MPU-6050 Code und Lib Fehler bei Kompilieren
Hey Forum.
Heute habe ich einen MPU-6050 bekommen und wollte einfach die Daten auslesen zum testen.
Jedoch bekomme ich diese Fehlermeldung beim kompilieren (siehe Bild).
Mit dem Code von Arduino klappts jedoch.
Hier ist noch der Code https://docs.google.com/file/d/0B2_rhDNAxM4sbkk0Y0htaXo1bVE/edit
MPU-6050
// I2C device class (I2Cdev) demonstration Arduino sketch for MPU6050 class
// 10/7/2011 by Jeff Rowberg <jeff@rowberg.net>
// Updates should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
// Changelog:
//      2013-05-08 - added multiple output formats
//                 - added seamless Fastwire support
//      2011-10-07 - initial release
I2Cdev device library code is placed under the MIT license
Copyright (c) 2011 Jeff Rowberg
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050.h"
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 accelgyro;
//MPU6050 accelgyro(0x69); // <-- use for AD0 high
int16_t ax, ay, az;
int16_t gx, gy, gz;
// uncomment "OUTPUT_READABLE_ACCELGYRO" if you want to see a tab-separated
// list of the accel X/Y/Z and then gyro X/Y/Z values in decimal. Easy to read,
// not so easy to parse, and slow(er) over UART.
#define OUTPUT_READABLE_ACCELGYRO
// uncomment "OUTPUT_BINARY_ACCELGYRO" to send all 6 axes of data as 16-bit
// binary, one right after the other. This is very fast (as fast as possible
// without compression or data loss), and easy to parse, but impossible to read
// for a human.
//#define OUTPUT_BINARY_ACCELGYRO
#define LED_PIN 13
bool blinkState = false;
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
    // initialize serial communication
    // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
    // it's really up to you depending on your project)
    Serial.begin(38400);
    // initialize device
    Serial.println("Initializing I2C devices...");
    accelgyro.initialize();
    // verify connection
    Serial.println("Testing device connections...");
    Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
    // use the code below to change accel/gyro offset values
    Serial.println("Updating internal sensor offsets...");
    // -76	-2359	1688	0	0	0
    Serial.print(accelgyro.getXAccelOffset()); Serial.print("\t"); // -76
    Serial.print(accelgyro.getYAccelOffset()); Serial.print("\t"); // -2359
    Serial.print(accelgyro.getZAccelOffset()); Serial.print("\t"); // 1688
    Serial.print(accelgyro.getXGyroOffset()); Serial.print("\t"); // 0
    Serial.print(accelgyro.getYGyroOffset()); Serial.print("\t"); // 0
    Serial.print(accelgyro.getZGyroOffset()); Serial.print("\t"); // 0
    Serial.print("\n");
    accelgyro.setXGyroOffset(220);
    accelgyro.setYGyroOffset(76);
    accelgyro.setZGyroOffset(-85);
    Serial.print("\n");
    // configure Arduino LED for
    pinMode(LED_PIN, OUTPUT);
    // read raw accel/gyro measurements from device
    accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    // these methods (and a few others) are also available
    //accelgyro.getAcceleration(&ax, &ay, &az);
    //accelgyro.getRotation(&gx, &gy, &gz);
    #ifdef OUTPUT_READABLE_ACCELGYRO
        // display tab-separated accel/gyro x/y/z values
        Serial.print("a/g:\t");
        Serial.print(ax); Serial.print("\t");
        Serial.print(ay); Serial.print("\t");
        Serial.print(az); Serial.print("\t");
        Serial.print(gx); Serial.print("\t");
        Serial.print(gy); Serial.print("\t");
        Serial.println(gz);
    #endif
    #ifdef OUTPUT_BINARY_ACCELGYRO
        Serial.write((uint8_t)(ax >> 8)); Serial.write((uint8_t)(ax & 0xFF));
        Serial.write((uint8_t)(ay >> 8)); Serial.write((uint8_t)(ay & 0xFF));
        Serial.write((uint8_t)(az >> 8)); Serial.write((uint8_t)(az & 0xFF));
        Serial.write((uint8_t)(gx >> 8)); Serial.write((uint8_t)(gx & 0xFF));
        Serial.write((uint8_t)(gy >> 8)); Serial.write((uint8_t)(gy & 0xFF));
        Serial.write((uint8_t)(gz >> 8)); Serial.write((uint8_t)(gz & 0xFF));
    #endif
    // blink LED to indicate activity
    blinkState = !blinkState;
    digitalWrite(LED_PIN, blinkState);
Man brauch noch die MPU-6050.h und die I2C Datei.
Danke schon mal :slight_smile:
Würde vielleicht jemand mal den Sketch ausprobieren und einfach nur kompilieren, damit ich mögliche Fehler ausschließen kann ?
Danke :slight_smile:
Ziemlich richtig: die MPU6050.h wird er bei dir nicht richtig gefunden haben.
( Ohne das MinusZeichen übrigens )
sucht zuerst im Sketch - Ordner
alternativ
#include <MPU6050.h> // sucht in Libraries\MPU6050
-- hab es nicht probiert, nur dein Bild angeguckt. (Fehler kann man übrigens auch als Text kopieren )
Danke für den Hinweis michael_x. Jetzt, wo ich die Dateien im lib Ordner Ordner von der Arduino IDE habe kommen die Fehlermeldungen nicht mehr :slight_smile:
Beim nächsten Update sind sie wieder weg, das ist dir sicher klar.
Da wo diene Sketche sind, sollte es auch einen Ordner libraries geben, die Unterverzeichnisse dort sollten auch gefunden werden, auch wenn du mal eine neue IDE installierst.
Hallo,
ich wollte jetzt nicht extra einen neuen Topic aufmachen, deswegen zieh ich den hier mal wieder hoch.
Habe nämlich einen ähnlichen Fehler.
Kurze Beschreibung.
Habe mir einen MPU6050 auf einem GY521 board gekauft.
--> Auf Arduino Playground geschaut
--> Mir den I2C Scanner und die FreeIMU Zip datei herunter geladen -->varesano.net -
--> MPU6050 angeschlossen I2C Scanner erkennt Device, wie beschrieben.
-->Zip.Datei extrahiert
--> Wie im Playground beschrieben alle Libraries in den Arduino Librarie Ordner kopiert
--> Example sketch arduino.raw geöffnet --> Fehler beim Kompilieren
--> Libraries über Librarie einfügen ins Programm geladen---> siehe Code unten--> Fehler beim Kompilieren
--> Habe jetzt schon X-Mal die Libs wieder gelöscht und neu installiert, irgend einen Fehler findet er immer beim Kompilieren.
--> Dann einen Sketch mit einer Anweisung erstellt und nur die Libs rein geladen--> Fehler beim Kompilieren
So langsam bin ich am Verzweifeln, hat irgendwer da einen Lösungsansatz für mich?
Sind die Libs von FreeIMU vielleicht veraltet oder beschädigt?
Für konstruktive Beiträge wäre ich sehr sehr dankbar.
Gruß
#include <Wire.h>
#include <I2Cdev.h>
#include <MPU60X0.h>
// Changelog:
THE SOFTWARE.
//#include "Wire.h"
//#include "I2Cdev.h"
//#include "MPU6050.h"
// AD0 high = 0x69
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
#define LED_PIN 13
    Wire.begin();
    Serial.println(gz);
@ Icke84
Könntest du vielleicht mal die Fehlermeldungen posten ?
Für den Segway hatte ich schon einige ausprobiert mit dieser hier war ich bis jetzt am besten bediend da die umsetztung des Kalmanfilters hier gernial ist.
https://github.com/TKJElectronics/KalmanFilter/tree/master/examples/MPU6050
Gruß
Der Dani
