Hello!
I'm currently working on a 2WD self-balancing robot. The problem I'm having is that the gyro/acc values are drifting and therefore the robot eventually will fall over.
The robot balances for about 5 seconds but after that it always falls over into the same direction. When I read the values on the serial monitor i noticed that even if the robot is still, the roll value increases in a steady pace.
Here's my code:
#include <PID_v1.h>
#include <Wire.h>
const int MPU = 0x68; // MPU6050 I2C address
float AccX, AccY, AccZ;
float GyroX, GyroY, GyroZ;
float AX_angle, AY_angle, GX_angle, GY_angle;
float roll, pitch, yaw;
float elapsedTime, currentTime, previousTime = 0;
// Motor control
const int LM1 = 2;
const int LM2 = 4;
const int RM1 = 6;
const int RM2 = 7;
const int LMpwm = 3;
const int RMpwm = 5;
const int ctrl5V = 10;
// PID
double setPoint;
double input = 0;
double output = 0;
const double Kp = 0.3;
const double Ki = 0.5;
const double Kd = 0.025;
PID pid(&input, &output, &setPoint, Kp, Ki, Kd, DIRECT);
void setup(){
Serial.begin(19200);
Wire.begin();
Wire.beginTransmission(MPU);
Wire.write(0x6B);
Wire.write(0x00);
Wire.endTransmission(true);
// Motor control
pinMode(LM1, OUTPUT);
pinMode(LM2, OUTPUT);
pinMode(RM1, OUTPUT);
pinMode(RM2, OUTPUT);
pinMode(LMpwm, OUTPUT);
pinMode(RMpwm, OUTPUT);
pinMode(ctrl5V, OUTPUT);
digitalWrite(ctrl5V, HIGH);
// PID
setPoint = roll;
pid.SetMode(AUTOMATIC);
pid.SetSampleTime(10);
pid.SetOutputLimits(-255, 255);
void loop(){
// Accelerometerns vinklar:
Wire.write(0x3B); // ACC Address
Wire.endTransmission(false);
Wire.requestFrom(MPU, 6, true);
AccX = (Wire.read() << 8 | Wire.read()) / 16384.0 ; // Kombinerar 2 mätvärden
AccY = (Wire.read() << 8 | Wire.read()) / 16384.0 ;
AccZ = (Wire.read() << 8 | Wire.read()) / 16384.0 ;
AX_angle = ((atan((AccY) / sqrt(pow((AccX), 2) + pow((AccZ), 2))) * 180 / PI) - 1.22 );
AY_angle = ((atan(-1 * (AccX) / sqrt(pow((AccY), 2) + pow((AccZ), 2))) * 180 / PI) + 0.73 );
// Gyroskopets vinklar:
currentTime = millis();
elapsedTime = (currentTime - previousTime) / 1000;
Wire.write(0x43);
GyroX = (Wire.read() << 8 | Wire.read()) / 131;
GyroY = (Wire.read() << 8 | Wire.read()) / 131;
GyroZ = (Wire.read() << 8 | Wire.read()) / 131;
//GyroX -= 0.32;
//GyroY += 0.38;
GX_angle += GyroX * elapsedTime;
GY_angle += GyroY * elapsedTime;
previousTime = currentTime;
// Complementary filter
roll = 0.9 * GX_angle + 0.1 * AX_angle;
pitch = 0.96 * GY_angle + 0.04 * AY_angle;
input = roll;
Serial.println(input);
pid.Compute();
if(roll > setPoint)
forward();
else if(roll < setPoint)
backwards();
/*else
halt();*/
void forward(){
digitalWrite(LM1, HIGH);
digitalWrite(LM2, LOW);
digitalWrite(RM1, LOW);
digitalWrite(RM2, HIGH);
analogWrite(LMpwm, output);
analogWrite(RMpwm, output);
void backwards(){
digitalWrite(LM1, LOW);
digitalWrite(LM2, HIGH);
digitalWrite(RM1, HIGH);
digitalWrite(RM2, LOW);
analogWrite(LMpwm, -output);
analogWrite(RMpwm, -output);
void halt(){
analogWrite(LMpwm, 0);
analogWrite(RMpwm, 0);
I've read that gyro values drift over time but I'm using a complementary filter, and the values increase in such a steady pace that i have a hard time believing that's the problem.
What causes the problem?
// Markus A
