Modifying Array Entries in Inline Assembly: SOLVED
Hello,
I am trying to add entries to an array using inline assembly and then send the array out through the Native USB port on an Arduino Due
Currently I have a sensor connected to an Arduino Due that passes bytes of data that I am collecting.
I would like to place the bytes into the array using inline assembly code rather than using C code.
I have a working test code in C and I used the assembly dump from it to build a test version in assembly, but for some reason, it does not work.
C version:
uint32_t FIFO[512];
int cnt1 = 0;
int cnt2 = 0;
SerialUSB.begin(250000);
while(1)
  FIFO[cnt1] = 1;
  cnt1++;
  if (cnt1 == 512)
    cnt1 = 0;
  FIFO[cnt1] = 2;
  cnt1++;
  if (cnt1 == 512)
    cnt1 = 0;
  SerialUSB.println(FIFO[cnt2]);
  cnt2++;
  if (cnt2 == 512)
    cnt2 = 0;
  cnt2++;
  if (cnt2 == 512)
    cnt2 = 0;
Inline Assembly version:
uint32_t FIFO[512];
volatile uint32_t *addPointer = &FIFO[0];
int cnt = 0;
  __asm__ volatile( "MOV R9, #0\n\t");
  __asm__ volatile( "LDR R8, [%0]\n\t" ::"r"(&FIFO)); //I believe this is where the problem is
while(1)
  __asm__ volatile( "MOV R10, #1\n\t");
  __asm__ volatile( "STR.W R10, [R8, R9, LSL #2]\n\t");
  __asm__ volatile( "ADD R9, #1\n\t");
  __asm__ volatile( "CMP.W R9, #512\n\t");
  __asm__ volatile( "ITE EQ\n\t");
  __asm__ volatile( "MOVEQ R9, #0\n\t");
  __asm__ volatile( "NOPNE\n\t");
  __asm__ volatile( "MOV R10, #2\n\t");
  SerialUSB.println(FIFO[cnt]);
  cnt++;
  if(cnt == 512)
    cnt = 0;
  cnt++;
  if(cnt == 512)
    cnt = 0;
I believe that the problem with the code is finding the correct memory address for the first entry spot of FIFO, but I have no idea where that memory address is or how to find it.
Thanks so much for your time
EDIT: See reply #2 for solution
Why? By the time the compiler gets done, I seriously doubt that your assembler code will be any faster.
As opposed to just pointing to FIFO?
By convention, all capital letter names are reserved for constants. Writing to a constant doesn't make sense.
Thanks for the advice, I have changed the name of the array to Fifo now.
Also, I simplified the assembly code to the following and I have been getting the following error although I believe this is the correct syntax for what I want to do:
Error: cannot represent T32_OFFSET_IMM relocation in this object file format
Assembly Code:
uint32_t Fifo[512];
volatile uint32_t *addPointer = &Fifo[0];
  __asm__ volatile( "LDR R6, [%0]\n\t" ::"r"(addPointer));
  __asm__ volatile( "MOV R8, #1\n\t");
  __asm__ volatile( "STR R8, R6\n\t");
  SerialUSB.println(Fifo[0]);
I understand that I won't get too much extra efficiency out of this, but I would like to at least understand why it is not working.
Solution:
See below
Changes:
place '&' in front of addPointer in inline assembly
place [] around R6 in last line of inline assembly
Working Code:
uint32_t Fifo[512];
  __asm__ volatile( "LDR R6, [%0]\n\t" ::"r"(&addPointer));
  __asm__ volatile( "STR R8, [R6]\n\t");
