MPU 6050 (GY 521) + Mega 2560
Hello all,
I am doing a project in which it requires the accelerations of hand. So, I purchased an accelerometer MPU 6050 (GY 521) and Arduino Mega 2560. I did not show the accelerations on my serial screen whenever I move the accelerometer.
Please help me in getting me the connections and code.
My connections - Vcc to 5v ; GND to GND; SCL to SCL 21; SDA to SDA 20
#include <Wire.h>
        //Declaring some global variables
int gyro_x, gyro_y, gyro_z;
long gyro_x_cal, gyro_y_cal, gyro_z_cal;
boolean set_gyro_angles;
long acc_x, acc_y, acc_z, acc_total_vector;
float angle_roll_acc, angle_pitch_acc;
float angle_pitch, angle_roll;
int angle_pitch_buffer, angle_roll_buffer;
float angle_pitch_output, angle_roll_output;
long loop_timer;
int temp;
  Wire.begin();        //Start I2C as master
  setup_mpu_6050_registers();                                            //Setup the registers of the MPU-6050
 for (int cal_int = 0; cal_int < 1000 ; cal_int ++){                  //Read the raw acc and gyro data from the
MPU-6050 for 1000 times
    read_mpu_6050_data();
    gyro_x_cal += gyro_x;
    gyro_y_cal += gyro_y;
    gyro_z_cal += gyro_z;
    delay(3);
  // divide by 1000 to get avarage offset
  gyro_x_cal /= 1000;
  gyro_y_cal /= 1000;
  gyro_z_cal /= 1000;
  loop_timer = micros();                                               //Reset the loop timer
void loop(){
                                           //Subtract the offset values from the raw gyro values
  gyro_x -= gyro_x_cal;
  gyro_y -= gyro_y_cal;
  gyro_z -= gyro_z_cal;
  //Gyro angle calculations . Note 0.0000611 = 1 / (250Hz x 65.5)
 angle_pitch += gyro_x * 0.0000611;
 angle_roll += gyro_y * 0.0000611;                   /
  angle_pitch += angle_roll * sin(gyro_z * 0.000001066);               //If the IMU has yawed transfer the roll angle to the pitch angel
  angle_roll -= angle_pitch * sin(gyro_z * 0.000001066);               //If the IMU has yawed transfer the pitch angle to the roll angel
  //Accelerometer angle calculations
acc_total_vector = sqrt((acc_x*acc_x)+(acc_y*acc_y)+(acc_z*acc_z));
  angle_pitch_acc = asin((float)acc_y/acc_total_vector)* 57.296;       //Calculate the pitch angle
 angle_roll_acc = asin((float)acc_x/acc_total_vector)* -57.296;       //Calculate the roll angle
  angle_pitch_acc -= 0.0;                                              //Accelerometer calibration value for pitch
  angle_roll_acc -= 0.0;                                               //Accelerometer calibration value for roll
  if(set_gyro_angles){
    angle_pitch = angle_pitch * 0.9996 + angle_pitch_acc * 0.0004;
    angle_roll = angle_roll * 0.9996 + angle_roll_acc * 0.0004;
  else{                                                            //At first start
    angle_pitch = angle_pitch_acc;                 //Set the gyro pitch angle equal to the accelerometer pitch angle
    angle_roll = angle_roll_acc;                     //Set the gyro roll angle equal to the accelerometer roll angle
    set_gyro_angles = true;                              //Set the IMU started flag
  angle_pitch_output = angle_pitch_output * 0.9 + angle_pitch * 0.1;
  angle_roll_output = angle_roll_output * 0.9 + angle_roll * 0.1;
  Serial.print(" | Angle_1  = "); Serial.print(angle_pitch_output); Serial.print("  ----------------  ");
  Serial.print(" | Angle_2  = "); Serial.println(angle_roll_output);
 while(micros() - loop_timer < 4000);
void setup_mpu_6050_registers(){
  //Activate the MPU-6050
  Wire.beginTransmission(0x68);                                        //Start communicating with the MPU-6050
  Wire.write(0x6B);                                                    //Send the requested starting register
  Wire.write(0x00);                                                    //Set the requested starting register
  Wire.endTransmission();
  //Configure the accelerometer (+/-8g)
  Wire.write(0x1C);                                                    //Send the requested starting register
  Wire.write(0x10);                                                    //Set the requested starting register
  //Configure the gyro (500dps full scale)
  Wire.write(0x1B);                                                         //Send the requested starting register
  Wire.write(0x08);                                                          //Set the requested starting register
void read_mpu_6050_data(){                                             //Subroutine for reading the raw gyro and accelerometer data
  Wire.write(0x3B);                                                           //Send the requested starting register
  Wire.endTransmission();                                                 //End the transmission
  Wire.requestFrom(0x68,14);                                           //Request 14 bytes from the MPU-6050
  while(Wire.available() < 14);                                          //Wait until all the bytes are received
  acc_x = Wire.read()<<8|Wire.read();
  acc_y = Wire.read()<<8|Wire.read();
  acc_z = Wire.read()<<8|Wire.read();
  temp = Wire.read()<<8|Wire.read();
  gyro_x = Wire.read()<<8|Wire.read();
  gyro_y = Wire.read()<<8|Wire.read();
  gyro_z = Wire.read()<<8|Wire.read();
How to solve these things? where this code works on Arduino UNO
Thanks a lot in advance.
W. Hamanah
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Please, use code tags for source code. :confused:
I used code and the its library for this link:
Its works with me in UNO but when downloaded code in Mega, it does not show any things on the serial monitor.
I used code and its library for this link:
Is there any adjusting or adding to make it work on arduino Mega 2560?
The I2C pins are not A4 and A5 on a Mega. They are pins 20 (SDA) and 21 (SCL).
Read the "how to use this forum-please read" sticky.
It is better to use pins next to AREF (Arduino R3 version). They are marked SDA, SCL on bottom side of board.
@WaleedMohammed, do not hijack. Thread split.
Mira a ver si te vale este:
Solo he incluido alguna libreria y cambiado Serial.begin(9600);
#include "Wire.h"
#include "MPU6050.h"
#include "I2Cdev.h"
long loop_timer;
int temp;
MPU6050 sensor(0x68);
    delay(3);
  gyro_x_cal /= 1000;
  gyro_y_cal /= 1000;
  gyro_z_cal /= 1000;
void loop(){
(deleted)
(deleted)
aaron_wong:
@WaleedMohammed, I tried your code. On the serial monitor, I just see crazy symbols like ⸮ and ▯. Is there a problem with the code or is it just my computer? Attached is a screenshot of the serial monitor.
I'm no expert, but that could be caused by selecting the wrong baud rate? in this case it's 9600.
But this post is nearly 2 years old... probably the guy had it sorted by now.
