Edited
Start by reading this page: https://www.arduino.cc/en/Tutorial/BuiltInExamples/StateChangeDetection.
You might have to "debounce" the button.
There are libraries that have both the "debounce" and the State Change Detection.
I think I have to add a variable to change when the button is pushed. I think this is close, but it is still not working.
#include<Servo.h>
Servo Myservo;
bool DoAction1=false;
pinMode(2,INPUT);
Myservo.attach(3);
if(digitalRead(2)==LOW)
DoAction1=true;
if(DoAction1==true)
Myservo.write(180);
Myservo.write(100);
delay(5000);
Myservo.write(180);
Myservo.write(130);
DoAction1=false;
DoAction1=false;
Myservo.write(130);
A better way to use momentary switches is to wire them to ground and use the internal pullup resistor (pinMode(pin INPUT_PULLUP);). My stated change tutorial shows how to do state change with active low (wired to ground) switches.
Read the forum guidelines to see how to properly post code.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
That is a useless description of the problem. The code does something, what is it? How is that different from what you want.
the code stops when the button is released. I want it to finish running even when the button is released.
Here is example to show how to so that using the state change detection method. This performs the action when the button becomes pressed (the transition from high to low) instead of when the button is pressed (the level). The next challenge is to get rid of delays. Here the code is posted properly in code tags and indented for readability with the IDE auto format tool. See post #5.
#include<Servo.h>
Servo Myservo;
//bool DoAction1 = false;
const byte buttonPin = 2;
const byte servoPin = 3;
bool buttonState = 0; // current state of the button
bool lastButtonState = 0; // previous state of the button
pinMode(buttonPin, INPUT_PULLUP);
Myservo.attach(servoPin);
static unsigned long timer = 0;
unsigned long interval = 50; // check switch 20 times per second
if (millis() - timer >= interval)
timer = millis();
buttonState = digitalRead(buttonPin);
if (buttonState != lastButtonState)
if (buttonState == LOW)
Serial.print("go to 180");
Myservo.write(180);
Serial.print(" go to 100");
Myservo.write(100);
delay(5000);
Serial.print(" go to 180");
Myservo.write(180);
Serial.print(" go to 130");
Myservo.write(130);
Serial.print("finished");
lastButtonState = buttonState;
With a state machine:
// Version YY/MM/DD Description
// 1.00 21/08/06
#include<Servo.h>
Servo myServo;
#define switchIsClosed LOW
#define switchIsOpen HIGH
#define enabled true
#define disabled false
bool timingFlag = disabled;
const byte mySwitch = 2; //+5V----[50k internal pull-up]----[switch]----GND
const byte heartbeatLED = 13;
byte lastSwitchState = switchIsOpen;
int mState = 0;
//timing stuff
unsigned long heartbeatMillis;
unsigned long switchMillis;
unsigned long commonTimerMillis;
pinMode(heartbeatLED, OUTPUT);
pinMode(mySwitch, INPUT_PULLUP);
myServo.attach(servoPin);
myServo.write(130);
} //END of setup()
//time to toggle the heartbeatLED (every 1/2 second) ?
if (millis() - heartbeatMillis >= 500)
//restart the TIMER
heartbeatMillis = millis();
//toggle the LED
digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
//time to check the switches (every 50ms) ?
if (millis() - switchMillis >= 50)
//restart the TIMER
switchMillis = millis();
checkSwitches();
//if we are timing, check the state machine ?
if (timingFlag == enabled)
stateMachine();
//other non-blocking code
} //END of loop()
void stateMachine()
switch (mState)
case 0:
//do nothing
case 1:
if (millis() - commonTimerMillis >= 500)
//move servo
myServo.write(100);
//next state
mState = 2;
//restart the TIMER
commonTimerMillis = millis();
case 2:
if (millis() - commonTimerMillis >= 5000)
//move servo
myServo.write(180);
//next state
mState = 3;
//restart the TIMER
case 3:
//move servo
myServo.write(130);
//next state
mState = 0;
//disable the TIMER
} //END of stateMachine()
void checkSwitches()
byte state;
//***************************************** mySwitch
state = digitalRead(mySwitch);
//has the switch changed state ?
if (lastSwitchState != state)
//update to the new state
lastSwitchState = state;
//if we are not timing, was the switch closed ?
if (timingFlag == disabled && state == switchIsClosed)
//enable the TIMER
timingFlag = enabled;
//start the servo sequence
mState = 1;
//move servo
myServo.write(180);
//start the TIMER
} //END of if (lastSwitchState != state)
} //END of checkSwitches()
