Modbus RTU
hello to evryone, i want create a slave whit arduino and 485 chip. whit this slave i want send a value of an variable to master, there is someone that have an a example? Beacuse it's my first time whit the modbus. Thank you very much!!!
Are you sure you know what Modbus is? You cannot send a value to the master, the master always must request it from the slave, the slave is only allowed to answer.
I use this library to do Modbus RTU, it has examples of how to use it. Depending on your needs you might have to use another library, each has it's own advantages and disadvantages.
If you need more help, provide much more information about your setup and goals!
I use modbus on my plc and in this case i need ask to arduino a value about load cell. but i don't know how to connect the variable value to the modbus register. (PLC is a master)
I already have this library, but from the examples I have not been able to understand which part I would need.
Don't expect us to know that as you haven't provided enough details to enable us to decide. Take a look at the advanced_slave example, that should give you a good start. If you don't understand that example, explain where exactly you have problems.
Hi, I looked at the example you told me, but I can't understand how I can make sure that once I request the reading of the register from the plc, arduino communicates the value of the variable to me. What function do I associate with the variable in the example below?
 *  Modbus slave example 2:
 *  The purpose of this example is to link the Arduino digital and analog
 *	pins to an external device.
 *  Recommended Modbus Master: QModbus
 *  http://qmodbus.sourceforge.net/
 *  Editado al español por LuxARTS
//Incluye la librería del protocolo Modbus
#include <ModbusRtu.h>
#define ID   1
//Crear instancia
Modbus slave(ID, Serial, 0); //ID del nodo. 0 para el master, 1-247 para esclavo
                        //Puerto serie (0 = TX: 1 - RX: 0)
                        //Protocolo serie. 0 para RS-232 + USB (default), cualquier pin mayor a 1 para RS-485
boolean led;
int8_t state = 0;
unsigned long tempus;
uint16_t au16data[9]; //La tabla de registros que se desea compartir por la red
 Configuración del programa
  io_setup(); //configura las entradas y salidas
  Serial.begin(19200); //Abre la comunicación como esclavo
  slave.start();
  tempus = millis() + 100; //Guarda el tiempo actual + 100ms
  digitalWrite(13, HIGH ); //Prende el led del pin 13 (el de la placa)
 Inicio del programa
  //Comprueba el buffer de entrada
  state = slave.poll( au16data, 9 ); //Parámetros: Tabla de registros para el intercambio de info
                                     //            Tamaño de la tabla de registros
                                     //Devuelve 0 si no hay pedido de datos
                                     //Devuelve 1 al 4 si hubo error de comunicación
                                     //Devuelve mas de 4 si se procesó correctamente el pedido
  if (state > 4) { //Si es mayor a 4 = el pedido fué correcto
    tempus = millis() + 50; //Tiempo actual + 50ms
    digitalWrite(13, HIGH);//Prende el led
  if (millis() > tempus) digitalWrite(13, LOW );//Apaga el led 50ms después
  //Actualiza los pines de Arduino con la tabla de Modbus
  io_poll();
 * pin maping:
 * 2 - digital input
 * 3 - digital input
 * 4 - digital input
 * 5 - digital input
 * 6 - digital output
 * 7 - digital output
 * 8 - digital output
 * 9 - digital output
 * 10 - analog output
 * 11 - analog output
 * 14 - analog input
 * 15 - analog input
 * pin 13 reservado para ver el estado de la comunicación
void io_setup() {
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(13, OUTPUT);
  digitalWrite(6, LOW );
  digitalWrite(7, LOW );
  digitalWrite(8, LOW );
  digitalWrite(9, LOW );
  digitalWrite(13, HIGH ); //Led del pin 13 de la placa
  analogWrite(10, 0 ); //PWM 0%
  analogWrite(11, 0 ); //PWM 0%
Enlaza la tabla de registros con los pines
void io_poll() {
  // digital inputs -> au16data[0]
  // Lee las entradas digitales y las guarda en bits de la primera variable del vector
  // (es lo mismo que hacer una máscara)
  bitWrite( au16data[0], 0, digitalRead( 2 )); //Lee el pin 2 de Arduino y lo guarda en el bit 0 de la variable au16data[0]
  bitWrite( au16data[0], 1, digitalRead( 3 ));
  bitWrite( au16data[0], 2, digitalRead( 4 ));
  bitWrite( au16data[0], 3, digitalRead( 5 ));
  // digital outputs -> au16data[1]
  // Lee los bits de la segunda variable y los pone en las salidas digitales
  digitalWrite( 6, bitRead( au16data[1], 0 )); //Lee el bit 0 de la variable au16data[1] y lo pone en el pin 6 de Arduino
  digitalWrite( 7, bitRead( au16data[1], 1 ));
  digitalWrite( 8, bitRead( au16data[1], 2 ));
  digitalWrite( 9, bitRead( au16data[1], 3 ));
  // Cambia el valor del PWM
  analogWrite( 10, au16data[2] ); //El valor de au16data[2] se escribe en la salida de PWM del pin 10 de Arduino. (siendo 0=0% y 255=100%)
  analogWrite( 11, au16data[3] );
  // Lee las entradas analógicas (ADC)
  au16data[4] = analogRead( 0 ); //El valor analógico leido en el pin A0 se guarda en au16data[4]. (siendo 0=0v y 1023=5v)
  au16data[5] = analogRead( 1 );
  // Diagnóstico de la comunicación (para debug)
  au16data[6] = slave.getInCnt();  //Devuelve cuantos mensajes se recibieron
  au16data[7] = slave.getOutCnt(); //Devuelve cuantos mensajes se transmitieron
  au16data[8] = slave.getErrCnt(); //Devuelve cuantos errores hubieron
I have highlighted with &&& what is not clear to me! and i not understand which is the function that i can use for comunicate a variable i would be really greateful if you help me!!! Thanks!
#define ID   1 //ID del nodo. 0 para el master, 1-247 para esclavo
//Crear instancia
Modbus slave(ID, Serial, 1);
boolean led;
int8_t state = 0;
&&&uint16_t au16data[9]; //La tabla de registros que se desea compartir por la red &&& (1)What is this?
  slave.start();
 Inicio del programa
&&&state = slave.poll( au16data, 9 );&&&What is this?//Parámetros:Tabla de registros para el intercambio de info
  io_poll();
 * pin maping:
 * 2 - digital input
 * 3 - digital input
 * 4 - digital input
 * 5 - digital input
 * 14 - analog input
 * 15 - analog input
void io_setup() {
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
void io_poll() {
The "au16data" array contains the values that the requesting master will get. So assign the corresponding value to the correct index in this array to let the library return that value.
