Hi.
I have a weird project I am working on.
I am trying to use the wifi on the MKR Wifi1010, to send Modbus TCP messages over.
And i get it to work, but:
1: it only receives every 3rd message.
2: When it receives, it will send the wrong data, and the next time i request, i get the rest of the data. (So i "hacked" the data and increased the message bit and was able to get a good feedback, just to prove that it was possible)
(Please ignore bad coding, this was made to prove the concept and implement into another project)
So my question is, why do i only see every 3rd message?
And why is it not sending all the data? ( I added the first client.write((byte) 0x00), due to it sending it wrong. With that there, the second time I request, the client receives a correct syntax string of data, without the data is missing the first 00)
I am not good at this, and learning as I go along. Most of this is patched together from examples and experimenting.
The client program I am using is made by the company I work for, and what I am trying to fool. Just to prove a point. ![]()
Print out from the RS232 from arduino at the bottom, and a picture of the client program that sends the requests.
// Wifi
#include <WiFiNINA.h>
// WiFi
char ssid[] = "TranstecTestBench"; // your network SSID (name)
char pass[] = "eSolution126"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(502);
// SERIAL FOR DEBUGGING (The text takes ALOT of space, remove or reformat if needed)
delay(2500);
Serial.println("Serial RS232 (DEBUGGING PORT) running -----------------------------");
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// print the network name (SSID);
Serial.print("Creating access point named: ");
Serial.println(ssid);
// Create open network. Change this line if you want to create an WEP network:
status = WiFi.beginAP(ssid, pass);
if (status != WL_AP_LISTENING) {
Serial.println("Creating access point failed");
// don't continue
while (true);
// wait 10? seconds for connection:
delay(5000);
// start the web server on port 80
server.begin();
// you're connected now, so print out the status
printWiFiStatus();
// Wifi Test
// compare the previous status to the current status
if (status != WiFi.status()) {
// it has changed update the variable
status = WiFi.status();
if (status == WL_AP_CONNECTED) {
// a device has connected to the AP
Serial.println("Device connected to AP");
// a device has disconnected from the AP, and we are back in listening mode
Serial.println("Device disconnected from AP");
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
int buf[32] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
int ii = 0;
Serial.println("What Master sent:");
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
int c = client.read(); // read a byte, then
Serial.println(c, HEX); // print it out the serial monitor
buf[ii] = c;
ii++;
Serial.println("What i saw:");
for(int i = 0; i <= 32; i++){
Serial.println(buf[i], HEX);
Serial.println("What i Need:");
Serial.println("Number of data points (Decimal):");
Serial.println(buf[5]);
Serial.println("Adress of Bench (Decimal):");
Serial.println(buf[6]);
Serial.println("Function:");
Serial.println(buf[7]);
Serial.println("Index (Decimal, RAW):");
Serial.println(buf[9]);
Serial.println("Index (Decimal, Actual):");
Serial.println(buf[9] + 40001);
Serial.println("Data:");
Serial.println(buf[10]);
Serial.println(buf[11]);
client.write((byte) 0x00);
client.write(buf[1]+1);
client.write(buf[2]);
client.write(buf[3]);
client.write(buf[4]);
client.write(05);
client.write(buf[6]);
client.write(buf[7]);
client.write(2);
client.write(1);
client.flush();
// close the connection:
client.stop();
Serial.println("client disconnected");
void printWiFiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
WiFi.config(IPAddress(192, 168, 1, 66));
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
9:31:01.363 -> Serial RS232 (DEBUGGING PORT) running -----------------------------
09:31:02.119 -> Please upgrade the firmware
09:31:02.119 -> Creating access point named: TranstecTestBench
09:31:09.122 -> SSID: TranstecTestBench
09:31:09.122 -> IP Address: 192.168.1.66
09:31:09.122 -> To see this page in action, open a browser to http://192.168.1.66
09:31:12.384 -> Device connected to AP
09:31:28.042 -> new client
09:31:28.511 -> What Master sent:
09:31:28.511 -> 0
09:31:28.511 -> 32
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 6
09:31:28.511 -> 67
09:31:28.511 -> 3
09:31:28.511 -> 0
09:31:28.511 -> 63
09:31:28.511 -> 0
09:31:28.511 -> 1
09:31:28.511 -> What i saw:
09:31:28.511 -> 0
09:31:28.511 -> 32
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 6
09:31:28.511 -> 67
09:31:28.511 -> 3
09:31:28.511 -> 0
09:31:28.511 -> 63
09:31:28.511 -> 0
09:31:28.511 -> 1
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 0
09:31:28.511 -> 7060
09:31:28.511 -> What i Need:
09:31:28.511 -> Number of data points (Decimal):
09:31:28.511 -> 6
09:31:28.511 -> Adress of Bench (Decimal):
09:31:28.511 -> 103
09:31:28.559 -> Function:
09:31:28.559 -> 3
09:31:28.559 -> Index (Decimal, RAW):
09:31:28.559 -> 99
09:31:28.559 -> Index (Decimal, Actual):
09:31:28.559 -> 40100
09:31:28.559 -> Data:
09:31:28.559 -> 0
09:31:28.559 -> 1
09:31:28.559 -> client disconnected
09:32:43.110 -> Device disconnected from AP
