Mpu6050 and arduino nano on I2c
Hi, I'm trying to build a drone but I have some problems. So when the motors start spinning at a decent speed the accelerometer values go to -32769. It might just have to do with my hardware but I have added anti-vibration screws and balanced the props so I don't see what else there is to do over there.
On the drone I have an Arduino uno, 2 mpu6050's and a hc-12 wich is read out by a Arduino nano wich then send the data to the Uno over an I2C bus.
What I have noticed is that when the hc-12 is receiving somethings to the values from the mpu6050's glitches sometimes so I think they are interfering with each other.
So there probably is something wrong with my code
Here is the code related to this:
const int MPU_addr1=0x68;
const int MPU_addr2=0x69;
const int NANO_addr=0x29;
void ReadMPU6050(){
if ((double)(micros() - TLoop)/1000000<double(0.05)) {
 Read=1;
 Read1MPU6050();
 Read2MPU6050();
 *Some code to get the average of both values*
 else{
  Read=0;
void Read1MPU6050() {
 Wire.beginTransmission(MPU_addr1);
 Wire.write(0x3B);  							// starting with register 0x3B (ACCEL_XOUT_H)
 Wire.endTransmission(false);
 Wire.requestFrom(MPU_addr1,14,true);  					// request a total of 14 registers
 AcX1=-(Wire.read()<<8|Wire.read())- 200;  				// 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
 AcY1=-(Wire.read()<<8|Wire.read())- 598; 				// 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
 AcZ1=(Wire.read()<<8|Wire.read());  					// 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
 Tmp=Wire.read()<<8|Wire.read();  					// 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
 GyX1=-(Wire.read()<<8|Wire.read())+ 4550;  				// 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
 GyY1=-(Wire.read()<<8|Wire.read())-380;  				// 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
 GyZ1=-(Wire.read()<<8|Wire.read());  					// 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L))
void Read2MPU6050(){
 Wire.beginTransmission(MPU_addr2);
 Wire.requestFrom(MPU_addr2,14,true);  					// request a total of 14 registers
 AcX2=-(Wire.read()<<8|Wire.read())+708;  				// 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
 AcY2=-(Wire.read()<<8|Wire.read())-390;  				// 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
 AcZ2=(Wire.read()<<8|Wire.read());  					// 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
 GyX2=-(Wire.read()<<8|Wire.read());  					// 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
 GyY2=-(Wire.read()<<8|Wire.read())+430;  				// 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
 GyZ2=-(Wire.read()<<8|Wire.read());  					// 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
void CalculateAngles() {
 dt = (double)(micros() - TLoop)/1000000;
 TLoop = micros();
if (Read==1) {
  roll = atan2(AcY, AcZ)*degconvert;
  pitch = atan2(-AcX, AcZ)*degconvert;
  gyroXrate = GyX/131.0;
  gyroYrate = GyY/131.0;
  gyroZrate = GyZ/131.0;
  compAngleX = .99 * (compAngleX + gyroXrate * dt) + .01 * roll;          // Calculate the angle using a Complimentary filter
  compAngleY = .99 * (compAngleY + gyroYrate * dt) + .01 * pitch;
  AngleX = compAngleX;
  AngleY = compAngleY;
  AngleZ = AngleZ + gyroZrate * dt;
void ReadNano(){
 Wire.begin(NANO_addr);
 Wire.onReceive(ReadController);
void ReadController() {
 double dtNano = (double)(micros() - TNano)/1000;
 if (dtNano<75){
  while (0 < Wire.available()) {
    char c = Wire.read();
  Stringinput = Stringinput + c;
  firstnumber = Stringinput.substring(0,1).toInt();
 *Some code to determine what value is what*
void starti2cbus(){
 Wire.begin();
 Wire.write(0x6B);
 Wire.write(0);
 Wire.endTransmission(true);
 Wire.begin();
 Wire.write(0x6B);
 Wire.write(0);
starti2cbus();
ReadNano();
ReadMPU6050();
CalculateAngles();
/*GetSpeed(); 							(non related things)
Stabilization();
ControlESCs();
Output();*/
TNano = micros();
delay(2);
I hope someone finds my mistake
Thank you for your time anyway
That doesn't work. The UNO talks to the MPU6050 by I2C, so it's the master on the bus. If it has to listen to the Nano, it would have to change to slave mode for that time but it never knows when the Nano talks to it. Although you'll find a lot of stuff about I2C multimaster operation, forget it. You won't get that reliable. Why do you have the Nano in place? Why don't you connect the HC-12 directly to the UNO's hardware serial interface?
Well reading the hc-12 takes about 10 milliseconds wich is way to much if you want the calculate the right angles. I think I'm going to ditch i2c and use ppm signals.
How does that relate to the question you had in the first post? And what exactly needs 10 milliseconds to read? Of course you must not use SoftwareSerial to read the HC-12 but if you use the hardware serial interface the hardware is doing most of the job and you have plenty of time to calculate whatever you want.
Please explain how you think that this will make the situation better.
