MQTT and LoRa issues
I'm having an issue where the device (esp32) stops receiving a subscription after a few hours. It publishes from a lora node fine, but dows not respond to a message from the broker. Am I missing something? If I reset the board, the messages go to the node, but then quits some time later.
  This one is kinda working from Jan 26
#include <WiFi.h>
#include <MQTT.h>        // https://github.com/256dpi/arduino-mqtt
#include <SPI.h>
#include <LoRa.h>        // https://github.com/sandeepmistry/arduino-LoRa
const char ssid[] = "MikesShop";
const char pass[] = "1qazxsw2";
#define BROKER_ADDRESS "10.10.7.4"
#define BROKER_PORT 1883
#define BROKER_USER ""
#define BROKER_PASSWORD ""
#define ss 5
#define rst 14
#define dio0 2
#define MONITOR_LED 25
byte msgCount = 0;            // count of outgoing messages
byte localAddress = 0xCC;     // address of this device
WiFiClient net;
MQTTClient mqttClient;
bool routeIncomingMessage = false;
String sourceDeviceAddress;
String sourceDeviceProperty;
String sourceValue;
bool routeOutgoingMessage = false;
char destinationDeviceAddress[10];
char destinationDevicePropery[10];
char destinationValue[10];
void registerDevice(String address, String device_input_property) {
  String topic = "TheShop/" + address + "/" + device_input_property;
  mqttClient.subscribe(topic);
void connectToBroker() {
  Serial.print("Connecting to MQTT Broker ...");
  while (!mqttClient.connect("TheShop", BROKER_USER)) {
    Serial.print("MQTT Client Disconnected! ");
    Serial.print(mqttClient.lastError()); Serial.println(" Return Code");
    Serial.println(mqttClient.returnCode());
  Serial.println(" connected!");
  // Last Will initialization
  mqttClient.publish("Shop", "Ready", true, LWMQTT_QOS1);
  mqttClient.subscribe("TheShop/#");
void onLoraReceive(int packetSize) {
  if (packetSize == 0) return;          // if there's no packet, return
  // read packet header bytes:
  int recipient = LoRa.read();          // recipient address
  byte sender = LoRa.read();            // sender address
  byte incomingMsgId = LoRa.read();     // incoming msg ID
  byte incomingLength = LoRa.read();    // incoming msg length
  String incoming = "";                 // payload of packet
  while (LoRa.available()) {
    incoming += (char)LoRa.read();
  if (incomingLength != incoming.length()) {   // check length for error
    Serial.println("error: message length does not match length");
    return;
  // if the recipient isn't this gateway
  if (recipient != localAddress) {
    Serial.println("This message is not for me.");
    return;
  // if message is for this device, or broadcast, print details:
  Serial.println("Received from: 0x" + String(sender, HEX));
  //Serial.println("Sent to: 0x" + String(recipient, HEX));
  //Serial.println("Message ID: " + String(incomingMsgId));
  //Serial.println("Message length: " + String(incomingLength));
  Serial.println("Message: " + incoming);
  Serial.println("RSSI: " + String(LoRa.packetRssi()));
  while (routeIncomingMessage == true);
  char buf[sizeof(incoming)];
  incoming.toCharArray(buf, sizeof(buf));
  sourceDeviceProperty = strtok(buf, "=");
  sourceDeviceAddress = String(sender, HEX);
  sourceValue = strtok(NULL, "=");
  routeIncomingMessage = true;
void mqttMessageReceived(String &topic, String &payload) {
  Serial.print("Received Topic: ["); Serial.print(topic); Serial.print("] Payload: "); Serial.println(payload);
  char buf[topic.length() + 1];
  topic.toCharArray(buf, sizeof(buf));
  char *p = strtok(buf, "/");
  p = strtok(0, "/");
  if (p == NULL)
    return;
  strcpy(&destinationDeviceAddress[0], p);
  p = strtok(0, "/");
  if (p == NULL)
    return;
  strcpy(&destinationDevicePropery[0], p);
  payload.toCharArray(destinationValue, sizeof(payload));
  routeOutgoingMessage = true;
void sendLoraMessage(byte device, String outgoing) {
  LoRa.beginPacket();                   // start packet
  LoRa.write(device);                   // add destination address
  LoRa.write(localAddress);             // add sender address
  LoRa.write(msgCount);                 // add message ID
  LoRa.write(outgoing.length());        // add payload length
  LoRa.print(outgoing);                 // add payload
  LoRa.endPacket();                     // finish packet and send it
  msgCount++;                           // increment message ID
//##########################   SETUP   #############
  Serial.println("Start LoRa Gateway");
  pinMode(MONITOR_LED, OUTPUT);
  digitalWrite(MONITOR_LED, HIGH);
  // WiFi Initializations
  WiFi.begin(ssid, pass);
  Serial.print("Connecting to WiFi ...");
    Serial.print(".");
  // MQTT Initializations
  mqttClient.begin(BROKER_ADDRESS, net);
  mqttClient.setOptions(15, true, 1500);//keepalive, cleansessiom, timeout
  //mqttClient.setWill("LoRa/gateway", "Disconnected", true, LWMQTT_QOS1);
  mqttClient.onMessage(mqttMessageReceived);
  connectToBroker();
  // Lora Initialization
  LoRa.setPins( ss, rst, dio0);
  if (!LoRa.begin(915E6)) {
    Serial.println("LoRa init failed. Check your connections.");
    while (true);
  Serial.println("LoRa init succeeded.");
  LoRa.onReceive(onLoraReceive);
  LoRa.receive();
//#####################   LOOP  ###############
  mqttClient.loop();
  delay(180);
  if (routeOutgoingMessage) {
    char buf[30];
    strcpy(&buf[0], &destinationDevicePropery[0]);
    strcat(&buf[0], "=");
    strcat(&buf[0], &destinationValue[0]);
    sendLoraMessage(strtol(destinationDeviceAddress, NULL, 16), buf);
    LoRa.receive();
  if (routeIncomingMessage) {
    String topic = "Shop/" + sourceDeviceAddress + "/" + sourceDeviceProperty;
    Serial.print("Sending Topic: ["); Serial.print(topic); Serial.print("] Payload: "); Serial.println(sourceValue);
    mqttClient.publish(topic, sourceValue, true, LWMQTT_QOS1);
  delay(100);
  digitalWrite(MONITOR_LED, LOW);
Take a look at the mqtt logs and see if you can glean anything from there
Or comment out the Lora code and see if mqtt stays connected. I don't know if your in
command of the publisher to send out a message every so often.
I couldn't find anything in the mqtt broker logs. I tried to send a keepalive reqest form the nod-red, whick would keep the module responding for 20 hours or so, but would still stop responding after that. I would try a different mqtt library, if I can figure out how to extract the topics to send over LoRa
The mqtt broker is running on your pc ? I use eclipse, there may be others but that seems to
be the goto. You can create clients and pubs on your pc and at the same time on your board
to see if they all lose connection or just on your board to try to narrow it down some.
I have mosquitto on a PI with a dozen or so home automation devices on it. Broker was showing the topics being sent, but the handler on the esp32 wasn't responding to it. I got EspMQTTClient working so far, and will see what happens over the next day. I wasn't sure the if anyone was around that had some experience with the mqtt and lora. New to the coding side of builds, and have been struggling with interpreting the hows and whys. It's coming. Thanks
