Module GSM A7670E I cannot send a message longer than 30 characters. not
I've been trying for a few days now, I've been reading on the internet and I can't find a solution.
please tell me what could be the cause.
messages longer than 30 characters are illegible, letters and special characters replaced.
I checked the same code on SIM800L and it works and long messages arrive.
#define RX_A7670E 4
#define TX_A7670E 5
#include <SoftwareSerial.h>
SoftwareSerial mySerial(RX_A7670E , TX_A7670E); // RX TX
#define RELAY 12
String receive_Sim = "";
String stateRelay= "off";
String nr_Tel = "+45xxxxxxxxx";
  pinMode(RELAY, OUTPUT);
  mySerial.begin(115200);
  delay(10000);
  while (!mySerial.available()) {
    mySerial.println("AT");
    Serial.println("Connecting...");
  Serial.println("Connected!");
  mySerial.println("AT+CMGF=1");
  mySerial.println("AT+CNMI=1,2,0,0,0");
  mySerial.println("AT+CMGL=\"REC UNREAD\"");
void On_Off_SMS() {
  if (receive_Sim.indexOf(nr_Tel) > -1) {
    if (receive_Sim.indexOf("On") > -1) {
      digitalWrite(RELAY, HIGH);
      stateRelay = "  Hello from Arduino. I would like to send long messages on the GSM module. I can't find a solution. Greetings to everyone and have a nice day";
      sendSMS();
      delay(200);
      receive_Sim = "";
      if (receive_Dane_Sim.indexOf("Off") > -1)  {
        digitalWrite(RELAY, LOW);
        stateRelay = "OFF";
        sendSMS();
        delay(200);
        receive_Sim = "";
  if (mySerial.available()) {
    delay(100);
    // Serial Buffer
    while (mySerial.available()) {
      receive_Sim = mySerial.readString();
    delay(10);
    Serial.println(receive_Sim);
    On_Off_SMS();
void sendSMS() {
  Serial.println("Sending SMS...");
  mySerial.print("AT+CMGF=1\r");
  delay(100);
  mySerial.print("AT+CMGS=\"+45xxxxxxxx\"\r");
  mySerial.print("Relay " + stateRelay);
  mySerial.print((char)26);// (required according to the datasheet)
  mySerial.println();
  Serial.println("text");
Most likely a limit of some sort, the first S i SMS I think is for Small or Short. READ the datasheets.
exactly. It looks like there's a limit. I read but found nothing. maybe I missed something because there are many pages of documentation.
Most people who are not programmers don't understand that we only spend maybe 20% of our time coding, and 60% reading, researching etc. Give me a few minutes to see if I can find the answer. A quick google tells me at least 160 chars, so it must be something else. I will grab your code and have a quick peek for anything obvious. At 82yo it needs to be obvious LOL
what board are you using, nano, esp32 ???
Also what SoftwareSerial library?
First thing is to get rid of ALL the delay statements.Do some research on using millis() to emulate multi-tasking. This will likely require a reorganization of your code, but itg will make it better. Look for articles and samples that have scheduker or 'get rid of delay' or similar, there is a lot on the arduino site alone.
Thank you for your interest, I have the module connected, everything works great, but I still have a problem with long messages.
I use wemos d1 mini and the library and software serial
I changed the power supply to a 3A power supply and it didn't help either.
maybe I should use a different board and use the hardware serial?
<<< EDIT >>>
Success, I guess I solved my problem. I send 100 characters and everything is readable.
I used hardware serial 115200 and everything works.
