Motor Shield V3 and Mega 2560 V3 ?
Hello,
would like to ask for help, do not get the setup to run.
UNO runs fine, but Mega not, what is the difference?
Library: all with Motor Shield tried / installed
running this Code:
const int MotorPinA = 12; // for motor A
const int MotorSpeedPinA = 3; // for motor A
const int MotorBrakePinA = 9; // for motor A
const int CW  = HIGH;
const int CCW = LOW;
  // motor A pin assignment
  pinMode(MotorPinA, OUTPUT);
  pinMode(MotorSpeedPinA, OUTPUT);
  pinMode(MotorBrakePinA, OUTPUT);
  Serial.begin(9600);//  seial monitor initialized
  //start motor A at maximum speed
  digitalWrite(MotorPinA, CW);// set direction
      Serial.println("Direction CW");
  analogWrite(MotorSpeedPinA, 100);// set speed at maximum
      Serial.println("Speed 100");
  delay(5000);// run for 5 seconds
  digitalWrite(MotorBrakePinA, HIGH);// brake
      Serial.println("Brake applied");
  delay(2000);
  digitalWrite(MotorBrakePinA,LOW);// release brake
      Serial.println("Brake removed");
  digitalWrite(MotorPinA, CCW);// set direction
      Serial.println("Direction CWW");
  analogWrite(MotorSpeedPinA, 70);// set to 1/3
      Serial.println("Speed at 70");
  delay(5000);//
}// loop end
What happens when you run it on the Mega ?
How is the system powered ?
Nothing, non Led lightning on shield.
External 12v connected on shield, runs Uno/Mega via Vin.
DC 12V Motor runs fine on UNO.
The code does not seem to use a library so what does this mean ?
non Led lightning.
Which LED is that ?
Library, nothing, I am an starter.
The 2 LED's for the Motor A are lightning during run of the Motor plugged on the UNO.
Maybe some pics of how the shield is mounted on the mega.
Also are you using the MEGA to power the board or an external source.
If it is an external source have you used either a jumper or track cut to tell the shield to use external power ?
Bob.
Shield on Mega is mounted to the pins as shown on Mega and Shield, means in front to usb. So the shield is mounted on the Mega is the same as UNO.
Only the ext. Power of the shield is used, UNO & Mega are powerd over it via Vin (when plugged into PC, also via USB).
Do not know of a jumper on the shield, only the cuttable connection on the backside, but still good to power UNO / Mega.
Clear, or still something not told? Just reply i try my best to answer as good as possible.
Shoud I try a differenct code ? Library? Is there a original Arduino Library for the Shield available?
Here some pics
