MPX5700DP pressure water sensor
Can I measure water pressure with this sensor MPX5700DP ?
I read datasheet, but there is not enough information to use in water pressure.
this is datasheet
Minimum pressure reading 0kPa
Maximum pressure reading 700kPa
Accuracy ± 2.5%
Analog output type
4.7 V analog output
Response time 1 ms
Power supply 4,75 → 5,25 V c.c.
Maximum operating temperature + 125 ° C
Minimum operating temperature -40 ° C
I appreciate your help.
Thank for all
From the data sheet
Media, other than dry air, may have adverse effects on sensor performance and long-term reliability.
  1. look for a sensors that are specifically designed for water pressure.
  2. know the maximum pressure your water system can have.
  3. get as sensor that can handle this pressure (a range of 700 kPa should do fine for typical municipal water supply pressures).
