I want to have further knowledge about MPU-9250. I am just new in programming tis kind of sensor. I already read the specs, and still I still don't understand the functions and some features of it. I hope someone, or anybody will help me here regarding this topic.
Thanks for giving me that link, it's working. When I run it I got negative values, what do you think that reading indicates? And if I were going to use not only one MPU 9250, how are we going to connect them? Also, I want to know on how to determine their addresses. Thanks.
I am having issues calibrating the code for the MPU-9250 sensor. I am using arduino Uno. The sensor works, but it is giving random values. I tried following this link:
(I am using the code from the link 'the script' to calibrate the acc/gyro first seperately.)
But I am not savvy enough in tech at all to understand why it is giving this error:
THE_Calib_Code_Acc_Gyro:118:18: error: lvalue required as left operand of assignment
int TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
exit status 1
