I am trying to establish a ModbusTCP communication between my PC and Arduino PMC(Portenta Machine Control). SO the basic idea is that my PC(ModbusTCP Server/Slave) would write data to 2 registers and my PMC(ModbusTCP Client/Master) would read the respective registers. Both of the codes run on the same machine.
The major isuue that I have is that "modbusTCPClient.begin(server, 1502)" fails. It returns a 0. So why does this happen? and how could I solve it?
I am quite new to ModbusTCP and I am learning on the go. So any help or guidance would be greatly appreciated!
Server Code:
from pyModbusTCP.server import ModbusServer, DataBank
host = '127.0.0.1'
port = 1502
class mydatabank(DataBank):
def __init__(self):
super().__init__()
def get_holding_registers(self, address, number=1, srv_info=None):
self._h_regs[0] = 5
self._h_regs[1] = 100
#repcakage data into a list
try:
return[self._h_regs[i] for i in range(address,address + number)]
except KeyError:
return
if __name__ == '__main__':
server = ModbusServer(host=host, port=port, data_bank=mydatabank())
server.start()
Client code:
#include<SPI.h>
#include<Ethernet.h>
#include<ArduinoRS485.h>
#include<ArduinoModbus.h>
EthernetClient client;
ModbusTCPClient modbusTCPClient(client);
IPAddress ip(192,168,1,10); //ip address created for PMC
IPAddress server(127,0,0,1);
while(!Serial);
Ethernet.begin(NULL,ip); //Successfull
int f = modbusTCPClient.begin(server, 1502);
// Serial.println("Attempting to connect to server...");
Serial.println(f);
if(modbusTCPClient.connected())
int value;//g
value = modbusTCPClient.holdingRegisterRead(0);
Serial.println(value);
Using 127.0.0.1 as the host IP address for your Modbus TCP server code on your PC probably means that the server will only listen for connections coming from the same machine where it's running. (127.0.0.1 is the loopback address, which refers to the local machine itself).
I am using a Linux machine. I did use this nc -w5 -z -v <ip_address> <port_number> and I got a result ** Connection to <ip_address> <port_number> port [tcp/*] succeeded!**.
So I do think that the firewall does not block the port.
I ran it on the same machine.
Interestingly, I tried to ping the IP address assigned to the Arduino(192.168.1.10) from my Linux machine(VM) and I got no reply. But when I tried to ping from my Host machine(Windows), i got a reply. But both the codes are running on the Linux machine. So is my Arduino not accessible in the Linux machine?
if (Ethernet.begin() == 0) {
Serial.println("Failed to configure Ethernet using DHCP!");
// Try to configure Ethernet with the predefined static IP address
Ethernet.begin(ip); // from your line IPAddress ip(192,168,1,10);
Serial.print("My IP is ");
Serial.println(Ethernet.localIP());
I tried it and still no success. I don't think it makes a difference as I am able to ping from Host machine(Windows) but not able to ping from Virtual Machine(Linux)
How do we check that? If you mean the change in Network settings that have to be made in the VM(eg, NAT to Bridged Adapter), then yeah, I have made it correctly.
