I'm trying to run a 3.7v pump (https://aliexpress.ru/item/1005007462476619.html?sku_id=12000041172228789) using following Mosfet Optocoupler module https://aliexpress.ru/item/1005005933522519.html?sku_id=12000034909573598 (FR120N)
Optron is controlled by wemos D1 mini through a web page, and when testing the whole circuit with pump replaced by LED - no issues raise, all is working correctly (enabling led by schedule, manually, manually with PWM).
However when led is replaced by Pump - pump just fails to start. There is small led on the mosfet optocoupler so when optron is closed - it is burning red. However when pump is enabled this small led just blinks slightly on start and immediately switches off.
When pump is connected directly to battery - it starts without any issues, but through an optocoupler it just does nothing. When PWM is lowered to any value below 100% I just hear peep sound from the pump.
What am I doing wrong? I have 3 same optocoupler mosfet modules, issue is the same for each. Mosfet seems capable of starting this pump, but still nothing.
Battery is connected to + and -, pump (or LED as on the photo) is connected + to + and - to Load.
I don't see any detailed specs or application data for either part. The MOSFET might need more gate voltage to operate properly.
Here is a MOSFET driver circuit if you want to build one yourself. But a logic-level MOSFET normally needs 5V at the gate to turn it fully-on so it might not work if you only have 3.3 or 3.7v.
A regular bipolar transistor turns-on with less than 1V. They generally can't handle as much current as MOSFET but the right transistor can probably drive that little motor. (The driver circuit would be slightly different.)
Wemos is powered separately, didn't mention it on the picture.
Yes, I have DMM, once optron is triggered I have same voltage on the pump powerline as on the battery (4.1v). However if I connect the pump to this powerline - voltage drops to 247mv.
Looks like some kind of "protection" to me
