MPU6050_DMP6 compiling error message [SOLVED]
Hello,
I am trying to download the example sketch for the MPU6050 IMU (MPU6050_DMP6). The raw data example compiles and uploads ok but the DMP6 example will not compile and gives the following error messages.
Any advice would be much appreciated.
Steve
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from MPU6050_DMP6.ino:48:0:
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:89:7: error: 'prog_uchar' does not name a type
const prog_uchar dmpMemory[MPU6050_DMP_CODE_SIZE] PROGMEM = {
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:229:7: error: 'prog_uchar' does not name a type
const prog_uchar dmpConfig[MPU6050_DMP_CONFIG_SIZE] PROGMEM = {
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:271:7: error: 'prog_uchar' does not name a type
const prog_uchar dmpUpdates[MPU6050_DMP_UPDATES_SIZE] PROGMEM = {
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h: In member function 'uint8_t MPU6050::dmpInitialize()':
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:342:30: error: 'dmpMemory' was not declared in this scope
if (writeProgMemoryBlock(dmpMemory, MPU6050_DMP_CODE_SIZE)) {
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:349:42: error: 'dmpConfig' was not declared in this scope
if (writeProgDMPConfigurationSet(dmpConfig, MPU6050_DMP_CONFIG_SIZE)) {
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
from C:\Users\my name\Documents\Arduino\libraries\I2Cdev/I2Cdev.h:74,
from MPU6050_DMP6.ino:46:
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:390:98: error: 'dmpUpdates' was not declared in this scope
for (j = 0; j < 4 || j < dmpUpdate[2] + 3; j++, pos++) dmpUpdate[j] = pgm_read_byte(&dmpUpdates[pos]);
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:394:98: error: 'dmpUpdates' was not declared in this scope
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:433:98: error: 'dmpUpdates' was not declared in this scope
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:437:98: error: 'dmpUpdates' was not declared in this scope
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:441:98: error: 'dmpUpdates' was not declared in this scope
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:459:98: error: 'dmpUpdates' was not declared in this scope
C:\Users\my name\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:478:98: error: 'dmpUpdates' was not declared in this scope
Error compiling.
enabled in File > Preferences.
Hello Delta_G and thanks,
Here is the first part of the sketch I am trying to compile (too big to post the whole sketch in one post on this forum). I haven't written it or the libraries myself as they are downloaded examples straight from Jeff Rowbergs site. I do realise the error messages relate to undeclared variables but I'm not sure why these errors would occur as I would have thought the libraries would be compatible with the sketches. Ís it possibly a problem with Windows 10 and Arduino IDE 1.6.5 compatibility?
Cheers,
Steve
// I2C device class (I2Cdev) demonstration Arduino sketch for MPU6050 class using DMP (MotionApps v2.0)
// 6/21/2012 by Jeff Rowberg <jeff@rowberg.net>
// Updates should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
// Changelog:
//      2013-05-08 - added seamless Fastwire support
//                 - added note about gyro calibration
//      2012-06-21 - added note about Arduino 1.0.1 + Leonardo compatibility error
//      2012-06-20 - improved FIFO overflow handling and simplified read process
//      2012-06-19 - completely rearranged DMP initialization code and simplification
//      2012-06-13 - pull gyro and accel data from FIFO packet instead of reading directly
//      2012-06-09 - fix broken FIFO read sequence and change interrupt detection to RISING
//      2012-06-05 - add gravity-compensated initial reference frame acceleration output
//                 - add 3D math helper file to DMP6 example sketch
//                 - add Euler output and Yaw/Pitch/Roll output formats
//      2012-06-04 - remove accel offset clearing for better results (thanks Sungon Lee)
//      2012-06-01 - fixed gyro sensitivity to be 2000 deg/sec instead of 250
//      2012-05-30 - basic DMP initialization working
I2Cdev device library code is placed under the MIT license
Copyright (c) 2012 Jeff Rowberg
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
//#include "MPU6050.h" // not necessary if using MotionApps include file
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for SparkFun breakout and InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 mpu;
//MPU6050 mpu(0x69); // <-- use for AD0 high
   NOTE: In addition to connection 3.3v, GND, SDA, and SCL, this sketch
   depends on the MPU-6050's INT pin being connected to the Arduino's
   external interrupt #0 pin. On the Arduino Uno and Mega 2560, this is
   digital I/O pin 2.
   NOTE: Arduino v1.0.1 with the Leonardo board generates a compile error
   when using Serial.write(buf, len). The Teapot output uses this method.
   The solution requires a modification to the Arduino USBAPI.h file, which
   is fortunately simple, but annoying. This will be fixed in the next IDE
   release. For more info, see these links:
   http://arduino.cc/forum/index.php/topic,109987.0.html
   http://code.google.com/p/arduino/issues/detail?id=958
// uncomment "OUTPUT_READABLE_QUATERNION" if you want to see the actual
// quaternion components in a [w, x, y, z] format (not best for parsing
// on a remote host such as Processing or something though)
//#define OUTPUT_READABLE_QUATERNION
// uncomment "OUTPUT_READABLE_EULER" if you want to see Euler angles
// (in degrees) calculated from the quaternions coming from the FIFO.
// Note that Euler angles suffer from gimbal lock (for more info, see
// http://en.wikipedia.org/wiki/Gimbal_lock)
//#define OUTPUT_READABLE_EULER
// uncomment "OUTPUT_READABLE_YAWPITCHROLL" if you want to see the yaw/
// pitch/roll angles (in degrees) calculated from the quaternions coming
// from the FIFO. Note this also requires gravity vector calculations.
// Also note that yaw/pitch/roll angles suffer from gimbal lock (for
// more info, see: http://en.wikipedia.org/wiki/Gimbal_lock)
#define OUTPUT_READABLE_YAWPITCHROLL
// uncomment "OUTPUT_READABLE_REALACCEL" if you want to see acceleration
// components with gravity removed. This acceleration reference frame is
// not compensated for orientation, so +X is always +X according to the
// sensor, just without the effects of gravity. If you want acceleration
// compensated for orientation, us OUTPUT_READABLE_WORLDACCEL instead.
//#define OUTPUT_READABLE_REALACCEL
// uncomment "OUTPUT_READABLE_WORLDACCEL" if you want to see acceleration
// components with gravity removed and adjusted for the world frame of
// reference (yaw is relative to initial orientation, since no magnetometer
// is present in this case). Could be quite handy in some cases.
//#define OUTPUT_READABLE_WORLDACCEL
// uncomment "OUTPUT_TEAPOT" if you want output that matches the
// format used for the InvenSense teapot demo
//#define OUTPUT_TEAPOT
#define INTERRUPT_PIN 2  // use pin 2 on Arduino Uno & most boards
#define LED_PIN 13 // (Arduino is 13, Teensy is 11, Teensy++ is 6)
bool blinkState = false;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
// packet structure for InvenSense teapot demo
uint8_t teapotPacket[14] = { '
, 0x02, 0,0, 0,0, 0,0, 0,0, 0x00, 0x00, '\r', '\n' };
And here is part of the MPU6050_6Axis_MotionApps20.h code where the error messages seem to come from.
// I2Cdev library collection - MPU6050 I2C device class, 6-axis MotionApps 2.0 implementation
// Based on InvenSense MPU-6050 register map document rev. 2.0, 5/19/2011 (RM-MPU-6000A-00)
// 5/20/2013 by Jeff Rowberg jeff@rowberg.net
// Updates should (hopefully) always be available at GitHub - jrowberg/i2cdevlib: I2C device library collection for AVR/Arduino or other C++-based MCUs
// Changelog:
// ... - ongoing debug release
THE SOFTWARE.
#ifndef MPU6050_6AXIS_MOTIONAPPS20_H
#define MPU6050_6AXIS_MOTIONAPPS20_H
#include "I2Cdev.h"
#include "helper_3dmath.h"
// MotionApps 2.0 DMP implementation, built using the MPU-6050EVB evaluation board
#define MPU6050_INCLUDE_DMP_MOTIONAPPS20
// Tom Carpenter's conditional PROGMEM code
// pgmspace.h is not supported? - Arduino Due - Arduino Forum
#ifdef AVR
#include <avr/pgmspace.h>
#else
// Teensy 3.0 library conditional PROGMEM code from Paul Stoffregen
#ifndef _PGMSPACE_H
#define _PGMSPACE_H 1
#include <inttypes.h>
#define PROGMEM
#define PGM_P const char *
#define PSTR(str) (str)
#define F(x) x
typedef void prog_void;
typedef char prog_char;
typedef unsigned char prog_uchar;
typedef int8_t prog_int8_t;
typedef uint8_t prog_uint8_t;
typedef int16_t prog_int16_t;
typedef uint16_t prog_uint16_t;
typedef int32_t prog_int32_t;
typedef uint32_t prog_uint32_t;
#define strcpy_P(dest, src) strcpy((dest), (src))
#define strcat_P(dest, src) strcat((dest), (src))
#define strcmp_P(a, b) strcmp((a), (b))
#define pgm_read_byte(addr) (*(const unsigned char )(addr))
#define pgm_read_word(addr) (
(const unsigned short )(addr))
#define pgm_read_dword(addr) (
(const unsigned long )(addr))
#define pgm_read_float(addr) (
(const float *)(addr))
#define pgm_read_byte_near(addr) pgm_read_byte(addr)
#define pgm_read_word_near(addr) pgm_read_word(addr)
#define pgm_read_dword_near(addr) pgm_read_dword(addr)
#define pgm_read_float_near(addr) pgm_read_float(addr)
#define pgm_read_byte_far(addr) pgm_read_byte(addr)
#define pgm_read_word_far(addr) pgm_read_word(addr)
#define pgm_read_dword_far(addr) pgm_read_dword(addr)
#define pgm_read_float_far(addr) pgm_read_float(addr)
#endif
#endif
/* Source is from the InvenSense MotionApps v2 demo code. Original source is
  • unavailable, unless you happen to be amazing as decompiling binary by
  • hand (in which case, please contact me, and I'm totally serious).
  • Also, I'd like to offer many, many thanks to Noah Zerkin for all of the
  • DMP reverse-engineering he did to help make this bit of wizardry
  • possible.
// NOTE! Enabling DEBUG adds about 3.3kB to the flash program size.
// Debug output is now working even on ATMega328P MCUs (e.g. Arduino Uno)
// after moving string constants to flash memory storage using the F()
// compiler macro (Arduino IDE 1.0+ required).
It looks like the problem was with the file paths for the libraries on my windows 10 computer. I downloaded a balancing robot sketch that uses the same libraries as the MPU6050_DMP6 sketch and it compiled without any problems. I then substituted the MPU6050_DMP_6 sketch and it also compiled without any problems.
Fingers crossed the problem is solved.
Cheers,
Steve
