.pv2energytoday);
sprintf(json,"%s \"pv2energytotal\":%.1f,",json,modbusdata.pv2energytotal);
sprintf(json,"%s \"opfullpower\":%.1f,",json,modbusdata.opfullpower);
sprintf(json,"%s \"tempinverter\":%.1f,",json,modbusdata.tempinverter);
sprintf(json,"%s \"tempipm\":%.1f,",json,modbusdata.tempipm);
sprintf(json,"%s \"tempboost\":%.1f,",json,modbusdata.tempboost);
sprintf(json,"%s \"ipf\":%d,",json,modbusdata.ipf);
sprintf(json,"%s \"realoppercent\":%d,",json,modbusdata.realoppercent);
sprintf(json,"%s \"deratingmode\":%d,",json,modbusdata.deratingmode);
sprintf(json,"%s \"faultcode\":%d,",json,modbusdata.faultcode);
sprintf(json,"%s \"faultbitcode\":%d,",json,modbusdata.faultbitcode);
sprintf(json,"%s \"warningbitcode\":%d }",json,modbusdata.warningbitcode);
#ifdef DEBUG_SERIAL
Serial.println(json);
#endif
sprintf(topic,"%s/data",topicRoot);
mqtt.publish(topic,json);
Serial.println("Data MQTT sent");
//sprintf(topic,"%s/error",topicRoot);
//mqtt.publish(topic,"OK");
Serial.print(F("Error: "));
sendModbusError(result);
digitalWrite(STATUS_LED, 1);
void ReadHoldingRegisters() {
char json[1024];
char topic[80];
char value[10];
uint8_t result;
//uint16_t data[6];
ESP.wdtDisable();
result = growatt.readHoldingRegisters(setcounter*64,64);
ESP.wdtEnable(1);
#ifdef DEBUG_SERIAL
Serial.print("HoldingReg Page");
Serial.print(": ");
#endif
sprintf(json,"{");
#ifdef DEBUG_SERIAL
#endif
#ifdef DEBUG_MQTT
#endif
#ifdef DEBUG_SERIAL
#endif
#ifdef DEBUG_MQTT
sprintf(topic,"%s/holding",topicRoot);
#endif
modbussettings.safetyfuncen = growatt.getResponseBuffer(1); // Safety Function Enabled
// Bit0: SPI enable
// Bit1: AutoTestStart
// Bit2: LVFRT enable
// Bit3: FreqDerating Enable
// Bit4: Softstart enable
// Bit5: DRMS enable
// Bit6: Power Volt Func Enable
// Bit7: HVFRT enable
// Bit8: ROCOF enable
// Bit9: Recover FreqDerating Mode Enable
// Bit10~15: Reserved
modbussettings.maxoutputactivepp = growatt.getResponseBuffer(3); // Inverter M ax output active power percent 0-100: %, 255: not limited
modbussettings.maxoutputreactivepp = growatt.getResponseBuffer(4); // Inverter M ax output reactive power percent 0-100: %, 255: not limited
modbussettings.maxpower = ((growatt.getResponseBuffer(6) << 16) | growatt.getResponseBuffer(7))*0.1;
modbussettings.voltnormal = growatt.getResponseBuffer(8)*0.1;
strncpy(modbussettings.firmware," ",6);
modbussettings.firmware[0] = growatt.getResponseBuffer(9) >> 8;
modbussettings.firmware[1] = growatt.getResponseBuffer(9) & 0xff;
modbussettings.firmware[2] = growatt.getResponseBuffer(10) >> 8;
modbussettings.firmware[3] = growatt.getResponseBuffer(10) & 0xff;
modbussettings.firmware[4] = growatt.getResponseBuffer(11) >> 8;
modbussettings.firmware[5] = growatt.getResponseBuffer(11) & 0xff;
strncpy(modbussettings.controlfirmware," ",6);
modbussettings.controlfirmware[0] = growatt.getResponseBuffer(12) >> 8;
modbussettings.controlfirmware[1] = growatt.getResponseBuffer(12) & 0xff;
modbussettings.controlfirmware[2] = growatt.getResponseBuffer(13) >> 8;
modbussettings.controlfirmware[3] = growatt.getResponseBuffer(13) & 0xff;
modbussettings.controlfirmware[4] = growatt.getResponseBuffer(14) >> 8;
modbussettings.controlfirmware[5] = growatt.getResponseBuffer(14) & 0xff;
modbussettings.startvoltage = growatt.getResponseBuffer(17)*0.1;
strncpy(modbussettings.serial," ",10);
modbussettings.serial[0] = growatt.getResponseBuffer(23) >> 8;
modbussettings.serial[1] = growatt.getResponseBuffer(23) & 0xff;
modbussettings.serial[2] = growatt.getResponseBuffer(24) >> 8;
modbussettings.serial[3] = growatt.getResponseBuffer(24) & 0xff;
modbussettings.serial[4] = growatt.getResponseBuffer(25) >> 8;
modbussettings.serial[5] = growatt.getResponseBuffer(25) & 0xff;
modbussettings.serial[6] = growatt.getResponseBuffer(26) >> 8;
modbussettings.serial[7] = growatt.getResponseBuffer(26) & 0xff;
modbussettings.serial[8] = growatt.getResponseBuffer(27) >> 8;
modbussettings.serial[9] = growatt.getResponseBuffer(27) & 0xff;
modbussettings.gridvoltlowlimit = growatt.getResponseBuffer(52)*0.1;
modbussettings.gridvolthighlimit = growatt.getResponseBuffer(53)*0.1;
modbussettings.gridvoltlowconnlimit = growatt.getResponseBuffer(64-64)*0.1;
modbussettings.gridvolthighconnlimit = growatt.getResponseBuffer(65-64)*0.1;
setcounter++;
setcounter = 0;
sprintf(json,"%s \"safetyfuncen\":%d,",json,modbussettings.safetyfuncen);
sprintf(json,"%s \"maxoutputactivepp\":%d,",json,modbussettings.maxoutputactivepp);
sprintf(json,"%s \"maxoutputreactivepp\":%d,",json,modbussettings.maxoutputreactivepp);
sprintf(json,"%s \"maxpower\":%.1f,",json,modbussettings.maxpower);
sprintf(json,"%s \"voltnormal\":%.1f,",json,modbussettings.voltnormal);
sprintf(json,"%s \"startvoltage\":%.1f,",json,modbussettings.startvoltage);
sprintf(json,"%s \"gridvoltlowlimit\":%.1f,",json,modbussettings.gridvoltlowlimit);
sprintf(json,"%s \"gridvolthighlimit\":%.1f,",json,modbussettings.gridvolthighlimit);
sprintf(json,"%s \"gridvoltlowconnlimit\":%.1f,",json,modbussettings.gridvoltlowconnlimit);
sprintf(json,"%s \"gridvolthighconnlimit\":%.1f,",json,modbussettings.gridvolthighconnlimit);
sprintf(json,"%s \"firmware\":\"%s\",",json,modbussettings.firmware);
sprintf(json,"%s \"controlfirmware\":\"%s\",",json,modbussettings.controlfirmware);
sprintf(json,"%s \"serial\":\"%s\" }",json,modbussettings.serial);
#ifdef DEBUG_SERIAL
#endif
sprintf(topic,"%s/settings",topicRoot);
Serial.println("Setting MQTT sent");
// Set the flag to true not to read the holding registers again
holdingregisters=true;
// This is the 1 second timer callback function
void timerCallback(void *pArg) {
seconds++;
// Query the modbus device
if (seconds % UPDATE_MODBUS==0) {
//ReadInputRegisters();
if (!holdingregisters) {
// Read the holding registers
ReadHoldingRegisters();
// Read the input registers
// Send RSSI and uptime status
if (seconds % UPDATE_STATUS==0) {
// Send MQTT update
if (mqtt_server!="") {
char topic[80];
char value[300];
sprintf(value,"{\"rssi\": %d, \"uptime\": %d, \"ssid\": \"%s\", \"ip\": \"%d.%d.%d.%d\", \"clientid\":\"%s\", \"version\":\"%s\"}",WiFi.RSSI(),uptime,WiFi.SSID().c_str(),WiFi.localIP()[0],WiFi.localIP()[1],WiFi.localIP()[2],WiFi.localIP()[3],newclientid,buildversion);
sprintf(topic,"%s/%s",topicRoot,"status");
mqtt.publish(topic, value);
Serial.println(F("MQTT status sent"));
// MQTT reconnect logic
void reconnect() {
//String mytopic;
// Loop until we're reconnected
while (!mqtt.connected()) {
Serial.print("Attempting MQTT connection...");
byte mac[6]; // the MAC address of your Wifi shield
WiFi.macAddress(mac);
sprintf(newclientid,"%s-%02x%02x%02x",clientID,mac[2],mac[1],mac[0]);
Serial.print(F("Client ID: "));
Serial.println(newclientid);
// Attempt to connect
if (mqtt.connect(newclientid, mqtt_user, mqtt_password)) {
Serial.println(F("connected"));
// ... and resubscribe
char topic[80];
sprintf(topic,"%swrite/#",topicRoot);
mqtt.subscribe(topic);
Serial.print(F("failed, rc="));
Serial.print(mqtt.state());
Serial.println(F(" try again in 5 seconds"));
// Wait 5 seconds before retrying
delay(5000);
Serial.begin(SERIAL_RATE);
Serial.println(F("\nGrowatt Solar Inverter to MQTT Gateway"));
// Init outputs, RS485 in receive mode
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
pinMode(STATUS_LED, OUTPUT);
// Initialize some variables
uptime = 0;
seconds = 0;
// Connect to Wifi
Serial.print(F("Connecting to Wifi"));
WiFi.mode(WIFI_STA);
#ifdef FIXEDIP
// Configures static IP address
if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
Serial.println("STA Failed to configure");
#endif
WiFi.begin(ssid, password);
Serial.print(F("."));
seconds++;
if (seconds>180) {
// reboot the ESP if cannot connect to wifi
ESP.restart();
seconds = 0;
Serial.println("");
Serial.println(F("Connected to wifi network"));
Serial.print(F("IP address: "));
Serial.print(F("Signal [RSSI]: "));
Serial.println(WiFi.RSSI());
// Set up the Modbus line
growatt.begin(SLAVE_ID , modbus);
// Callbacks allow us to configure the RS485 transceiver correctly
growatt.preTransmission(preTransmission);
growatt.postTransmission(postTransmission);
Serial.println("Modbus connection is set up");
// Create the 1 second timer interrupt
os_timer_setfn(&myTimer, timerCallback, NULL);
os_timer_arm(&myTimer, 1000, true);
server.on("/", [](){ // Dummy page
server.send(200, "text/plain", "Growatt Solar Inverter to MQTT Gateway");
server.begin();
Serial.println(F("HTTP server started"));
// Set up the MQTT server connection
mqtt.setServer(mqtt_server, 1883);
mqtt.setBufferSize(1024);
mqtt.setCallback(callback);
// Port defaults to 8266
// ArduinoOTA.setPort(8266);
// Hostname defaults to esp8266-[ChipID]
char value[80];
sprintf(value,"%s-%02x%02x%02x",clientID,mac[2],mac[1],mac[0]);
ArduinoOTA.setHostname(value);
// No authentication by default
// ArduinoOTA.setPassword((const char *)"123");
ArduinoOTA.onStart([]() {
os_timer_disarm(&myTimer);
Serial.println("Start");
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
modbus.begin(MODBUS_RATE);
void callback(char* topic, byte* payload, unsigned int length) {
// Convert the incoming byte array to a string
String mytopic = (char*)topic;
payload[length] = '\0'; // Null terminator used to terminate the char array
String message = (char*)payload;
Serial.print(F("Message arrived on topic: ["));
Serial.print(topic);
Serial.print(F("], "));
// Handle HTTP server requests
server.handleClient();
ArduinoOTA.handle();
// Handle MQTT connection/reconnection
if (!mqtt.connected()) {
reconnect();
mqtt.loop();
// Uptime calculation
if (millis() - lastTick >= 60000) {
lastTick = millis();
uptime++;
if (millis() - lastWifiCheck >= WIFICHECK) {
// reconnect to the wifi network if connection is lost
if (WiFi.status() != WL_CONNECTED) {
Serial.println("Reconnecting to wifi...");
WiFi.reconnect();
lastWifiCheck = millis();
