Modulino library won't install
Continuing the discussion from Modulino Distance on QWIIC can not be read:
Hey, i cannot seem to be able to download the mdoulino library. I rpess install but it doesnt install. Also how do you get the messages in the monitor window? I am suing the uno Q dongled to screen and keypad, but I cannot seem to understand how to view the outpout fron the serial monitor. The monitor window keeps “silent“. could you share more of this project?
Hi @Pota_Mota.
I apologize for the inconvenience. This is caused by a known bug in Arduino App Lab:
The developers have already prepared a fix, but there hasn't been a new release of Arduino App CLI since that time, so this is why you still encounter the problem. The fix will be in the next release and Arduino App Lab automatically updates, so you don't need to take any special action to get the fix.
I'll provide instructions you can follow to work around the bug now:
  1. Click the "Applications" button at the top left corner of the UNO Q's Linux desktop.
    A menu will open.
  2. Select "Terminal Emulator" from the menu.
    A "Terminal" window will open.
  3. Type the following command at the command line prompt in the "Terminal" window:
    arduino-cli lib update-index
  4. You should now see a "Downloading index" process start, with a progress indicator. Wait for the command to finish successfully.
Now try installing the library again. Please note that the library has been renamed from "Modulino" to "Arduino_Modulino", so that is the name of the library you will be installing.
Hopefully the library will now install successfully and everything will work as expected. If you still have any problems, just let us know and we'll provide further assistance.
Did you encounter this problem while using the sketch code shared by @umbertones?:
That code should work as expected. However, if you were not able to install the library the sketch depends on, then you would not have been able to run that sketch, so I suspect you were instead using some other code. If so, please provide the full code of the sketch you were using when you encountered the Serial Monitor problem in a reply here on this forum topic and we'll take a look.
