Hi i am trying to use mpu6050 accelerator as a motion detection sensor. The acc (x,y,z) data is calculated to gather an average value. I assigned thresholds while i get the average number as (1.0) . If the readings off the threshold i am hoping to get a distinctive pulsing sound every 6 seconds from a buzzer. And if the the values are between the threshold then i want to play another tone . In this case because i don't have a buzzer, i used led(13) to simulate it. I tried to write some code inside the loop but i think they interfere with each other. When it waits for the interval i don't want reading to be interrupted. So eventually what i want arduino to do is ; while running beep every 6 seconds while staying still for 3 seconds play a sound. Any help appreciated. Thanks.
void loop () {
Arx = accel_t_gyro.value.x_accel;
Ary =accel_t_gyro.value.y_accel;
Arz = accel_t_gyro.value.z_accel;
Amag = sqrt(square(Arx)+square(Ary)+square(Arz));
Amag = Amag/16840; // After this if there is no movement in any axis it reads almost 1.0 all the time.
Serial.println(Amag); // checking the reading
tolerance = 0.15;
xNorm = 1.0;
if (Amag >(xNorm+tolerance)||Amag < (xNorm-tolerance))
Running();
Serial.println("Running");
else {
Serial.println("Stopped");
Stopped();
delay(200);
void Running(){
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
void Stopped(){
if ((unsigned long)(millis() - waitUntil) >= interval) { // interval value is 6000.
digitalWrite(13, !digitalRead(13)); // Toggle the LED on Pin 13, later on i want to get a sound.
waitUntil = waitUntil + interval; // wait another interval cycle
OK. I made some progress already.
#define interval 6000
double Amag,xNorm,tolerance;
const int ledPin = 13;
int ledState = LOW;
unsigned long waitUntil=0;
long previousMillis = 0;
const int numReadings = 20;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
double Arx, Ary,Arz;
Amag = Amag/16840;
Amag= Amag*100;
// subtract the last reading:
total= total - readings[index];
// read from the sensor:
readings[index] = Amag;
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings) {
index = 0;
// calculate the average:
average = total / numReadings;
// send it to the computer as ASCII digits
Serial.print("average= ");
Serial.print(average);
Serial.print("Amag= ");
delay(5); // delay in between reads for stability
tolerance = 10; // Will be adjusted with a pot
xNorm = 95; // open for fine tuning
if (average >(xNorm+tolerance)||average < (xNorm-tolerance))
Serial.println("Running ");
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
else {
Stopped();
void Stopped(){
Serial.println("Stopped ");
if ((unsigned long)(millis() - waitUntil) >= 100) { // check for rollover
// It's time to do something!
waitUntil = waitUntil + 100; // wait another interval cycle
These are core parts.I applied smoothing to get stable values. And this gives me some time for shifting between states.
I think i have to connect a buzzer . Find a nice tune, and make some adjustments afterwards.
