Modbus TCP/IP Server
Hi everyone, I am trying to communicate an Arduino with a solar inverter, Arduino as Client (Master) and Inverter as Server (Slave).
I have Arduino Nano, ENC28J60 and W5100.
There is a lot of information on the web, but I can't get it to work.
Can somebody help me? I am not a programming expert, I would need someone to guide me with this project.
Thank you
  This is Modbus test code to demonstrate all the Modbus functions with
  with Ethernet IC ENC28J60
  ModbusTCP is free software: you can redistribute it and/or modify
  it under the terms of the GNU General Public License as published by
  the Free Software Foundation, either version 3 of the License, or
  (at your option) any later version.
  ModbusTCP is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  GNU General Public License for more details.
  You should have received a copy of the GNU General Public License
  along with ModbusTCP.  If not, see <http://www.gnu.org/licenses/>.
  Adopted from ModbusMaster for RTU over RS-485 by Doc Walker
  Modified by Narendra Dehury for TCP.
  copyright @ phoenixrobotix.com
#define ENC28J60     = 1
unsigned int param_value_int[7];
#include <UIPEthernet.h>
#include <avr/wdt.h>
IPAddress ModbusDeviceIP(10, 10, 108, 211);
IPAddress moduleIPAddress(10, 10, 108, 23);  // Anything other than the device IP Address
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xE1 };
#include <ModbusTCP.h>
ModbusTCP node(1);
void setup(){
  pinMode(4, OUTPUT);
  digitalWrite(4, HIGH);
  //wdt_enable(WDTO_4S);
  //WDTCSR |= _BV(WDIE);
  wdt_disable();
  Ethernet.begin(mac, moduleIPAddress);
  node.setServerIPAddress(ModbusDeviceIP);
  Serial.println("Setup");
  delay(6000);
void loop(){
  uint8_t result;
//  node.setTransactionID(random(100));
  result = node.readHoldingRegisters(1, 12);
  Serial.print("hola: ");
  Serial.println(result, HEX);
  //if(result == node.MBServerConnectionTimeOut)
  if(result != 0)
    node.MBconnectionFlag = 0;
    Serial.println("TimeOut");
    if(result == 5) {
      //Ethernet.begin(mac, moduleIPAddress);
      wdt_enable(WDTO_8S);
    delay(6000);
  int len = node.getResponseBufferLength();
  Serial.println("Response Length: " + String(len));
  for (byte j = 0; j < len; j++)
    Serial.print(node.getResponseBuffer(j));
    Serial.print(" ");
  node.clearResponseBuffer();
  delay(100);
//  node.writeSingleRegister(5, 3);
//  Serial.println(result, HEX);
//  delay(500);
//  for (byte i = 0; i < 5; i++)
//    node.setTransmitBuffer(i, (i+100));
//  node.writeMultipleRegisters(2, 5);
//  delay(500);
//  node.writeSingleCoil(20, 1);
//  delay(500);
  node.setTransmitBuffer(0, 0b1010101001010101);
  node.writeMultipleCoils(20, 16);
  result = node.readCoils(20, 18);
  Serial.println(node.getResponseBuffer(0), BIN);
  delay(200);
  result = node.readHoldingRegisters(2, 8);
    param_value_int[j] = node.getResponseBuffer(j);
    Serial.print(param_value_int[j]);
    Serial.print(" ");
  delay(10000);
Hi, Thanks
But in this case the server is the other device, not the arduino. Or not?
how is it to determine?
Sorry its okey, Arduino master is the client and the solar inverter is the server.
I run the code but isn´t work, i´m triying with "modbus slave" in the PC.
