Hi All,
I have done my due diligence with Google University and have not reached an resolution. I am using the Modern Device Wind Sensor Rev P in a remediation system I am constructing. The flow measurements appear to be within a believable range, but I run in to an issue with the temp readings. Background of the setup: I have these sensors installed upstream of the 12v blower, and the Arduino is on the same battery source as the blower, with grounds tied together. The velocity and mass flow measurements are spot on, but run in to an issue with the temp. When the blower is off, the temp is spot on, but once the fan turns on, I have a major temp drop. Ambient is around 65F, which the sensor (MCP9701) reads without a problem, but when the fan turns on, the temp reading drops to around 16-18F. I assume I need to set up an equation to account for the wind speed, but have not found any documentation around this issue. Less a full scale wind tunnel test and regression, any ideas?
In case my coding is inducing this issue, it is below. Note, the addressing to the LCD screen has two lines with one commented out, I have 2 different addresses that are used, depends on the remediation system, I have to change the address based on the system being programed.
#include <Wire.h>
int WellNumber = 7;
//LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x3F, 20, 4);
LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 20, 4);
Hardware hookup for sensor
Sensor Arduino Pin
Ground Ground
+10-12V Vin
Out A0
TMP A2
Hardware hookup for LCD
Ground Ground
Vcc 5V
SDA A4
SCL A5
const int VelocityPin = A0;
const int NumVelocityReadings = 10;
int VelocityReadings[NumVelocityReadings];
int VelocityIndex = 0;
int VelocityTotal = 0;
int VelocityAverage = 0;
const int TempPin = A2;
const int NumTempReadings = 10;
int TempReadings[NumTempReadings];
int TempIndex = 0;
int TempTotal = 0;
int TempAverage = 0;
static char VelocityStr[5];
static char FlowStr[5];
static char TempStr[5];
float Dia = 2.0;
const float Pi = 3.14159;
////////////////////////////// Serial Setup //////////////////////////////
////////////////////////////// Initialize Velocity and Temp Arrays to Zero //////////////////////////////
for (int ThisVelocityReading = 0; ThisVelocityReading < NumVelocityReadings; ThisVelocityReading++) {
TempReadings[ThisVelocityReading] = 0;
for (int ThisTempReading = 0; ThisTempReading < NumTempReadings; ThisTempReading++) {
TempReadings[ThisTempReading] = 0;
////////////////////////////// Initialize LCD Screen and Run Screen Test //////////////////////////////
lcd.init();
lcd.backlight();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Display Test");
lcd.setCursor(0, 1);
lcd.print("Please Wait - 3");
lcd.print("Please Wait - 2");
lcd.print("Please Wait - 1");
lcd.clear();
lcd.setCursor(1, 0);
lcd.print("Monitoring Well ");
lcd.setCursor(17, 0);
if (WellNumber < 10) {
lcd.print("0");
lcd.print(WellNumber);
lcd.print("Velocity: ");
lcd.setCursor(17, 1);
lcd.print("FPM");
lcd.setCursor(2, 2);
lcd.print("Flow: ");
lcd.setCursor(15, 2);
lcd.print("CFM");
lcd.setCursor(2, 3);
lcd.print("Temp: ");
lcd.setCursor(15, 3);
lcd.print((char)223);
lcd.setCursor(16, 3);
lcd.print("F");
////////////////////////////// Raw Readings //////////////////////////////
int VelocityRAW = analogRead(VelocityPin); // read velocity
int TempRAW = analogRead(TempPin); //read temp
////////////////////////////// Velocity Averageing Calculations //////////////////////////////
VelocityTotal = VelocityTotal - VelocityReadings[VelocityIndex];
VelocityReadings[VelocityIndex] = analogRead(VelocityPin);
VelocityTotal = VelocityTotal + VelocityReadings[VelocityIndex];
VelocityIndex = VelocityIndex + 1;
if (VelocityIndex >= NumVelocityReadings) {
VelocityIndex = 0;
VelocityAverage = VelocityTotal / NumVelocityReadings;
////////////////////////////// Temperature Averaging Calculations //////////////////////////////
TempTotal = TempTotal - TempReadings[TempIndex];
TempReadings[TempIndex] = analogRead(TempPin);
TempTotal = TempTotal + TempReadings[TempIndex];
TempIndex = TempIndex + 1;
if (TempIndex >= NumTempReadings) {
TempIndex = 0;
TempAverage = TempTotal / NumTempReadings;
////////////////////////////// Velocity and Flow Rate Calculations //////////////////////////////
float VelocityMPH = pow((((float)VelocityAverage - 264.0) / 85.6814), 3.36814); // velocity formula derived from a wind tunnel data, annemometer and some fancy Excel regressions. formula provided by manufacturer and in miles per hour.
float VelocityFPM = VelocityMPH * 88.0; //convert from miles per hour to feet per minute
if (isnan(VelocityFPM)) {
lcd.setCursor(10, 1);
lcd.print(" ");
lcd.print("OFF");
if(VelocityFPM >= 1000){
dtostrf(VelocityFPM, 6, 1, VelocityStr);}
else{
dtostrf(VelocityFPM, 6, 2, VelocityStr);
lcd.print(" ");
lcd.print(VelocityStr);
float AreaSqIn = Pi * pow(((float)Dia / 2.0), 2); //calcuate cross sectional area of pipe in square inches
float AreaSqFt = AreaSqIn / 144; //convert from square inches to square feet
float FlowCFM = VelocityFPM * AreaSqFt;
if (isnan(FlowCFM)) {
lcd.setCursor(8, 2);
lcd.print(" ");
lcd.print("OFF");
dtostrf(FlowCFM, 6, 2, FlowStr);
lcd.print(" ");
lcd.print(FlowStr);
////////////////////////////// Temperature Calculations //////////////////////////////
float TempC = ((((float)TempAverage * 5.0) / 1024.0) - 0.400) / .0195; // convert to volts then use formula from datatsheet. Vout = ( TempC * .0195 ) + .400 tempC = (Vout - V0c) / TC see the MCP9701 datasheet for V0c and TC
float TempF = (TempC * (9.0 / 5.0)) + 32.0;
if (isnan(TempC)) {
lcd.setCursor(8, 3);
lcd.print(" ");
lcd.print("OFF");
dtostrf(TempF, 6, 2, TempStr);
lcd.print(" ");
lcd.print(TempStr);
delay(750);
