Model.eim run without applab on arduino uno Q
Hi i am trying to deploy my object detection model.eim on arduino uno q without using applab and wants to get high fps how it can possible anyone help me please
As Q people are learning the Q Platform, please briefly explain what you talking about so that the novice readers may look into it.
Thanks,
Sorry I also don't really know much when it comes to these models and the like.
There are web pages on some related stuff like:
Arduino UNO Q Elf Detector Series - Part 4: Real-Time Object Detection with YOLOv5 | Foundries.io
But my guess is that you are wanting to use both processors? With Python on the one and Arduino on the other?
Not sure if you are completely not wanting to use their app or anything remotely associated with it.
But, you do have the options, including editing the sources using whatever tools you wish, and then transfer them to the Q several different ways, such as:
VisualStudioCode - with remote ... extension.
PuTTy/KiTTY and Winscp
You then can control running/stopping... the app using the command: arduino-app-cli
arduino@Uno-Q4:~$ arduino-app-cli
A CLI to manage Arduino Apps
Usage:
  arduino-app-cli [command]
Available Commands:
  app         Manage Arduino Apps
  brick       Manage Arduino Bricks
  completion  Generates completion scripts
  config      Manage Arduino App CLI config
  daemon      Run the Arduino App CLI as an HTTP daemon
  help        Help about any command
  monitor     Attach to the microcontroller serial monitor
  properties  Manage apps properties
  system      Manage the board’s system configuration
  version     Print the version number of Arduino App CLI
Flags:
      --format string      Output format (text, json) (default "text")
  -h, --help               help for arduino-app-cli
      --log-level string   Set the log level (debug, info, warn, error) (default "error")
Use "arduino-app-cli [command] --help" for more information about a command.
arduino@Uno-Q4:~$
As for getting speed, hopefully someone can help
