Model: 276-640 Infrared collector vs. Sony RMT-B101A
I will start off with what I am trying to do.. I thought it would be simple, but I was soooo wrong. I have a remote I'm not using, and I want to use it for my Arduino to turn LEDs on and off. I have used scripts to grab the inputs of HEX and raw code for each button. When I try to turn around and use that code to execute commands, it does not work. Serial shows its seeing the input, but it wont do anything.
This is what I used to decode the remote buttons:
 * IRhashdecode - decode an arbitrary IR code.
 * Instead of decoding using a standard encoding scheme
 * (e.g. Sony, NEC, RC5), the code is hashed to a 32-bit value.
 * An IR detector/demodulator must be connected to the input RECV_PIN.
 * This uses the IRremote library: http://arcfn.com/2009/08/multi-protocol-infrared-remote-library.html
 * The algorithm: look at the sequence of MARK signals, and see if each one
 * is shorter (0), the same length (1), or longer (2) than the previous.
 * Do the same with the SPACE signals.  Hszh the resulting sequence of 0's,
 * 1's, and 2's to a 32-bit value.  This will give a unique value for each
 * different code (probably), for most code systems.
 * You're better off using real decoding than this technique, but this is
 * useful if you don't have a decoding algorithm.
 * Copyright 2010 Ken Shirriff
 * http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
// Compare two tick values, returning 0 if newval is shorter,
// 1 if newval is equal, and 2 if newval is longer
// Use a tolerance of 20%
int compare(unsigned int oldval, unsigned int newval) {
  if (newval < oldval * .8) {
    return 0;
  else if (oldval < newval * .8) {
    return 2;
  else {
    return 1;
// Use FNV hash algorithm: http://isthe.com/chongo/tech/comp/fnv/#FNV-param
#define FNV_PRIME_32 16777619
#define FNV_BASIS_32 2166136261
/* Converts the raw code values into a 32-bit hash code.
 * Hopefully this code is unique for each button.
unsigned long decodeHash(decode_results *results) {
  unsigned long hash = FNV_BASIS_32;
  for (int i = 1; i+2 < results->rawlen; i++) {
    int value =  compare(results->rawbuf[i], results->rawbuf[i+2]);
    // Add value into the hash
    hash = (hash * FNV_PRIME_32) ^ value;
  return hash;
  if (irrecv.decode(&results)) {
    Serial.print("'real' decode: ");
    Serial.print(results.value, HEX);
    Serial.print(", hash decode: ");
    Serial.println(decodeHash(&results), HEX); // Do something interesting with this value
    irrecv.resume(); // Resume decoding (necessary!)
#define LEDPIN 13
void blink() {
  digitalWrite(LEDPIN, HIGH);
  delay(200);
  digitalWrite(LEDPIN, LOW);
  delay(200);
// Blink the LED the number of times indicated by the Philips remote control
// Replace loop() with this for the blinking LED example.
void blink_example_loop() {
    unsigned long hash = decodeHash(&results);
    switch (hash) {
    case 0x322ddc47: // 0 (10)
      blink(); // fallthrough
    case 0xdb78c103: // 9
      blink();
    case 0xab57dd3b: // 8
      blink();
    case 0x715cc13f: // 7
      blink();
    case 0xdc685a5f: // 6
      blink();
    case 0x85b33f1b: // 5
      blink();
    case 0x4ff51b3f: // 4
      blink();
    case 0x15f9ff43: // 3
      blink();
    case 0x2e81ea9b: // 2
      blink();
    case 0x260a8662: // 1
      blink();
    default:
      Serial.print("Unknown ");
      Serial.println(hash, HEX);
This is what I was trying to adapt to actually do something with the remote:
// 0.1 by pmalmsten http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1176098434
// 0.2 by farkinga
// 0.3 by farkinga - adds cool behaviors
#define IR_BIT_LENGTH 12    // number of bits sent by IR remote
#define BIT_1 1000          // Binary 1 threshold (Microseconds)
#define BIT_0 400           // Binary 0 threshold (Microseconds)
#define BIT_START 2000      // Start bit threshold (Microseconds)
#define IR_PIN 11            // Sensor pin 1 wired through a 220 ohm resistor
#define LED_PIN 8           // first LED output
#define POWER_PIN 7        // second LED output, corresponds to power button
#define DEBUG 1             // Serial connection must be started to debug
int runtime_debug = 0;      // flag to output raw IR pulse data
int output_key = 0;         // flag to print decoded key integers
int power_button = 0;       // flag to indicate if power LED is on
int power_level = 128;      // value (0-255) for power LED intensity
  pinMode(LED_PIN, OUTPUT);	//This shows when we're ready to recieve
  pinMode(POWER_PIN, OUTPUT);	//This is the "power on" indicator
  pinMode(IR_PIN, INPUT);
  digitalWrite(LED_PIN, LOW);
  digitalWrite(LED_PIN, HIGH);
  int key = get_ir_key();
  digitalWrite(LED_PIN, LOW);  // turn LED off while processing response
  do_response(key);
  delay(100);                  // short delay to cancel duplicate keypresses
  wait for a keypress from the IR remote, and return the
  integer mapping of that key (e.g. power button on remote returns
  the integer 1429)
int get_ir_key()
  int pulse[IR_BIT_LENGTH];
  int bits[IR_BIT_LENGTH];
  do {} //Wait for a start bit
  while(pulseIn(IR_PIN, LOW) < BIT_START);
  read_pulse(pulse, IR_BIT_LENGTH);
  pulse_to_bits(pulse, bits, IR_BIT_LENGTH);
  return bits_to_int(bits, IR_BIT_LENGTH);
  respond to specific remote-control keys with different behaviors
void do_response(int key)
  switch (key)
    case 1437:  // record button
      Serial.println("toggle debug pulse");
      runtime_debug = 1 - runtime_debug;
    case 1498:  // display button
      Serial.println("Toggle key output");
      output_key = 1 - output_key;
    case 1429:  // power button
      Serial.println("Power");
      power_button = 1 - power_button;
      set_power();
    case 1424:  // channel up button
      Serial.println("Channel Up");
    case 1425:  // channel down button
      Serial.println("Channel Down");
    case 3342:  // up rocker/pause
      power_level+=1;
      set_power();
    case 3343:  // down rocker/stop
      power_level-=1;
      set_power();
    case 3344:  // left rocker/rewind
      if (power_level < 50)
        power_level-=3;
        power_level-=10;
      set_power();
    case 3345:  // right rocker/fast forward
        power_level+=3;
        power_level+=10;
      set_power();
    case 3352:  // play button
      blip_power();
    default:
      if (output_key)
        Serial.print("Key ");
        Serial.print(key);
        Serial.println(" not programmed");
  use pulseIn to receive IR pulses from the remote.
  Record the length of these pulses (in ms) in an array
void read_pulse(int pulse[], int num_bits)
  for (int i = 0; i < num_bits; i++)
    pulse[i] = pulseIn(IR_PIN, LOW);
  IR pulses encode binary "0" as a short pulse, and binary "1"
  as a long pulse.  Given an array containing pulse lengths,
  convert this to an array containing binary values
void pulse_to_bits(int pulse[], int bits[], int num_bits)
  if (DEBUG || runtime_debug) { Serial.println("-----"); }
  for(int i = 0; i < num_bits ; i++)
    if (DEBUG || runtime_debug) { Serial.println(pulse[i]); }
    if(pulse[i] > BIT_1) //is it a 1?
      bits[i] = 1;
    else if(pulse[i] > BIT_0) //is it a 0?
      bits[i] = 0;
    else //data is invalid...
      Serial.println("Error");
  convert an array of binary values to a single base-10 integer
int bits_to_int(int bits[], int num_bits)
  int result = 0;
  int seed = 1;
  //Convert bits to integer
  for(int i = 0 ; i < num_bits ; i++)
    if(bits[i] == 1)
	result += seed;
    seed *= 2;
  return result;
  set the brightness of the "power LED" depending on the power_level
  variable.
void set_power()
  power_level = constrain(power_level, 0, 200);
  analogWrite(POWER_PIN, power_level * power_button);
  // if the power level is above the max or below the min...
  if ((power_level == 200) || (power_level == 0))
    blink_led();
  make LED blink rapidly
void blink_led()
  for (int i = 0; i < 5; i++)
    analogWrite(LED_PIN, 0);
    delay(50);
    analogWrite(LED_PIN, 1);
    delay(50);
  neat little routine to fade both LEDs in a sequence.  Currently,
  this is called by do_response() when the "play" button is pressed.
void blip_power()
  int max_val = 100;
  for (int i = 0; i < max_val; i++)
    analogWrite(POWER_PIN, max_val-i);
    analogWrite(LED_PIN, i);
    delay(15);
  for (int i = max_val; i >= 0; i--)
    delay(15);
  set_power();
I appreciate ANY advice you have or any code I should try. My goal is to simply flash a few pins depending on the button i press. I was wondering if anyone knew about some simple code I can use to decode my remote and use it. Keep in mind, I am quite new to this, and the code I am using, I did not write.
Thanks in advance!
