MPU6050 acceleration output in m/s²
Hey,
I want a sketch with temp, gyro and acc output.
Temp output in degrees and gyro axis output is fine. But i don't understand the Acceleration Axis output.
I'm using a library with these commands for Acceleration:
accX = ((float)rawAccX) / 2048.0;
accY = ((float)rawAccY) / 2048.0;
accZ = ((float)rawAccZ) / 2048.0;
and i'm getting this on the serial monitor if i dont move the mpu:
accX : -0.31	accY : 0.05	accZ : 8.50
How do I change the output in understandable m/s² ?
Thanks
I use a calibration based on this set of articles: Accelerometer Calibration I: Introduction | Chionotech
The maths gets kind of hairy but the end result is a calibration program that is simple to use and very accurate.
Thanks for the link. I also read the 6050 datasheet, so let's see if i understand it correctly:
The mpu6050 has the full-scale range between +-2 and +-16g.
So the library uses +-2 g (16,384 LSB/g), because of these lines:
accX = ((float)rawAccX) / 16384.0;
	accY = ((float)rawAccY) / 16384.0;
	accZ = ((float)rawAccZ) / 16384.0;
When my mpu6050 is lieing on the table, I get this output:
accX : -0.05	accY : -0.01	accZ : 1.07
So the mpu6050 reads the gravity on z-axis with 1.07 g, right? So all the data is in g.
1,07 g = 10,49 m/s²
If I multiply all the output with 9.806, I should get the wanted m/s² output?
Or am I failing in math currently? :blush:
Once you get the output in g, then yes, just multiply by 9.806
Ok, but to help me understand:
The full-scale range +-2 g (16,384 LSB/g) results in the output for 1 g on all axis if the library devides the raw data with 16384?
Does someone have a good website or explanation for this?
Do you know what "LSB" means?
It is very simple maths after that point.
That output indicates you need to calibrate the accelerometer, and it is either not lying perfectly flat on the table or the table is not level.
