Hi.
I set up a windows 10 eclipse mosquitto broker. My other devices (zigbee2mqtt, tasmota etc) connects fine, but my ESP8266 / ESP32 will not connect with user and password. Authentication error.
If I edit the conf file with "allow_anonymous true" it can connect, but with "allow_anonymous false" it won't.
Like I said, other devices connect just fine with the same username and password.
Any suggestions?
Although bad practice I removed some part of the code to stay within 9000 char.
#define MQTT_KEEPALIVE 60
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
#define LED 16
//"**CHANGE**" wifi SSID and password
const char* ssid = "myssid";
const char* password = "mypsswd";
//"**CHANGE**" MQTT server IP address
const char* mqtt_server = "192.168.winpc.ip"; //my windows machine ip
const char* mqtt_user = "user"; // from psswd file in C:/mosquitto directory
const char* mqtt_password = "psswd"; //from psswd file in C:/mosquitto directory
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
IPAddress server(192, 168, x, xx);
unsigned long heartbeat_millis=0;
int heartbeat_cnt=0;
//"**CHANGE**" debug output
#define MyDebug 0 //0=no debug, 1=deeebug
**CHANGE** mqtt_name[] used as part of topic name
/ble/MQTT_NAME/mac/rssi
/ble/MQTT_NAME/mac/volt
const char mqtt_name[]="2etg";
const int pinHandShake = 4; //handshake pin, esp8266 GPIO4/D2
//buffer for char[] used in mqtt publishes, size at least as big as topic + msg length
char mqtt_buf[120]; // e.g "/ble/esp1/d76dcd1b3720/volt" is 30 chars long
bool conn_status;
// Callback function header
void callback(char* topic, byte* payload, unsigned int length);
const int serialBufSize = 100; //size for at least the size of incoming JSON string
static char serialbuffer[serialBufSize]; // {"mac":c2f154bb0af9,"rssi":-55,"volt":3.05,"mag":1}
static char mytopic[120]; //MQTT topic string size, must be less than size declared.
//todo: add error checking for mqtt msg lengths
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
digitalWrite(LED, HIGH); //off
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
char message_buff[60]; //payload string
// create string for payload
int i=0;
for(i=0; i<length; i++)
message_buff[i] = payload[i];
message_buff[i] = '\0'; //terminate buffer string class eol
String msgString = String(message_buff);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP8266Client123-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
if (client.connect(clientId.c_str())) {
Serial.println("connected");
// Once connected, publish an announcement...
client.publish("outTopic", "hello world");
client.loop();
// ... and resubscribe
//client.subscribe("inTopic");
//client.subscribe("50C51C570B00"); //switched ble
//client.subscribe("req_door_open");
//client.subscribe("req_door_close");
//client.subscribe("mq_snow_red");
//client.subscribe("mq_snow_green");
//client.subscribe("mq_snow_blue");
//client.subscribe("mq_tree_red");
//client.subscribe("mq_tree_green");
//client.subscribe("mq_tree_blue");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
pinMode(LED, OUTPUT); // BUILTIN_LED pin as an output, actually pin D0 (GPIO16)
digitalWrite(LED, LOW); //LED on
Serial.begin(9600); //ESP8266 default serial on UART0 is GPIO1 (TX) and GPIO3 (RX)
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
pinMode(pinHandShake, OUTPUT);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
//stealing this code from
//https://hackingmajenkoblog.wordpress.com/2016/02/01/reading-serial-on-the-arduino/
//non-blocking serial readline routine, very nice. Allows mqtt loop to run.
int readline(int readch, char *buffer, int len)
static int pos = 0;
int rpos;
if (readch > 0) {
switch (readch) {
case '\n': // Ignore new-lines
case '\r': // Return on CR
rpos = pos;
pos = 0; // Reset position index ready for next time
return rpos;
default:
if (pos < len-1) {
buffer[pos++] = readch; //first buffer[pos]=readch; then pos++;
buffer[pos] = 0;
// No end of line has been found, so return -1.
return -1;
//json iterator that parses char* and publish each key-value pair as mqtt data
void localParseJson(char *mybuf)
//JSON parsing
//JSON object exists in this scope, routine should execute atomatically no interrupts
//If software serial is used, and parsing is interrupted, json object still be valid?
StaticJsonBuffer<200> jsonBuffer;
JsonObject& object = jsonBuffer.parseObject(mybuf);
Incoming uart:
mac:c2f154bb0af9,rssi:-55,volt:3.05,mag:1
Iterate and publish as
/ble/livingroom/c2f154bb0af9/rssi -55
/ble/livingroom/c2f154bb0af9/volt 3
/ble/livingroom/c2f154bb0af9/mag 1
1) count # fields in after MAC
2) concat "ble"/"MAC"/+iterate field
3) capture data to publish
if (object.success())
// Parsing success, valid json
//todo: it's too easy to forget mytopic size, not checking for size when string being assembled.
// add error checking and improve readability
int topic_char_index=0;
// mytopic[i] = '\0'; make sure null terminate mytopic
//construct the first part of the topic name, which is just /ble/mac
mytopic[0]='/'; topic_char_index++;
mytopic[1]='y'; topic_char_index++;
mytopic[2]='y'; topic_char_index++;
mytopic[3]='y'; topic_char_index++;
mytopic[4]='/'; topic_char_index++; //topic_char_index is 5;
//add gateway location name, /ble/LIVINGROOM
int mqtt_name_len = sizeof(mqtt_name); //returns num of chars + 1 for \0 character
#if MyDebug
Serial.print("topic_char_index before mqtt_name: ");
Serial.println(topic_char_index);
Serial.print("size of mqtt_name_len should be 16: ");
Serial.println(mqtt_name_len);
#endif
for (int i=0; i<(mqtt_name_len-1); i++)
#if MyDebug
Serial.println(mqtt_name[i]);
#endif
mytopic[topic_char_index] = mqtt_name[i];
topic_char_index++;
mytopic[topic_char_index] = '/'; topic_char_index++;
#if MyDebug
Serial.print("topic_char_index after mqtt_name: ");
#endif
//set string pointer to JSON Value containing the key "mac"
// so it's pointing to "mac":c2f154bb0af9
const char* mac_name = object["mac"];
#if MyDebug
Serial.println("mac name is");
Serial.println(mac_name);
#endif
int sizeofff = strlen(mac_name); //returns exactly number of characters in mac_name. Doesn't add 1 like sizeof
#if MyDebug
Serial.print("size of macname: ");
Serial.println(sizeofff);
#endif
// /ble/livingroom/c2f154bb0af9/
//fill mac address into topic name string
for (int i=0; i<sizeofff; i++)
mytopic[topic_char_index]= mac_name[i];
topic_char_index++;
topic_char_index++;
#if MyDebug
Serial.println("mytopic after mac address add");
Serial.println(mytopic);
#endif
